How long do/or should brakes lasts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deeznutz, May 18, 2011.
  1. May 18, 2011 at 2:32 PM
    deeznutz
    deeznutz [OP] Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    How long did your front brakes lasts? My truck only has 19,600 miles and the brakes are already starting to squeek. I'm thinking this isn't normal as I am easy on my brakes, meaning no sudden or hard stops. I would think this is considered wear and tear and isn't covered under warranty but squeeking at 19.6K miles just isn't normal.
  2. May 18, 2011 at 4:28 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Drive in reverse and apply the brakes while backing up, if there is shit stuck between the rotor and pads it might come out
  3. May 18, 2011 at 4:33 PM
    JAB1962
    JAB1962 Member
    DOVER DELAWARE
    2011 SPEEDWAY BLUE TACOMA SPORT DOUBLE CAB LB
    Sometimes when brake pads get hard they squeak. That doesnt mean they are bad. When you hear metal to metal scraping you have a problem. Just crawl under the truck and see how much pad is left.
  4. May 18, 2011 at 4:38 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    My factory Toyota pads on my '06 were changed out after 4 years and 78,000 miles and still had 25% left on the fronts and about 50% on the rears. I drive fairly agressive but I do have quite a long freeway commute which may or may not be stop/go for about 1/2 hour each way to work and back.
    Mine get a little squeaky when they are dusty, or I haven't sprayed them off in a while. Brake dust and regular dust builds up and causes a high pitch squeal once in a while, but a good spraydown at the coin-op car wash or with the garden hose under pressure usually takes care of the issue.
