How long do you Idle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Got2ryde, Nov 16, 2012.
  1. Nov 16, 2012 at 4:52 AM
    Got2ryde
    Got2ryde [OP] Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    I'm wondering how long you guys let your truck "warm up". How many seconds elapse from the time you fire up your truck to the time you start moving? How long does it take our trucks to build up oil pressure?
  2. Nov 16, 2012 at 5:03 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Start truck, immediately back out of garage, roll slowly in 1st gear down the 300 ft driveway, drive slowly down the 1/4 mile private drive to main road. Then its off and running. No idle warm up time at all. :cool:
  3. Nov 16, 2012 at 5:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    However long it takes my hand to go from ignition to the gear shifter. Maybe 1 second if I'm in a hurry and 2 seconds if I'm relaxed. :D ;)
  4. Nov 16, 2012 at 6:10 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Same, I don't let my truck warm up.
  5. Nov 16, 2012 at 6:11 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Maybe 10 seconds. 15-20 if you include backing out of the driveway.
  6. Nov 16, 2012 at 6:12 AM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    I try to let it warm up till the heat comes on. Gotta let that oil warm up! But sometimes I don't lol
  7. Nov 16, 2012 at 6:13 AM
    ssmith29440
    ssmith29440 Well-Known Member
    2012 Tacoma TxPro Trd
    I usually wait abot two or three min. It takes that long to put phone in charge cradle and decide what im going to tune into on xm. Then im off and going.
  8. Nov 16, 2012 at 6:29 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I wait for ignition timing to drop and come back up, which tends to be just a few seconds after the fan clutch comes out of lockup and the fan stops roaring. 30 seconds to a minute typically.
    I don't wait for oil to warm up. I learned from my Civic's oil pressure gauge that it takes wayyy longer than coolant (you can tell by idle oil pressure; that car would have warm coolant in 5 minutes and warm oil in 45 minutes). When cold the idle pressure is determined by the relief valve anyways so it's gonna be at the system's maximum pressure within about 2 seconds of starting the engine, provided your filter's anti-drainback valve is working properly. As long as it's warm enough to flow to the rod bearings, and you're not revving it so hard it starves, it's fine. Still I use 0w30 to help that situation tho.
  9. Nov 16, 2012 at 6:34 AM
    custom90gt
    custom90gt Well-Known Member
    Colorado
    05 SWB TRD Off Road
    Idling is a double edged sword:
    Don't let your oil warm up long enough and give it a decent amount of gas and you're hurting your engine.
    Let your truck idle for too long and you're dumping fuel into the oil and causing bearing damage...
    I prefer to let mine warm up for a minute in the driveway and then start driving, but never let it get above 1500 rpms. Thankfully I live near a long road that not many people drive on so I can take my time getting up to speed.
  10. Nov 16, 2012 at 6:44 AM
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    In the summer, not at all. In the winter, until the frost is gone and I can see where Im going.
  11. Nov 16, 2012 at 7:26 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    i watch the water temp on my scangauge, usually let it hit 100, take it easy on it till about 145-150. by take it easy i mean i don't like to get it over 2k rpm.
    I always let it warm up, unless I am in such a hurry that I can't wait, i really take it easy, 1500 rpm or under for the first 10 minutes. I feel like its hell on the engine jumping in and going for it
  12. Nov 16, 2012 at 7:30 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    You'd be surprised how much longer it takes for the oil to warm even after the coolant is warmed up. It takes forever, so I do what you do. Once I see the coolant gauge move, I move.
  13. Nov 16, 2012 at 7:30 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    However long it takes me to put on my seatbelt, put it into first, and disengage the parking brake.
    In the winter, I turn the truck on, scrape the windows, and go. Don't really wait for too long.
  14. Nov 16, 2012 at 7:39 AM
    badger
    badger Well-Known Member
    07 SR5
    I do pretty much exactly this. 100 degrees on the Scangauge but I take it easy till the temp hits 180. I don't just do that for the engine, but things like the transmission need a little time to reach temp. From what I have gathered over many years is that the middle ground is the best place to be. There are downsides to very long idling warmups and downsides to roaring off on a cold engine. The sooner the engine temp normalizes without straining it, the better. The best way to do that is to get moving easy as soon as you can. Like most things a little "common" sense goes a long way.
  15. Nov 16, 2012 at 7:49 AM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Sometimes I let it warm up, sometimes I don't have time, but I keep my truck in our basement so it never gets below about 60. That said, I have to pull onto the main road about a half of a mile from my house, it's in a blind curve so I have to stomp on it pretty hard sometimes. I have to reach into the 3-4k range pretty regularly, I've got 53k on my 07 with no issues.
  16. Nov 16, 2012 at 8:00 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    In the colder months I try to let it warm up for 2-3 minutes, a little more if very cold outside.
  17. Nov 16, 2012 at 8:09 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Usually remote start in the winter, otherwise long enough to take off the parking brake and clear the windshield.
  18. Nov 16, 2012 at 8:41 AM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    I occasionally have my Taco in gear before all the gauge lights are on...probably not a good thing but hey...nothing like being in a rush
  19. Nov 16, 2012 at 9:23 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this..to a tee.
  20. Nov 16, 2012 at 9:36 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Until RPM's drop to 1000.
