How Long Does It Take for Your Heater to Blow Warm/Hot Air?
Discussion in 'Performance and Tuning' started by jlleiber, Nov 14, 2012.
  1. Nov 14, 2012 at 6:41 AM
    jlleiber
    jlleiber [OP] Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    Sorry, if I put this is the wrong section, but it seemed like a "performance" issue I guess...
    Now that it is getting colder, I have noticed that my heater takes a long time to blow warm air (if at all). I have a 15 minute drive to work and warm air only comes out if I am accelerating. And when I come to a stop sign and idle, the air actually gets cold. The engine temp gets to midway just a few minutes after driving, but I can't seem to get warm air to blow out. I have the "recirculate" button pressed, which helps some, but that kicks itself off for some reason.
    Anyone experience anything like this or have any suggestions to make my Taco into a furnace again?
  2. Nov 14, 2012 at 11:57 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Right now in Texas during the nights it gets around 50, not much but just stating this for comparison reasons. Anyways at night it takes about 15 mins or to really feel "warm and cozy."
    My solution: I was thinking about getting a Remote Start for the truck so I can pre-heat the cabin before I climb in. Going to look into it this weekend.
  3. Nov 14, 2012 at 11:57 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Bad thermostat? Sounds like its stuck full on. If its super cold where you are, like below 0 F... sometimes it helps to block off your grill a bit.
    Also check your coolant level. My truck gets warm within about 2-3 minutes and hot within about 5
  4. Nov 14, 2012 at 11:59 AM
    Yamaha Dave
    ^ Just changed it last week, no change in status.
  5. Nov 14, 2012 at 12:00 PM
    brian
    Elizabeth City, NC
    You've never put tap water into your radiator before have you? That can also clog the system, particularly the heater core.
    No water leaks on the floorboards? All dry?
  6. Nov 14, 2012 at 12:09 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    if the temp gauge is normal, don't even consider anything other than heater core or heater control issues.
  7. Nov 14, 2012 at 12:57 PM
    jlleiber
    Justin
    Indiana
    can you expand on that a little bit?
  8. Nov 14, 2012 at 4:41 PM
    Leggo
    Newton,Ma.
    Sure, only pointing out that mid range temp readings indicate proper engine temp. Also could indicate enough coolant.
    I would look at the temp controller (IE: heater control valve or what ever it has in place). or the vents themselves being blocked somehow, also is the fan blowing properly?
    is it possible you are still under warranty?
  9. Nov 14, 2012 at 4:46 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Install a electric radiator fan.
  10. Nov 14, 2012 at 6:09 PM
    brian
    Elizabeth City, NC
    I'm sorry but what the heck would that do for him?
  11. Nov 14, 2012 at 7:29 PM
    Leggo
    Newton,Ma.
    keep him warm in the garage for a little while:D
  12. Nov 16, 2012 at 3:13 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Thursday morning it was 27 degrees out and before I started the truck the coolant temp read 35. I turned the dial to full heat.
    Idled for one minute before driving, temp passed 80 and climbing.
    First stop sign, three quarters of a mile away, 130F and climbing, just starting to get heated air.
    Next stop sign was three miles down the road, 186F, highest temp it gets to. Hot air started to cook me out of the truck and I had to turn it down to halfway up the dial.
    Having a partial grill block really helps on those cold mornings.
  13. Nov 16, 2012 at 4:32 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    An electric fan will only come on after the truck has reached operating engine temperatures. So the car will warm up faster on startup.
    although the temps in Phoenix are not that cold, this is how my truck acts too. My heater is plenty warm after the third mile. I dont turn them on untill then because id rather have no air than cold air blowing at my feet.
  14. Nov 16, 2012 at 11:05 AM
    Leggo
    Newton,Ma.
    while that is true to speed up the time needed to get hot, Blowing hot(or not) air is a different issue entirely. his engine is reaching normal temp but he has no hot air blowing inside. Correct?
  15. Nov 16, 2012 at 12:01 PM
    jlleiber
    Justin
    Indiana
    You got it. The engine itself is warmed up by the time I get a mile down the road. Hot air doesn't blow unless I'm giving her a decent amount of gas. And to answer your question from before, the fan is blowing air properly
  16. Nov 16, 2012 at 2:47 PM
    Leggo
    Newton,Ma.
    This may sound strange, but I have seen the impeller on the waterpump fail before. If you suggest revving the engine to get some heat to flow from the core, I would think a flow problem exists. Revving the engine only speeds up the water pump. Are you still under warranty?
  17. Nov 16, 2012 at 3:44 PM
    ElkHunter
    ElkHunter Member
    Mark
    Oregon City, Oregon
    2012 TacomaAccess Cab SR5 4x4
    Are the blend doors actuated by vacuum? If so, that could explain the fact that more RPMs gives you more heat... Maybe a cracked vacuum line/regulator???
    More vacuum, more heat because the blend door is being held open. At least, it sounds that way to me...
  18. Nov 16, 2012 at 4:08 PM
    jlleiber
    Justin
    Indiana
    Nope, not under warranty
  19. Nov 16, 2012 at 4:11 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Even when parked outside in the cold ... mine seems to warms up fast.
  20. Nov 16, 2012 at 4:18 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Mine warms up within about 2-3 miles. Actually gets really warm, almost hot within 10 min or so.
