How Long is OK for no front alignment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by double_b, Jan 2, 2013.
  1. Jan 2, 2013 at 7:09 PM
    double_b
    double_b [OP] Well-Known Member
    Red Lion, PA
    '14 DCab Tacoma TRD Off Road
    I will be getting the rear TSB done in about two weeks. Parts supposed to be in around Jan 11. In the meantime I am getting Billies put on in the front and set to 1.75. I am also getting new Duratracs 265/75/16 put on. I am thinking about getting the Billies and tires on next week and then hoping the dealer doesn't have a problem doing the required front end alignment with the non-stock shocks up front.
    My question is if it's about two weeks from shock and tire install am I asking for trouble??
  2. Jan 2, 2013 at 7:13 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    It's more about how much you'll drive it rather than the time. I wouldn't drive it more than a couple of miles if I planned on keeping the tires.
  3. Jan 2, 2013 at 7:14 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Depends on how much you drive in 2 weeks...I wouldn't go on long highway trips without an alignment but city driving to work and back I would be ok with it but that's just me
  4. Jan 2, 2013 at 7:22 PM
    Haslefre
    Haslefre Not Really Here
    Brady
    Puget Sound
    09 Offroad 4x4.
    IronMan4x4 Foam Cell Pro Fronts, IronMan 2" rear leaf pack. Relentless 1/4" steel skid plate. Weathertech Digital fit front floor liners. BAMF Sliders with kickout. HomerTaco Satoshi grill.
    I would recommend getting the alignment done after the billies and tires. Find a local alignment shop.
    Toyota won't do a front end alignment when they are only working on the rear. They will probably make you pay for it at the dealer and charge you more than you will find outside of the dealer.
  5. Jan 2, 2013 at 7:27 PM
    06sr5prerunner
    06sr5prerunner DILIGAF
    luis
    midland tx
    2006 sr5 prerunner
    bhlm paint wheels duplicolor plasti dip white grill. billies 5100. bf goodrich at 285's 75 16 black valence led corner lights expedition bed rack by anb fabrication spidertrax wheel spacers rotopax fuel tanks 4gal mounted on bed rack quickfist mounts for shovel. ddm hid kit 35watt 6000k hi/low beam
    i had to drive mine for about 800 miles with a bad alignment :/ havent seen any problems on the taco due to that but i guess ill find out eventually. proabably fucked my tires a little though same thing as you put billies upfront 1.75
  6. Jan 2, 2013 at 11:47 PM
    Gincoma
    Salt Lake City UT
    Its required in the TSB to do an alignment and will be free if under warranty which I'm assuming is
  7. Jan 3, 2013 at 12:10 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2010DCSB4X4TRDORMGM
    See build thread.
    Yeah when I had my rear TSB done they did the alignment on all four.
  8. Jan 3, 2013 at 2:18 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I made that mistake...drove about a month (1000 miles) without aligning, and I wore the inner half of my front BFG's to home-made drag slicks.
    Get it done ASAP.
  9. Jan 3, 2013 at 2:20 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Just keep an eye on the tire wear.
  10. Jan 3, 2013 at 7:11 AM
    double_b
    Red Lion, PA
    OK thanks everyone. I am going to try and plan accordingly so that I minimize driving w/o the alignment as much as I can. I don't have to get the new tires at the same time that was just convenience...I can go back and get the tires on after the TSB and shock work is done. I don't care if I tear up the POS Rugged Fails.
    I am considering calling the dealer and inquire about what they would charge me to install the Billies at the same time but I know that will be outrageous labor cost I am sure. Plus I don't want them to think I am trying to get a "free" lift by getting them to do the TSB...not that they would but I don't want the hassle.
