How Long Did Your OEM Battery Last?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcman01, Dec 30, 2013.
  1. Oct 1, 2016 at 1:45 PM
    #161
    tsb
    tsb 2018 National Champions
    Clemson Tigers
    '14 4X4 DBCSB TRD OR
    N-FAB nurfs, ARE cover, Gentex mirror, 20% tint
    Just figured out my '14 has a programming flaw with the headlights auto off. The light turn themselves off when i open the driver's door. However if you exit the by any other door the lights stay on and runs the battery dead.
    Or if you turn on the ignition switch from the passenger seat with the lights on they stay on when u turn the ignition off and exit from the passenger door.
    I normally leave my lights on since they turn off when I open the driver door.
    I left a window down as I was leaving the truck and jumped in the passenger door to raise the window. My light were left on several hours. I had no idea the lights came on and didn't cut themselves off from the passenger door.
    TRDSport10 likes this.
  2. Oct 1, 2016 at 3:58 PM
    #162
    prodelivery
    prodelivery Well-Known Member
    Tay
    '98 reg cab 4wd 5 speed GREEN
    I work at a dealership. There's no telling whether your truck had it's battery drained while sitting on the lot. All too often a light gets left on or something and it may sit there completely dead for even a couple weeks. Can't be good for the long term. Vehicles sitting on the showroom floor often go dead, too. They are usually recharged quickly, though. This happens repeatedly sometimes which can't be good for the battery life. I figure this explains the varying results. In most cases the battery has never died before purchase, but I wouldn't be too surprised if it was 1/10.
  3. Oct 1, 2016 at 5:34 PM
    #163
    did_you_say_tacos
    did_you_say_tacos Well-Known Member
    2010 White TRD Off-Road Crew
    Toytec Eibach/Bilstein 5100 3" Lift Stealth Custom Series SR8 Bronze 17x8.5 Cooper AT3 275/70/17 Bestop Softop Thule Rack
    Had to replace my factory battery this morning. 2010 taco with 84k. Could run all accessories but not enough cold cranking amps to turn it over.
  4. Oct 1, 2016 at 5:45 PM
    #164
    Protrucker
    Protrucker Active Member
    Al
    Broome County, NY
    06 Tacoma 4x4
    My '06 still has the original battery & hasn't shown any signs of getting weak.
    shakerhood likes this.
  5. Aug 19, 2017 at 4:46 PM
    #165
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Update: As reported above, the stock battery lastest 3 years and 3 months. The replacement battery just died last week while I was in Baja... at a gas station... it wouldn't crank, during a 3,000 mile trip with no problems before, after 2,000 miles! That battery lasted 5 years and 5 months. There was an Auto Zone a block from the gas station, so after a jump start, I got it there and had a new battery installed. Saved the day... at Ciudad Constitucion, Baja California Sur!
  6. Aug 19, 2017 at 8:44 PM
    #166
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I've made it a habit to replace my battery every 4 years regardless. Also all my drives are about 15 minutes and I rarely drive longer than that. This along with Texas heat for 4 summers. So cheap insurance to not get stuck somewhere.
  7. Aug 19, 2017 at 8:51 PM
    #167
    rdjr17
    rdjr17 Well-Known Member
    Ron
    Nepa
    2019 voodoo blue Trd pro
    My 2011 went in 3 years replaced it with Megatron interstate battery
  8. Aug 19, 2017 at 10:10 PM
    #168
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    Dealer replaced right at 2 years 25k miles during routine service. Said it tested bad, I had no signs up to that point.
  9. Aug 20, 2017 at 7:12 AM
    #169
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    Mine starting leaking fluid from around the positive terminal at 3 years/50k miles... decided to swap it out before it left me stranded somewhere
  10. Aug 20, 2017 at 12:56 PM
    #170
    SmittyExtreme
    SmittyExtreme New Member
    NJ
    Silver Sky 2014 TRD OR DCSB
    Stealth Mounted 32" bar, Roof mounted 52" bar, ditch lights, snorkeled rear diff. Other odds and ends. Currently in the build process.
    Had my OEM battery until I got the truck airborne(all 4 tires off the ground about 2ft) (also on accident) and ruined a cell in the battery from the landing.. So 3 years or so?
  11. Aug 21, 2017 at 2:24 PM
    #171
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    The one in my 02 Tundra lived almost 10 years....the Taco is only 3 years old so who knows how long that one will last.
  12. Aug 21, 2017 at 5:13 PM
    #172
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    Still running the OEM in my 2012. I check it every month or so with a meter and it's still holding charge well. Fired up all winter even on days -20f.
  13. Aug 21, 2017 at 5:25 PM
    #173
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    My truck will be 10 years old in November, and I just put in the 4th battery about a month ago. All the batteries so far have been Toyota batteries. The new battery that I just put in is an EverStart Maxx from Walmart.
  14. Aug 21, 2017 at 5:33 PM
    #174
    TacoGold
    TacoGold Well-Known Member
    Peter
    Austin, Texas
    2010 DCSB TRD OR
    Working towards an overland build
    bought my 2010 used so I dont know if the battery that was in it that died was the original (looked like it probably was), but I had to replace it in 2014. Been running an Optima 8037-127 D27F YellowTop Starting and Deep Cycle Battery since then (so for over 3 years as the starter battery) with no problems (knock on wood for when I drive home tonight).
  15. Aug 22, 2017 at 5:08 AM
    #175
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Just replaced mine in July. Put a EverStart Maxx from Walmart in it.
  16. Aug 22, 2017 at 5:20 AM
    #176
    Johnjaz
    Johnjaz Well-Known Member
    AZ
    07 DCSB 4x4 Sport
    Dented Bumper
    I get about 3 in AZ
  17. Aug 22, 2017 at 5:22 AM
    #177
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I've had batteries last 5-6yrs, and a few that only lasted a year. You just never know, too many variables.
  18. Aug 22, 2017 at 10:29 AM
    #178
    jmgrq956
    jmgrq956 Member
    Albuquerque, NM
    15 silver sky trd
    Just had mine replaced by dealer saturday...2 years, 30k. Just went out. Luckily went out now and not on my camping trip in CO.
  19. Aug 22, 2017 at 11:18 AM
    #179
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The only time I've had to replace my batteries is when relatives have not closed my door properly and the left on lights drained the battery. Pretty much kills it every time. It never maintains a charge after that.
    I did leave my radio on in my truck all weekend one time in my Taco and the battery never died. Still going strong on my stock battery 5 years now.
  20. Aug 22, 2017 at 11:47 AM
    #180
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    7 years and mine was dead
