How long do clutches last and cost?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluejays, Feb 27, 2009.
  1. Feb 27, 2009 at 4:15 PM
    bluejays
    bluejays [OP] Well-Known Member
    I was wondering how long clutches last. I know it depends on the driver, but on average, how long would you say? Also, how much does it cost to repair it? Thank you
  2. Feb 27, 2009 at 4:18 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
  3. Feb 27, 2009 at 4:25 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    my dads 86 yota replaced in 97 with about 130,000 miles
    my 98 taco just replaced november last year 126,000-127,000
    so about 10 years or 130,000 give or take
    like u said depends on the driver
  4. Feb 27, 2009 at 6:44 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    My 1994 had 146,XXX with the original clutch when I sold it. I had a Honda Civic with 178,XXX with the original clutch when I sold that as well.
  5. Feb 27, 2009 at 6:50 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    Just got rid of my ten year old Neon with the original clutch at around 132000 km (82000 miles). It was starting to wear out, but still drove comfortably enough.
  6. Feb 27, 2009 at 9:05 PM
    gdctaco
    gdctaco Well-Known Member
    georgetown, ont
    06 access cab 4x4 O/R
    rr diff mod in-cab 110
    my '06 xcab trd OR 4.0 is at 134000kms, and no sign of failing, with some towing and wheeling.
  7. Feb 27, 2009 at 9:19 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    It can vary...........it depends on driving conditions along with your driving habits.
  8. Feb 27, 2009 at 11:04 PM
    bluejays
    thanks. when the does come for repair, how much do they cost?
  9. Feb 28, 2009 at 7:08 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Try calling some dealers or reputable transmission shops in your area, that will give you the most accurate answer on a price. Different areas of the country may not be reflective of where you live.
  10. Feb 28, 2009 at 7:48 AM
    Brunes
    Brunes abides.
    Rotorhead
    Cosign- that's you best bet. You can also consider aftermarket parts if you have a specific application or you want some longer wear or whatever.
  11. Feb 28, 2009 at 8:07 AM
    BAT24
    BAT24 Well-Known Member
    Ohio
    TRD Rugged Trail
    TRD - CAI Sport Hood Sport Grille Sport Headlights OEM LED Tails Factory Roof Rack
    The clutch in my 96 Tacoma 2.7 4 x 4 lasted 185,000 miles, actually the pilot bearing started making noise so I replaced everything while it was out. I didnt thrash it to much and did a lot of highway driving though.
  12. Feb 28, 2009 at 8:09 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    when i had mine done it was around 1600 but i had new brakes and tierod ends put on at the same time
