How long on average before clutch goes out?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Powered Parachute, Aug 4, 2020.
  1. Aug 4, 2020 at 8:05 AM
    Powered Parachute
    Powered Parachute [OP] Well-Known Member
    Olympic Peninsula Washington State
    2014 V6 4L Manual DCSB TRD Sport
    Fab Fours rear bumper. Bestop. Uni Filter Clamp-On Breather. Scratched up and dinged mod.
    Keep hearing the haters say this about Manuals as a draw back needing clutch replacements. What's the facts on Toyota Tacoma clutch longevity?
  2. Aug 4, 2020 at 8:14 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    There are too many variables to accurately answer that question. Some people may go 100000 miles or more some only 50000. It depends on the driver, are they mr. shifter , shifting and down shifting all the time, city or highway driving? Does the person tow or haul heavy loads. Do you drive in heavy city traffic or hilly places like San Francisco? There are many more variables too. You’ll get a million answers depending on each person’s personal experience.
  3. Aug 4, 2020 at 8:17 AM
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Totally depends on the driver, I pulled the tray in mine for a squick at 100k and it was at 50%
    A friend with gen1 went 300k. Another who always hot roded got 80k
  4. Aug 4, 2020 at 11:54 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ 100 %
  5. Aug 4, 2020 at 11:58 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Heck, some people clutch might last 300K+ miles. I don't buy that they can only last 100K.
  6. Aug 4, 2020 at 12:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Exactly. There is no "average" amount of mileage before a clutch goes out. There are way too many variables to predict that.
    EdgemanVA likes this.
  7. Aug 4, 2020 at 12:06 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    depends if your dumping that bitch at every red light or not.
    Chako and 12TRDTacoma like this.
  8. Aug 4, 2020 at 12:07 PM
    su.b.rat
    su.b.rat broken truck
    agreed. OE clutch is not super strong or grippy like some aftermarket units, but if you treat it right easily over 150k and likely a lot higher.
    my OE clutch was perfectly good at 64k but i did a performance upgrade anyway just for a thicker more solid engagement. but i didn't need it.
    EdgemanVA[QUOTED] likes this.
  9. Aug 4, 2020 at 12:08 PM
    eon_blue
    Azusa, CA
    There are guys with 1st gens on here that still have the factory clutch going strong with well over 300k miles. If you do mostly highway driving you can get a ton of life out of a clutch. Mostly city driving I'd expect ~100 - 150k. If you wheel a lot then less than that.
    All assuming you know how to drive a manual, I mean you could wear a clutch out in 60 seconds if you wanted to.
    Chako, Das it mang and 12TRDTacoma like this.
  10. Aug 4, 2020 at 12:08 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I'm at 110K, so far so good.
  11. Aug 4, 2020 at 12:12 PM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    I have a 95 with over 500k and and 02 with 461K as of the ride to work this morning, neither has ever had a clutch changed. Its all about how you drive it. I don't baby a truck but i don't hot rod them either.
  12. Aug 4, 2020 at 12:16 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I don’t really see this as a drawback anyway. A clutch is really easy to change. It’s really not much harder than changing brake pads.
  13. Aug 4, 2020 at 12:50 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I never had a problem with my clutch in my 1st gen. owned it 17 yrs. I also towed in the mountains for hunting trips, dirt bikes and snowmobiles.
  14. Aug 4, 2020 at 12:57 PM
    Iceberg
    Iceberg Well-Known Member
    Josh
    Alabama
    2008 DCSB TRD OR
    Mine is original clutch. 2008 double cab with 144,000. It still seems to be on good shape.
  15. Aug 4, 2020 at 1:00 PM
    Sailor_Nick
    Sailor_Nick Well-Known Member
    Nick
    Massachusetts
    2011 Tacoma TRD-OR DCSB 6-speed
    Bilstein 5100's, 32" tires
    I bought my 2011 with 273k miles and I replaced the clutch at that time only because of a squeaky throwout bearing. To my surprise, the clutch was original and trans had never even been separated from the engine. The clutch still had tons of life left in it. I replaced with new just for peace of mind. They will last a long time if driven right.
  16. Aug 4, 2020 at 3:44 PM
    Silverstreak2112
    Silverstreak2112 New Member
    Ted
    Harrisburg
    6spd-SS
    I’m @ 239k and counting on the clutch. Bought it from dealer 12 yrs ago with 75k on it. I think the key is that I never let anyone else drive my truck..
    My dilemma now is getting it inspected in PA. It’s an ‘05 4.0 Acc 4X4 with a new frame in 2016 but I got the dreaded P0306 (cyl 6 misfire) due to slowly dying head gasket. As soon as CEL stays off long enough to reset I/M readiness monitors, I'll get new stickers on it.
    Silverstreak TM
  17. Aug 4, 2020 at 7:41 PM
    TacoTuesday1
    FL
    Clutch discs are cheap.
    I pulled one out at 140k miles that had 7-7.4mm thickness left.
    New is about 8mm, worn is probably 2mm or whatever the rivets are at
    Some people actually know how to drive, understand how parts work and how to use them correctly, etc.
    most don't, but claim they do
    ie calling it "smooth" and not excessive slippage, etc
    EdgemanVA and smithlaketaco like this.
  18. Aug 5, 2020 at 8:52 AM
    Mad4268
    Mad4268 Active Member
    Erie, PA
    06 Blue Tacoma TRD-OR 6-Spd STD
    '06 with 165,000 miles and still original clutch.
  19. Aug 5, 2020 at 8:54 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I've got 152,000 on mine. Second owner of the truck. I probably have put a lot more wear on it than she did. But it still works great. Like others have said, too many variables to account for.
