How long should an OEM battery last?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Still Stoked, Apr 2, 2019.
  1. May 5, 2021 at 7:49 AM
    #141
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Mine lasted 4 years 85,000 miles
  2. May 5, 2021 at 7:54 AM
    #142
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    My OEM battery is still holding up after 2 years / 18k miles. I don’t have any issues with the current battery, however I’m going off to college in the fall so I might as well replace it this summer with one of the Optima Yellow or Odyssey batteries.
    shakerhood likes this.
  3. May 5, 2021 at 8:27 AM
    #143
    Chicken_Taco
    Chicken_Taco Well-Known Member
    Comfortably numb on the Darkside of the moon
    2019 Midnight Black Tacoma TRD Sport
    Working on it ...
    My wife’s 2019 Camry (bought new November 2018) battery went south at about 28,000 miles. Got about 2 1/4 years out of it. Covered by warranty.
    My 2019 Tacoma (purchased new December 28, 2019) currently is about to hit the 29k Mark. Battery still seems to be A-Ok.
  4. Dec 28, 2024 at 11:17 AM
    #144
    N3FOLMike
    N3FOLMike Well-Known Member
    2021 Tacoma TRD OffRoad
    My 2021 is at 30K miles and according to the last diagnostics, my battery has about 70% life left. It is almost a 4 year battery, so I might just replace it this weekend. I’ve been thinking about this for a few months now.
  5. Dec 28, 2024 at 11:23 AM
    #145
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I think that is smart. To me, getting stuck isn't worth squeaking another few or two months (maybe a dollar's worth?) out of it. Since the Tacoma and many other newish vehicles will not even attempt to crank under a certain voltage, there is little to no warning.
    Given how small, powerful, long lasting and cheap the jump pack are,, there isn't much of reason not to have one. Especially isolating your vehicle from problems when helping others.
    petethemeat and 06Tacooo like this.
  6. Dec 28, 2024 at 8:37 PM
    #146
    akimmel
    akimmel Well-Known Member
    Alex
    2019 TRD OR DCSB 6MT
    Just pulled the original out of my 2019 at close to 60k. It was starting to sound weak on startup the longer I left it and the colder it was. I snagged an Odyssey from napa with their holiday coupon. I had to flex the factory tiedown a bit to make it work even though I stayed with a 24F, it's a tiny bit taller. I'm planning on buying some stainless j-hooks and making a simple aluminum tiedown to replace it.
    06Tacooo likes this.
  7. Dec 28, 2024 at 9:05 PM
    #147
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Batteries that live in colder climates will last longer but won’t put out as many amps. Also if you discharge a starting battery it shortens it’s life. I live in Utah and my average wet cell lead acid last about 5-6 years. I do check the water level every oil change. We have temps from 20F to 100F.
  8. Dec 29, 2024 at 5:37 AM
    #148
    Chicken_Taco
    Working on it ...
    I bough my truck new 12/28/19. I figured it was a 5 year battery and was just going to change BEFORE it decide to die on me. Figured I would wait until after Christmas to do it. Last week we had very cold temps on Weds I went out to go to work it started but seemed funny. I below it off. Thursday morning it was off. By Friday I was lucky to get it started. So while at work I got a new Napa battery and replaced it. Now all is good once again.
    Even though the original battery was reading 12.4 volts on the meter, its cold cracking amps seemed to have left it. 5 years was a good run
  9. Jan 7, 2025 at 7:25 PM
    #149
    akimmel
    Alex
    I got a better tiedown knocked out after work today. I went with stainless j-hooks from Powertrays and used a 9" piece of 1.5"x0.25" aluminum flat bar. No more wiggly battery for this taco, it is locked down.
  10. Jan 7, 2025 at 8:10 PM
    #150
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Nice work but OEM works just fine for me.
    Same as battery type, don't need no odyssey.
    Chew likes this.
  11. Jan 8, 2025 at 11:12 AM
    #151
    Pwrhouse7mm
    Pwrhouse7mm Member
    2017 Tacoma TRD 4x4
    I bought my 2017 in August and battery only lasted a couple weeks before it went out. When I changed it it was the original battery from 2017. Lasted roughly 7 years.
  12. Jan 8, 2025 at 8:10 PM
    #152
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Did you know That the H6 Battery is better and fits?
    have been running it for a few year now, its shorter but i just added a spacer on the bottom.
