How long do brakes typically last?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomonkey, Nov 4, 2023.
  1. Nov 4, 2023 at 9:35 AM
    tacomonkey
    tacomonkey [OP] Well-Known Member
    I have a 2015 Prerunner with 40k miles. I've never replaced the brakes. I recently went to a local tire center to get my tire patched and they said I needed new brakes. I opted to hold off and just give me an estimate. The paperwork says "1mm and rotoglazed" - $529.97 ceramic pads, brake rotor. Rear brakes, it states "Brake dust" - $34.99 adjust and clean. I don't drive much, hence the low mileage. When I do drive, my brakes feel fine, no squeaking and works as expected. My wife even said my brakes feel better than her Highlander brakes, which were replaced a year ago.
    How long do brakes usually last?
    Do Tacomas have a wear indicator? (Visual or audible)
    What is the best way to inspect the brakes and determine if it's time to replace?
  2. Nov 4, 2023 at 9:38 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    The fronts are easy just jack up the truck and remove the front wheels and take a look at the pads.
    Brake life depends a lot on your driving style in addition to the pad/rotor so you won’t get a specific answer on lifespan.
  3. Nov 4, 2023 at 9:45 AM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Sounds about right, if you doubt them pull the front wheels, the rear shoes will last much longer than the front pads and rotors. Like said above also depends on your driving habits.
  4. Nov 4, 2023 at 10:07 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It depends on your driving style.
    Fronts 60k-80k
    Rears 100k-150k
    Again, driving type and style have a lot to do with it.
    My OE fronts lasted 60k.
    And I have 95k on the this set.
    I just changed my rears at 160k
    Jimmyh likes this.
  5. Nov 4, 2023 at 10:29 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    changed front pads at 80K
    rears still okay at 105K
    but I drive like a grandpa
  6. Nov 4, 2023 at 10:39 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Depends on drive style. I had mine replaced at 100k. But I also drive highway 90%+ of the time and coast to slow down a lot as a result.
  7. Nov 4, 2023 at 11:18 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    My front pads and rotors lasted 120k. Rears are still at 50p at 148k…
    It’s pretty easy to pop off a wheel and look at your front pads. Also, the Tacoma front brake job is probably one of the easiest brakes jobs known to man. Rears are a different story.
    That quote sounds like a rip off & a line of BS to me. Definitely shop around if you are bent on having somebody else do the job. I’d probably have a Toyota mechanic do the rear drums but you shouldn’t need that done at 40k, regardless of driving style.
  8. Nov 4, 2023 at 1:32 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    As said, it depends. My F & R brakes are still original at 114K miles. I check the fronts at every 5K oil change & tire rotation.... check the rears less often.
    StevieD likes this.
  9. Nov 4, 2023 at 2:07 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've gotten as much as 83,000 out of front brakes on my F150 and 200,000 out of the rear brakes on my Tacoma. The Ford is at 140,000 so far on the rear's and are factory. But it can vary a lot. For some vehicles and drivers 30,000 is as much as they will get on front brakes. But under normal circumstances rear brakes usually last twice as long.
    How much you tow/haul and the terrain you drive in matters a lot.
    When you do replace the pads don't go cheap. Good pads last a lot longer and are cheaper in the long run.
  10. Nov 4, 2023 at 2:19 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Asking how long brakes last is impossible to answer each answer will be different .
    Also so many different variables one needs to account for as well.
    Then inspecting things does no good if you have no idea what your looking at.
    Find some local help to show you what your looking at.
    In this day almost every shop is struggling to just stay open.
  11. Nov 4, 2023 at 2:26 PM
    tacomonkey
    Do the calipers have a window to view the brake pads? I put my hand thought my rims and it feels like it does. What should I be looking for as far as thickness of the pad?
    TnShooter likes this.
  12. Nov 4, 2023 at 2:29 PM
    Bishop84
    Bishop84 Well-Known Member
    Pads are usually measured with millimeters even in the states if I recall.
    Minimum is 2mm, new is 13mm, usually 4mm or lower is discard.
    So 1/8th inch if you can figure that out.
  13. Nov 4, 2023 at 2:44 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I have 109,000 miles on the fronts with about about 4 mm of pad left. I have been checking them at oil change time.
  14. Nov 4, 2023 at 3:52 PM
    Brianz1001
    Brian
    too much to type
  15. Nov 4, 2023 at 4:58 PM
    XSplicer62
    Jefferson State
    After you remove the wheel, it's super easy to see pad thickness. :thumbsup:
  16. Nov 4, 2023 at 6:17 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’d stay away from that place. Or at least don’t let them do anything other than tire patching.
    It’s unlikely you need pads & rotors up front unless you’re very hard on them. The rears could possibly need adjusting. But they probably don’t know the specific procedure for the taco. Cleaning is nothing more than washing the dust off with brake cleaner.
    XSplicer62 likes this.
  17. Sep 30, 2024 at 4:01 PM
    Leafan
    Leafan Member
    2019 White Tacoma TRD
    Still going with my original brakes at 207000 Kms. Nuts, but downshifting seems to work.
    Pat Harrison likes this.
  18. Sep 30, 2024 at 5:58 PM
    dtaco10
    Dave
    Changed my front pads and rotors at about 122,000 miles. This week I looked at my rear shoes, sprayed the components down with a brake cleaner, adjusted them, and will continue on. The adjustment helped my parking/emergency brake and gave a little better feel to the braking. In no hurry but I'll look for a sale on brake shoes.
    Jimmyh likes this.
  19. Oct 1, 2024 at 1:21 PM
    Pat Harrison
    Pat Harrison Well-Known Member
    Patrick
    Lower Mainland B.C.
    15 Taco Dual Cab
    Coming
    I’m a down shifter too so my 2015 DCLB ( auto trans ) with a consistent gear load in bed of about 600 lbs is currently at 162,000k on my original brakes front and rear.
  20. Oct 1, 2024 at 1:32 PM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I still have about 4mm on the front pads on my '96. 118K miles. I think they are the original pads. I'll be replacing soon but am in no hurry.
    If yours are truly only 1 mm they're due for replacement now. Easy to check, though. Always a good idea to verify a shop's claim.
