How long to install/remove Wet Okole seat covers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DavidS, Apr 7, 2012.
  1. Apr 7, 2012 at 11:41 AM
    DavidS
    DavidS [OP] Well-Known Member
    Dave
    Pacific Northwest
    2012 Tacoma TRD Sport
    I do a lot of mountain biking here in the PNW and about half the year I'm covered in mud after riding. I just got a new Tacoma and am shopping for some seat covers that can be quickly removed/installed to wash the mud off. How long does it take to intall a set of Wet Okoles? They sure look great, but guess they are not too easy to remove.
    Alternatively, does anyone have a recommendation for some cheap plastic ones that go on and off super fast and can be stuffed in the rear storage bins when not in use. I need to take things beyond the hefty bags I now use.
  2. Apr 7, 2012 at 12:58 PM
    sytfu510
    sytfu510 INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
    Install isn't too bad, there's 3 straps that go under the seat. The top and bottom are separate pieces. The back is easy to remove has 2 clips that hook onto the bottom, the bottom section may be more tricky if you tucked the cover into the panels.
  3. Apr 7, 2012 at 5:06 PM
    DavidS
    Dave
    Pacific Northwest
    Are we talking about 10 seconds or 10 minutes? Thanks,
  4. Apr 7, 2012 at 5:13 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I took my sweet time and I had front and rear done in about 1.5 hours
  5. Apr 7, 2012 at 5:57 PM
    Larry
    Larry CARL
    CARL
    I've used bath towels on the seats since buying my truck new in July 2010...install & remove in seconds. I keep a few extras to cover the seat back when necessary.
    Removed, seats look factory new.
  6. Apr 7, 2012 at 9:51 PM
    DavidS
    Dave
    Pacific Northwest
    OK, thanks... I love the look, but that is about 1 hour 29 minutes and 50 seconds too long for me.;)
  7. Apr 7, 2012 at 10:33 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    I got Wet Okole seat covers and while they are great, they're definitely not the type of covers you take on and off frequently to wash. That would be a major PITA. I took both front seats out to install more easily and the whole process probably took 1.5 hrs. Your probably better off using towels or garbage bags for seat covers when you're really muddy.
