How Long Did Your Front Brake Pads Last?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rickochet, Jul 11, 2015.
  1. Jan 2, 2016 at 8:35 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I've gotten over 120K on original Toyota pads - different models of Toyota. Have done the same on other Asian SUVs.
    It boils down to the type of driving you do. Mine is mostly highway. If you're doing stop-n-go all day long, you likely won't see what I have.
    Also - some people ride their brakes. That will kill them quickly.
  2. Jan 2, 2016 at 9:29 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had over 100K on my old 2000 when I got rid of it and never had to change front or the rear brakes, my old 2008 still had plenty of meat left on them when I traded at 80K.
  3. Jan 2, 2016 at 4:24 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I'm on my 4th set @ 98000 miles. 2nd set of rear brakes.
  4. Jan 2, 2016 at 4:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    $0.
    You should find a quality independent mechanic that has some modern tools, like computer access to AllData or other commercial software to help them with details on various marquees.
    Most of the normal wear items on these trucks are nothing special in terms of mechanical skills or tools.
  5. Jan 3, 2016 at 2:20 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Something wrong...
    Take your foot off the brake pedal when driving.
    File IFR and big_jarv like this.
  6. Jan 3, 2016 at 7:18 AM
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Two weeks ago I changed out the pads and pins on my pharmacist's '02 4Runner - @ 250,000 miles , original pads , rotors and pins . He's owned it since new , never been in the shop and he documents the snot out of everything . Had me do the job since he could not get those pins to budge , they were stuck good and one on RF had to be drilled out on both ends . He did not get rotors as I recommended , his pads had almost .250" left and rotors spec'd out with plenty of thickness yet so they are staying . No heat cracks or signs of heavy glazing on those rotors either . Right front caliper will have to be swapped out soon , two inboard pistons are starting to lose the rubber boots and i didn't have any that size in stock . I'm still scratching my head how he's managed to get that many miles on the oem brakes , but hat's off to him anyway . He's mid-50's and evidently drives quite lightly....
    Sarge
  7. Jan 3, 2016 at 4:20 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    If you use engine braking and time our stops without using your brakes, I can see them lasting that long.
  8. Jan 3, 2016 at 5:03 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I've gotten 100k out of the front pads. Bought Toyota pads to replace. Well worth it compared to those, "lifetime," warranty pads you get at the land of fuzzy dice and dual wiper blades.
  9. Jan 3, 2016 at 5:13 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    As you can see when we're seniors, our minds goes sooner than the brake pads.
    Just in case you want to know my weeny lasted longer than my brakes.
  10. Jan 3, 2016 at 5:15 PM
    BuffaloScout
    BuffaloScout Well-Known Member
    Minnesota
    10 4x4 TRD
    Weathertech, Wet Oaks, Baby Car Seat, Flashlight Mod
    Just got quoted $270 dollars for new pads and for the dealer to grind down rotors. Sounds fair to me, although I will still call around and hear other quotes. By the way my truck is 2010 with 60,000 miles on it. Hope that helps.
  11. Jan 3, 2016 at 5:16 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    7.5 years and 80k miles.
    They had a few thousand more miles left in them but didn't want to have to deal with it during the winter.
  12. Jan 3, 2016 at 6:12 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    2010 Prerunner with 92K and still plenty of pad left. Of course most of my driving is highway miles.
  13. Jan 3, 2016 at 6:53 PM
    Riverratsl
    Riverratsl Member
    Scott
    West tennessee
    2005 4x4
    One size bigger tire then stock.
    I just changed my front pads out with 170000 on them. They were the originals. Rotors were still good. :)
    It's a five speed and I downshift a lot rather then use brakes. Most of the time I use the pedal more for the brake light then actual braking.
    I guess it is habit from driving trucks :)
  14. Jan 3, 2016 at 7:04 PM
    Taco2Taco79
    Taco2Taco79 Active Member
    The Green State
    2015 TRD Sport MGM DCSB
    Bilstein 6112/5160 ..275/65/18 DuraTracs on MB KO rims...NFab Bars...WetOkoles
    I changed my brakes at 140k on my 05 ac 2.7 4x4...
  15. Jan 3, 2016 at 7:18 PM
    #35
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I know, I'm a first gen, but the 99 I just picked up only has 62k miles on it. I had to replace the pads because they were worn, but they were factory pads from 1999 haha.
  16. Jan 3, 2016 at 7:51 PM
    #36
    cbrcolin
    cbrcolin Well-Known Member
    Colin
    THOUSAND PALMS, CA
    19 QUICKSAND 7545
    NONE YET
    96,000+ miles on my 2009 2.7 Prerunner 5 speed manual. Original pads still have 4-5 mm left.
