How long will a 2nd generation Tacoma last? Years and mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeJones7989, May 9, 2017.
  1. Feb 23, 2025 at 7:54 PM
    #161
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    So, to answer the title,
    All of them.
    Provided you perform routine maintenance on time, including major wear items such as wheel bearings and fuel pumps.
  2. Feb 24, 2025 at 9:02 AM
    #162
    tommytaco67
    tommytaco67 Well-Known Member
    vail
    2012 SR5 V6
    My 2012 Tacoma has around 213k on the clock(bought it with zero). I've only had minor repairs water pump, ac hose, secondary air valve replaced under warranty at 200k. Lots of tires, new suspension x 2 for the rears and leafsprings. Runs like new I am pretty meticulous about changing all my fluids at regular intervals using synthetics all around. Im 58 and I need this to last until I retire maybe longer. I also have an old lexus I use as my daily driver so the taco only gets used when I need a truck or if It looks lonely I rip it around for a day or 2.
    I love the reliability.
  3. Feb 24, 2025 at 10:34 AM
    #163
    blnewt
    blnewt Active Member
    Brad
    2015 Gray metallic Double Cab V6 4x4 SR5
    Nice! How often do you service your ATF (If you have an automatic that is). I have no doubt that will roll well into your retirement. I'm 62, just bought my 3rd Toyota truck (190k miles) and have no doubt this will last til I'm rolling into the nursing home or the graveyard lol.
  4. Feb 24, 2025 at 3:26 PM
    #164
    JohnnyGraphic
    JohnnyGraphic Well-Known Member
    Johnny
    Northern California
    2021 4Runner TRD OffRoad Premium
    Falken Wildpeak AT3Ws
    Be aware that the life of a car is driver dependent. If you commute 30 miles each day on the freeway going the limit vs stop n go is different on the engine/transmission etc. Same with the daily driver that drives 5 miles to work and barely gets the car up to temp.
    Also, if your car is garage kept vs kept outside will make a difference. Chicago is different than San Diego.
    In all cases, if you REALLY want to keep on top of your car, any car, get an oil analysis and make adjustments to your maintenance from there. Keep up on any repairs/replacements that need to get done. Wash your car frequently. Don't let gunk build up.
    Patch Barracks likes this.
  5. Feb 25, 2025 at 7:10 AM
    #165
    BryansTacoma08
    BryansTacoma08 Well-Known Member
    Bryan
    Beaufort South Carolina
    2008 DCSB Speedway Blue
    I have a 2008 4x4 Tacoma that I purchased used in 2012 with 70,000 miles on it. It now has almost 270K on it. Only issue is ive had to replace the 4x4 Transfer case. Other than routine maintenance. No big issues (KNOCK ON WOOD). Going strong!
    O'DubhGhaill and herecomesace like this.
  6. Feb 25, 2025 at 11:38 AM
    #166
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    Depends of where and how it's driven. I'm in Quebec = road salt. I started off with my new 2012 with new tires and OME suspension. Over the last 2 years, I dropped $10K in Canadian pesos on my 2012, mostly in OEM parts, starting at about 200K km. Not much before that other than regular maintenance and a few parts. I must of done at least 50K km on gravel roads, usually high speed and loaded to the gills (not me, the truck ;)). Here's a rough list on what was done with date, km's and parts. Presently, trucks purrs like a kitten, and hoping for a 30K until additional work which will probably be idler wheels, plugs, possibly alternator, and thinking of changing AC compressor as preventive maintenance. Crossing my fingers to keep it another 3 yrs/ 60K without much work. We'll see after that, rust is starting to show :( Presently at 258K km / 160K miles.
    20121114 32 Tires, Duratrac 265/75-16
    20121114 32 OME 2.5'' HD Kit
    20121114 32 SPC UCA
    20121114 32 Firestone Airbags for rear leafs
    20140217 31115 Front rotor machining
    20150528 48000 SPC UCA bushing replacement # 1
    20160920 60843 Replaced front pads and rotors
    20170111 66500 Tire replacement # 1, Duratrac 265/75-16
    20180510 96000 Battery replacement # 1
    20180514 96000 SPC UCA balljoint replacement # 1
    20180612 96987 Belt replacement # 1
    20180612 96987 AC clutch replacement # 1(cheap Ebay, china)
    20181005 98000 Unifilter mod
    20181005 108000 OME BP-51 rear shocks
    20181117 110000 Airbag for rear leafs replacement # 1
    20190212 114505 SPC UCA bushing replacement # 2
    20190212 114505 Differential air vent mod
    20190212 114505 Replaced front pads and rotors
    20190225 115265 Rear axel sceal
    20191212 135244 Antenna replacement # 1
    20200428 140028 Replace air pump under warranty
    20200826 144132 AC o-ring repair, front rotor machining, replaced 3 idler wheels and belt replacement # 2
    20200717 150000 Tire replacement # 2, Duratrac 265/75-16
    20210104 159403 Drum machining
    20210127 165000 Windshield replacement
    20210526 167569 Replaced high pressure AC hose
    20210630 170000 Replaced stabilizer bar bushing
    20210716 170000 AC clutch replacement # 2 (cheap Ebay, china)
    20210916 176426 Replaced front brake pads and rotors
    20221202 210768 Replaced lost pin from front brake pad
    20221223 212000 Tire replacement # 3, Duratrac 265/75-16
    20230417 218000 Antenna replacement # 2
    20230417 218000 Replaced front and back suspension, coils, leafs, shocks etc. (broken leaf spring) (back BP-51 replaced under warranty)
    20230417 218000 Replaced LCA's
    20230730 227303 Replaced front brake pads and left caliper
    20230817 227303 Replaced a bunch of front end fasteners
    20230817 227303 Lots of welding left wheelwell/radiator support area
    20240603 242522 Replaced all 4 tires under warranty (# 4)
    20240605 243000 Replaced muffler
    20240611 243500 Replaced front wheel bearings, front and rear pads, rotors, drums
    20240813 244000 Replaced CV Axels + seals, right side caliper, SPC balljoint (#3) and bushing, AC clutch # 3(cheap Ebay, china), battery replacement # 2, added ECGS bushing
    20240907 246000 Replaced catalytic converter gaskets
    StihlToyota and DavesTaco68 like this.
  7. Feb 26, 2025 at 1:05 PM
    #167
    tommytaco67
    vail
    2012 SR5 V6
    I have a manual
    blnewt[QUOTED] likes this.
  8. Feb 27, 2025 at 10:03 PM
    #168
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    2008 Tacoma base truck
    it is AT
    Black97v6MT[QUOTED] likes this.
  9. Mar 6, 2025 at 4:29 AM
    #169
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
    Aww, how they grow up so fast... :rofl::woot:
    Kolter45, Ezriderga and rydr1 like this.
  10. Mar 6, 2025 at 5:15 AM
    #170
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    hey! i am the 5 mile commute to work guy (she gets up to temp in that time) and garaged in salty ass MA
    only had her 5 months tho! good points by you...oil does like getting up to temp, moreso an issue if you dont let it do that, like when i drive 2 mins to walk dog from my house, the vehicle doesnt fully warm, and the oil gets milky under fill cap
  11. Mar 6, 2025 at 5:15 AM
    #171
    rydr1
    rydr1 Well-Known Member
    Can a 19 year old Tacoma with 129k miles be added to this list? Parked outside all it's life so it needs new paint. Minor repairs and proper maintenance, but I drive this one out to wherever without any worries.
    Like everyone else has mentioned, proper maintenance and always inspect for broken, worn, leaking items and replace as soon as possible.
    My dad just picked up a 4th gen Tacoma and even though it's tempting, I can't get rid of my fully functional truck.
    O'DubhGhaill, Williston and hinmo24t like this.
  12. Mar 15, 2025 at 8:55 PM
    #172
    TacoTuesday1
    FL
    A properly designed vehicle taken care of will do over a million miles.
    my Tacoma has given me so much the question is how can I give to it.
    as a professional mechanic who has worked on most of, if not every type of vehicle on the road, I know this is by far not the norm.
  13. Mar 15, 2025 at 9:16 PM
    #173
    JohnnyGraphic
    Johnny
    Northern California
    O'DubhGhaill and Blacktacoma23 like this.
  14. Mar 15, 2025 at 9:36 PM
    #174
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Simplicity is a good thing especially as they age..
  15. Mar 17, 2025 at 6:45 PM
    #175
    TonyTacoma
    TonyTacoma Member
    Florida
    08 Tacoma
    My 2008 Double Cab has 215000, bought new. Only had problems with bearings and steering.
  16. Mar 21, 2025 at 5:47 PM
    #176
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    God how I hate that Dude! A collector's dream and he destroyed it for shits, giggles, and youtube hits. What a shame...
  17. Mar 21, 2025 at 8:53 PM
    #177
    JohnnyGraphic
    Johnny
    Northern California
    I agree. But, he did prove a point. These things are built to last! Better than buying a nice old vintage and desirable vehicle and wrapping it in plastic never to enjoy it. I know some who spend a ton of money on things like Porsches and the like and never drive it aside from an occasional 5 mile drive to the office 'to be seen'. I told him he's KILLING his car. I'd hate to see what his EGR/CCV system looks like. Probably resembles the Exxon Valdiz! (Did I just date myself?).
