How long does your oil pressure light remain on during a cold start?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MGRS, Apr 24, 2010.
  1. Apr 24, 2010 at 6:10 PM
    MGRS
    MGRS [OP] Well-Known Member
    08 6spd TRD 4x4
    What is considered normal with 5w30, starting cold at ~60F.
    My light always went out instantly as the motor was cranked. Now, after the most recent change (Mobil-1 5w30 and M-102 filter), it remains on for almost a second after the motor starts. What could be causing this change? Bad check valve on the filter?
    Thanks.
  2. Apr 24, 2010 at 10:44 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    Sounds like a bad ADBV on the filter. Change it out cold since it is already leaking back into the engine.
  3. Apr 24, 2010 at 11:38 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Mine goes out so fast I have never seen it!
  4. Apr 24, 2010 at 11:43 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Yeah, bad flap on filter.
  5. Apr 25, 2010 at 5:48 AM
    MGRS
    08 6spd TRD 4x4
    Vicinity 60F.
    Will change out the filter for a Wix 1516 I just picked up. It is a larger filter and looks like it has a coil spring instead of a flat spring in there. Never seen that before on a filter.
  6. Apr 25, 2010 at 6:18 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Off topic. I've been using the [FONT=verdana,arial,helvetica][SIZE=-1]Wix 51348. Would the Wix 1516 work for me ? I have a 2.7 - she says bigger is better so just wondering.[/SIZE][/FONT]:D
  7. Apr 25, 2010 at 1:57 PM
    MGRS
    08 6spd TRD 4x4
    Changed the filter out today, and that was it. No oil spilled. Bad anti-drain valve. Oil pressure light is back to normal after the filter switch. I will be sticking with the Napa/Wix 1516 from now on.
    Next topic- how much will starting without any oil in the filter damage the motor?
  8. Apr 25, 2010 at 2:44 PM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
  9. Apr 25, 2010 at 2:54 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    For the small length of time you were doing this, I would believe very little. I am a firm believer in WIX and have used them for years in all my cars/trucks.
  10. Apr 25, 2010 at 9:28 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    The spring you see is for the bypass function should the filter get clogged. Has nothing to do with the ADBV which is the rubber piece you see through the outer holes in the baseplate.
    Regardless, glad to hear the WIX fixed your issue. The Mobil 1 filters while overpriced, are generally good filters. Considering the millions of filters made everyday, the occasional turd will get through.
  11. Apr 26, 2010 at 5:44 AM
    dalsmthme
    Ithaca, NY
    Just out of curiosity, why not use Toyota filters?
