How Long Do I Have?
Discussion in '1st Gen. Tacomas (1995-2004)' started by magic, Dec 8, 2011.
  1. Dec 8, 2011 at 10:08 AM
    magic
    magic [OP] Well-Known Member
    ok so i just put on a toytec 3" front strut spacer with procomp shocks on my 99 v6 and i used the stock coils.
    how long do i have until my coils (begin) to compress?
    oh fyi the truck came out of cali so the coils have no rust what so ever and are in great shape.
  2. Dec 8, 2011 at 10:13 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Probably years
  3. Dec 8, 2011 at 10:15 AM
    magic
    ok sounds good.... im thinking about next summer getting some ome coil either (880 or 881)
  4. Dec 8, 2011 at 10:15 AM
    magic
    some offroading(flexing) but not like rock crawling. abot 40 miles a day on highway. but next year it may get about 5 miles a day.
  5. Dec 8, 2011 at 7:45 PM
    magic
    any ideas?
  6. Dec 8, 2011 at 9:15 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    They are already compressing. But it will probably be years before noticing a big difference....assuming nothing breaks.
  7. Dec 9, 2011 at 10:05 AM
    magic
    well ya i mean im already starting to rub a little on the inside fender when turned at about 35 degress because im running 285/75's on a 3" lift. and i just dont want it to get worse. see what i mean?
  8. Dec 9, 2011 at 1:41 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    If you grind down the pinch weld it will stop most of the rubbing. But the 285s will still rub on the frame at full lock
  9. Dec 11, 2011 at 7:53 PM
    magic
    ha i guess we have a funny guy here
  10. Dec 11, 2011 at 7:54 PM
    magic
    ive got 3.75" backspacing so i dont rub my frame...
  11. Dec 11, 2011 at 7:57 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    You should be fine for a while, but having a 99, your coils are probably already pretty worn, so the spacers will make the coils take a shit a lot quicker.
  12. Dec 11, 2011 at 8:01 PM
    magic
    ya im considering ebaich on procomp shocks this coming summer... thoughts? fyi i would go with procomp cuz thats what i just put on about 2 months ago with the spacer lift
  13. Dec 11, 2011 at 8:02 PM
    TacoMX
    Jonathan
    Deltona, Florida
    Should work. Just get rid of the pro-crap shocks when you can. Run Bilstein 5100's.
    What do you have going on in the back?
  14. Dec 11, 2011 at 8:06 PM
    magic
    then i would be basically throwing away money cuz thats all new shocks and coils.... but in the rear ive got procomp 9000's with toytec 1.5" spacer. i plan to leave that for a while...... but one day get some 1.5" leafs
  15. Dec 11, 2011 at 8:09 PM
    TacoMX
    Jonathan
    Deltona, Florida
    its not throwing away money. I meant to keep the pro comp shocks till they wear out and replace them with bilsteins.
    And if by spacer you mean a block in the rear, then a 1.5'' leaf pack, or even an AAL would be a huge improvement.
    Icon makes a progressive 1.5'' AAL that is a lot cheaper than a whole new leaf pack if you are on a budget when it comes time to improve your suspension.
  16. Dec 11, 2011 at 8:17 PM
    magic
    oh hahaha my bad i thought u meant throw the procomp away but ya its a 1.5" block in the rear. but when i was deciding on my rear lift i went with a black because i was told that add a leafs are pretty difficult to install. and if they arent the right length then u need to take it to a shop so they can screw around with it so it will work just what i was told by toytec.... haha ya im on a limited amount of money for my truck because i go off to college next year and only got a 50% scholarship
  17. Dec 11, 2011 at 8:19 PM
    magic
    sorry spaces arent working^^^ so its like one big paragraph
  18. Dec 11, 2011 at 8:20 PM
    TacoMX
    Jonathan
    Deltona, Florida
    AAL's are pretty easy to do yourself. Almost same process as adding a block, because all the same stuff needs to be removed to do it.
    And I dont know why toytec would tell you that, because as long as the AAL is made for your truck (like the ones they sell). You will have no problems installing it yourself.
  19. Dec 11, 2011 at 8:22 PM
    magic
    sometimes toytec really pisses me off!!! now i waised 80 bucks with those blocks..... well atleast i can reuse my longer u bolts
  20. Dec 11, 2011 at 8:25 PM
    TacoMX
    Jonathan
    Deltona, Florida
    hey, its all a learning process.
