How Long to Settle & Get Alignment?
Discussion in 'Suspension' started by SManZ, Nov 16, 2009.
  1. Nov 16, 2009 at 4:25 AM
    SManZ
    SManZ [OP] el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I'm going to be installing the Toytec ultimate lift kit and LR UCAs this Wed!
    As the front settles and gets lower will it affect the alignment? If thats the case, after it is installed, how much should I drive to let the suspension settle in before getting an alignment?
    -Thanks!
  2. Nov 16, 2009 at 7:17 AM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Get an alignment ASAP
  3. Nov 16, 2009 at 7:49 AM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    My red Toytec coils settled within a couple of days. After a day or so, i re-adjusted, then again after about 500 miles. They have been stable since. I've seen posts that suggest taking a detailed measurement from hub center to fender opening when getting it aligned, and if it settles re-adjust to that same height. Me, i'd just wait. My truck handled fine after the lift, no need to rush.
  4. Nov 16, 2009 at 7:51 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    try a place with lifetime alignments...;)
