How long does your battery last, without charging, while running a fridge?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Jul 1, 2019.
  1. Jul 2, 2019 at 7:05 AM
    #41
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    So, perhaps I might retain propane on this truck. I actually do like the idea, I just don’t like the amount of bed space, which is at a premium, that it takes up.
    Supposing I were to install an ASME lpg tank. What do I need to look out for? Are these type of tanks something that I can refill at a gas station that sells propane by the gallon? What are the certification details?
  2. Jul 2, 2019 at 7:22 AM
    #42
    Rujack
  3. Jul 2, 2019 at 7:35 AM
    #43
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Yeah I just recharge my spare AGM battery with the DC solar charger and run all external electronics off the spare battery.
    Solar is great for recharging these batteries. I’ve also got a small gas generator, if needed which will run the VTanks 14.7 battery charger (115V) in case there’s no sunlight.
  4. Jul 2, 2019 at 7:38 AM
    #44
    Rujack
    Which solar charger?
  5. Jul 2, 2019 at 8:02 AM
    #45
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Not sure if this is overkill for you, or something you would consider... This is in my truck 100% of the time, but obviously I've got a "canopy".
    It's a simple plywood box with a house battery (x2), battery isolator, fuse panel, battery charger, and battery switch. And if you can't tell from the pic, my fridge is huge (75L dual zone) and I can easily run it a couple days @ 32 degrees without putting out my solar or running my truck, in 70-90 degree weather. In fact, I can't remember the last time I've charged the batteries with my truck. I usually just plug the charger in the day before I leave to top them off, and also make sure my fridge is cold before I leave.
    It may look like a lot of work, but it just took some time. Now that it's in I've added 12v outlets and usb ports for running camp lights and charging phones. It's been great. Obviously you could probably get my with something smaller, unless you want a LOT of storage. We often just use half of the fridge, using the other half as dry storage (we can control the temps separately or just shut off one side completely).
    Rujack[OP] likes this.
  6. Jul 2, 2019 at 8:11 AM
    #46
    Grossomotto
    2017 4WDV6LB6MT
    #46
    YF_Ryan likes this.
  7. Jul 2, 2019 at 8:12 AM
    #47
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I went there once. I insisted on
    Driving the Volvo wagon
  8. Jul 2, 2019 at 8:27 AM
    #48
    YF_Ryan
    Kent, WA
    I bet the Yeti 1000 Lithium would make your life easy. That and an ARB 50Qt and you'd be golden. Could add a solar panel at some point to help out.
    When all was said and done, my system was about the same cost as the Yeti 1000, but the Yeti has about 20% more usable capacity than my 2 batteries combined since it is lithium. And you could easily move the Yeti around, too. Use one of them REI coupons on it and you'd save a bundle, too!
