How long should an OEM battery last?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Still Stoked, Apr 2, 2019.
  1. Jan 24, 2021 at 7:23 AM
    #101
    Tanmann
    Tanmann Well-Known Member
    Richmond, VA
    2017 OR Access Cab
    Cardboard spoiler and skateboard wheelz
    I’m at 77,300 miles on my 2017 still on the original oem battery. ‍♂️ Must have gotten lucky
  2. Jan 24, 2021 at 9:09 AM
    #102
    Tacllama
    Tacllama Well-Known Member
    2017 Blue SR5 DCLB 4x4
    Bilstein 5100's OME 885 springs for 1.5" lift in the front 3 leaf AAL for 1.75" lift in the rear
    53,000 miles and ~ 3.5 years on my ‘17 original OEM battery. One thing to consider about the topic of this thread is not just where people live but where they live in relation to work, stores where they run errands, etc. If you’re only driving a few minutes on average to get to your destination, my experience has been your battery won’t be getting a full charge from the alternator after each start up which can lead to premature issues with said battery.
    Brie, rev25sharp and Markcal like this.
  3. Jan 24, 2021 at 9:23 AM
    #103
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you saved your receipt you can turn it in to Toyota for reimbursement.
  4. Jan 24, 2021 at 11:18 AM
    #104
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I would also like to see some info on this with some real facts. The main reason the batteries are exchange is to keep the lead in the US! There are only like 3 or 4 manufactures of flood cell batteries in the US and dozens of rebranded sellers. Now that does not mean it is recycled here that is where the problem lies it comes back to us but in the mean time is is killing tens of thousands of people in poor countries. 99% of the lead is reusable.
  5. Jan 24, 2021 at 1:05 PM
    #105
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Factory batteries are usually good around 4 years. My last car (crappy Chrysler 300) died after only 3. I have had a few go 5 years but then I change it as I dont want to push it and get stuck somewhere.
  6. Jan 24, 2021 at 1:05 PM
    #106
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    All i can say is these newer batteries toyota is using must be some sort of remanufactured cheap crap. I never had any truck battery fail in the past until around 7-8 years, and i did several trips to quebec in the dead of winter. Those batteries would sit out in the cold at -30 to -40 for close to a week.
    We had one guy with a new ford 150 that his battery froze so bad we had to sit it in the motel bathroom sink to warm it up enough for it to come back.
  7. Jan 24, 2021 at 1:11 PM
    #107
    Breakfast_taCOs
    Breakfast_taCOs Active Member
    TBD 3 Gen Tacoma OR Manual
    Saw this at the local dealership; very helpful guide
    bagleboy, TheAredub, Brie and 2 others like this.
  8. Jan 24, 2021 at 1:46 PM
    #108
    Sungod
    Sungod Well-Known Member
    St Augustine
    Yeah, but mileage isn't one of the factors so why do post it? If I said my battery lasted 10K, what would it matter? I could drive 2k a year or I could drive 10K a year. The mileage means nothing in terms of battery life.
  9. Jan 24, 2021 at 2:05 PM
    #109
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    My OEM battery lasted almost 5yrs. I replaced it 3-4 months ago while still in service, never failed to start, but the cells were getting weaker (via-monthly hydrometer test).
    I replaced it with a Walmart 2yr warranty with the same ccA capacity as factory.
    Moreover, I also put the new one on a trickle charge for a day and a half before putting it into service and expect to get 5yrs out (with maintenance) of it also.
  10. Jan 25, 2021 at 3:02 PM
    #110
    18trdsport
    18trdsport Well-Known Member
    Bay Area, CA
    2018 TRD Sport ACLB MT
    Because it tells you how often the vehicle was used. In my case, average 3.7k miles per year, the truck was hardly used. It sat for 2 or more days at a time quite frequently. For someone that puts 20k miles per year, they start that vehicle almost every day and got more use out of that battery then I did mine.
  11. Jan 25, 2021 at 3:18 PM
    #111
    The hammer
    Mileage has little or no bearing on battery life. Non, nada.
    If it did, battery warranty would be based on mileage and or months just like engine/drivetrain and such.
    The battery is meant to be charged (re-used) up to its stated battery life (warranty) and if it fails before the stated period, it is usually replaced on a pro-rated basis.
    Hope that helps
    Bleep100 and Sungod like this.
  12. Jan 25, 2021 at 4:18 PM
    #112
    foxtrapper
    foxtrapper Well-Known Member
    2017 went dead in 2020. So three years!
  13. Jan 25, 2021 at 4:51 PM
    #113
    eclane
    eclane Well-Known Member
    2020 Black TRD OR DCSB
    Nice. I was going to say 4-5 years and your map falls into my personal experience in NJ.
  14. Jan 25, 2021 at 5:07 PM
    #114
    D500
    D500 Well-Known Member
    David
    SE Georgia
    I bought a 2013 Highlander new in January of 2013. When I traded for the Tacoma in November of 2020, it had the original battery and 137K miles. I'm in SE Georgia, and it gets warmish here about 6 months a year.
  15. Jan 25, 2021 at 10:09 PM
    #115
    18trdsport
    Bay Area, CA
    Not really helpful. I was hoping if someone would explain why same OEM battery fails in one year versus 3 year or 5 years, etc. Basically, why it fails before its stated period. I agree. The battery doesn't rack up mileage so mileage is not a direct cause. But are there indirect causes?
  16. Jan 26, 2021 at 6:42 AM
    #116
    zoo truck
    None
    Just get the largest capacity battery you can fit in the truck, and it'll last longer.
  17. Jan 26, 2021 at 7:01 AM
    #117
    The hammer
    largest capacity battery won't do well (live as long) in hot climate operating conditions. They perform better in very cold climate. Thus the name die hard?
    The main reason a battery fails prematurely is poor maintenance. When a battery is made, it is deep charged for 18-32 hrs depending on the type battery.
    That is the last time a battery will ever see a deep charging cycle again. Unless of course it falls into the hands of a gear-head like me.
    Things that will shorten battery life:
    Bouncing it around
    Heat
    Jolt charging (start/stop)
    Improper electrolyte levels
    Dirty/corroded terminals
    Things that will help battery life
    A steady work platform
    Moderate weather
    proper electrolyte maintenance levels
    deep charging cycles (or regular/occasional long trickle charging)
    Clean terminals (sealing helps to keep terminals clean)
    Hope that helps
    bobrown14 and Brie like this.
  18. Jan 26, 2021 at 7:12 AM
    #118
    zoo truck
    None
    I've found that buying deep cycle batteries at walmart for my boat last longer than those sold at auto part stores. I still have 2 of them on my shelve now from 2015 that will go back in the boat this spring for another season.
  19. Jan 26, 2021 at 7:55 AM
    #119
    Big Kev
    Big Kev Well-Known Member
    Kevin
    Colorado
    16 TRD Sport
    My 16 bought in November of 15 is still on the original battery. 92,000 on my odometer and live in a place we get winter.
  20. Mar 23, 2021 at 1:55 PM
    #120
    YourActualName
    YourActualName Well-Known Member
    NH
    2015 Black Tacoma Limited DCLB
    Magnuson SC, +
    Update, I killed the battery early pandemic by leaving the bed lights on. Went with a new OEM since it was about time to replace it.
