How long will a 2nd generation Tacoma last? Years and mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeJones7989, May 9, 2017.
  1. Feb 18, 2025 at 2:36 PM
    #141
    OkieCowboy
    OkieCowboy Well-Known Member
    Lloyd
    Choctaw, Oklahoma
    2012 TRD 4X4 Access Cab
    2012 TRD Off Rd Access Cab. I bought it almost three years ago with 158k miles. It now has 196k miles and runs like a new one. Other than regular maintenance I have only replaced two tire pressure sensors. It allows the new Silverado to be a Garage Queen. It will get new tires radiator flush, and a couple of other maintenance items at 200k. It should easily make 300k. It does like a new cabin air filter about every 10k miles. IMG_0721.jpgIMG_1465.jpg
    StihlToyota and ScrippsRanch67 like this.
  2. Feb 19, 2025 at 8:01 AM
    #142
    kozy
    kozy Well-Known Member
    Tim
    Arizona
    2006 Access Cab 4x4/6MT
    What prompted the engine replacement at 220K? Head gasket?
    Black97v6MT likes this.
  3. Feb 19, 2025 at 9:55 AM
    #143
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    2008 Tacoma base truck
    My 2008 Tacoma has over 431,000 miles with original drivetrain and still runs like a new truck.
  4. Feb 19, 2025 at 10:11 AM
    #144
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Yep, found a 2015 engine with 3k miles for $3200
    Toyota wanted $4000+ to replace the head gasket on the original and small shops wouldn’t change the gasket on the engine with that many miles
    ABA180 and kozy[QUOTED] like this.
  5. Feb 19, 2025 at 10:32 AM
    #145
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    2010 V6 OR
    Just hit 200K. I change coolant, trans, diffs, transfer case, power steering fluids every 50K. Spark plugs every 30K. Belt every 60K. Change oil every 5K miles with Mobil 1 and oversized Mobil 1 filter. Always grease driveline with each oil change. Major issues are LCA w/ball joints at 180K, Carrier bearing at 100K, 1 spider joint at 180K. It also goes through the car wash twice a week on average which blast under the frame. I have no rust and live where they have unlimited salt (Great Salt Lake) and use the stuff on roads during the winter. It's spent most of it's life garaged underground at work and in my garage when home.
    OkieCowboy likes this.
  6. Feb 19, 2025 at 8:06 PM
    #146
    blnewt
    blnewt Well-Known Member
    Brad
    2015 Gray metallic Double Cab V6 4x4 SR5
    2015 Double Cab SR5 V6 4x4 Texas Edition w/ 190k miles, no issues whatsoever, just flushed the ATF last week.
  7. Feb 19, 2025 at 10:55 PM
    #147
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This is badass..because 5 lug.
    Can't beat that deal for the engine, probably worked out close in dollars even if you paid for the install..what did that run you
  8. Feb 19, 2025 at 11:06 PM
    #148
    Oreo Cat
    Only the price of tools and parts. had all the hand tools already but had to go buy a engine hoist and transmission jack from harbor freight, probably paid around $500 for those. $750 for URD headers that blocked off the holes on the engine block for the secondary air pump
    I don’t want to go back and add up all the money I spent.. the more I think about it the more I see the alternatives I could have taken to either save money or buy a wrecked 4th gen v8 4Runner
    ABA180[QUOTED] likes this.
  9. Feb 20, 2025 at 10:22 AM
    #149
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    I'm at 20 year on my 05 base model. Of course it only just rolled 60,000 miles so it's not even broken in yet.
  10. Feb 20, 2025 at 10:47 AM
    #150
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    MT or AT in that beauty??
  11. Feb 20, 2025 at 11:15 AM
    #151
    ABA180
    East Bridgewater MA
    Curious if you got a number to have it done instead and what that came to
    Like those wheels, wouldn't really be practical for my area year round but killer truck
  12. Feb 21, 2025 at 5:57 AM
    #152
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Ok, so I'm back peddling on the reliablility of MY 2005 Taco...
    At about 190k, the frame around the engine mount perch finally gave.
    Then the head gasket leak sealer gave because the truck sat for months while i was preparing to fix the frame.
    So, the shittiest year of a Tacoma, went for 190k and 20 years LoL. We'll, arguably, the 2016 trucks might be worse than the 05??
    (I keep the frame treated with fluid film, so minimal rust. The head gasket started a small leak at around 170k.)
  13. Feb 21, 2025 at 10:34 AM
    #153
    gstodd
    2005 2wd base 5-lug
    They aren't as bad as you would think. They are mono block forged so they take hits well. I've only bent two of them and that was hitting a rock at speed that was 4-5" in diameter. The local wheel repair shop was still able to fix the damage and true them back up and it cost me less than trying to import another set from Japan. Of course with the 255/35s I'm running on them I've got a lot more protection than the 225/30s I used to run with them on my other car.
  14. Feb 21, 2025 at 11:14 AM
    #154
    ABA180
    East Bridgewater MA
    With the snow and salt around here they'd be ruined pretty fast, too nice for that part of the year.
  15. Feb 22, 2025 at 12:23 AM
    #155
    FishaRnekEd
    New Orleans, LA
    Hey dude, watch out for the 2005 issues, if you aren't already aware of them.
  16. Feb 22, 2025 at 5:49 PM
    #156
    The Yellow Dart
    The Yellow Dart Well-Known Member
    Nick
    Seattle
    07 //SR5 4x4
    OME 2.5" Lift, TC UCAs, LEER Cap, Sleeping platform, PA20-TOY
    I had a 2007 AC SR5 4x4 until… well, yesterday.
    198,892 miles on it. Engine still ran like a champ despite me just doing the minimum like oil changes every 5k (synthetic) and changing the diff fluids like once every 5 years.
    I put some mods into it: 2.5” OME lift with 886’s Nitrochargers in the front/back and Dakar leafs with TC UCAs. Ran 255/75/17 Duratracs for the last 10 years. Added a hitch, trans cooler, 4 & 7 - pin wiring harnesses, Prodigy brake controller - never once used any of the towing stuff. Literally the most action the hitch saw was a HitchSafe.
    My problems were that I didn’t understand about greasing zerk screws. Last time I took it in, my UCAs, LCAs, CV boots, et al, were all shot. Alignment was way out of whack and I ended up ditching the Duratracs for some stock tires for the last 6 months. That, and within the last 1.5 years, the frame rust (as well as the leaf springs) just exploded on me.
    Thing still fired right up and ran amazingly. But, I have a family now and I needed to get something that someone other than I could drive. (Like how a captain knows how to maneuver his ship, but anyone else who tries will die) And the AC isn’t the best for hauling anything resembling a fully-grown human in the back.
    Sadly, traded it in for a 2021 Highlander Hybrid LE for the people-hauling/gas mileage aspects. It’s been just over 24 hours and I desperately want my truck back. But, gotta be responsible.
    I had that truck for 15 years and there are a lot of memories linked to it. Toyota forever.
    herecomesace and blnewt like this.
  17. Feb 23, 2025 at 6:37 AM
    #157
    blnewt
    Brad
    Yeah, every single Toyota truck I've had, then sold, I've regretted. I won't be selling my 2015 anytime soon, and when the time comes I'll regret that too :( For whatever reason Toyota trucks just keep their mechanical integrity better than anything else on the planet, a 20 yr old Toyota still runs and drives very similar to when new versus any other old vehicle I've driven, some were downright terrifying when they get serious miles/years on them.
  18. Feb 23, 2025 at 10:59 AM
    #158
    Black97v6MT
    iMA0
    tacoLand USA
    '11 reg cab 4cyl with the AT
    Been having odd noises lately in D at 60-65 MPh
    Not a clue about where it coming from yet
  19. Feb 23, 2025 at 3:13 PM
    #159
    gstodd
    2005 2wd base 5-lug
    Fortunately most of the issue are with the V6 or with parts that I've already replaced with while modifying the vehicle. Only one left is the coolant tube under the intake manifold. I'll get around to replacing it with the metal one at some point.
    FishaRnekEd[QUOTED] likes this.
  20. Feb 23, 2025 at 7:53 PM
    #160
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    My 2011 recently needed a fuel pump and an AC line. Up until then it only needed basic maintenance. I suspect it will go another decade with only basic maintenance.
    ABA180 likes this.
