How long will a catalytic converter last?
Discussion in '1st Gen. Tacomas (1995-2004)' started by aboyandhisdog, Mar 28, 2015.
  1. Mar 6, 2020 at 9:30 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    awesome, thanks!
    I don’t believe their getting clogged. I can smell that it’s running rich. Whenever I find the time maybe I can grab two good cats off of a TW member or a pick and pull (if that’s even legal) and see how it does. I know I have to replace my downstream sensor because it throws a code. It’s only during start up. I have the sensor, it’s just that the threads are junk. I’m probably going to have to order the sea air flange from LC engineering and have my local exhaust guy weld it on.
    1997tacomav6[QUOTED] likes this.
  2. Mar 6, 2020 at 10:02 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yep same with both of my older ones in excess of 300K One of them had the O2 sensor nuts rust off and blew the sensor out of the pipe but that was about it.
  3. Mar 6, 2020 at 10:32 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I pulled my old O2 studs and replaced with new 8mm x1.25
  4. Mar 6, 2020 at 10:44 AM
    QMEDJoe
    Joe
    I thought they were welded to the flange? So I could spray some Aerokroil on them, remove them and replace with new ones?
  5. Mar 6, 2020 at 10:46 AM
    eon_blue
    Azusa, CA
    Catalytic converters should last indefinitely assuming your truck is in good working order. Lean and rich conditions kill cats. Also, thieving tweakers...skids work well to protect you not only from rocks but also cat thieves
    1997tacomav6, QMEDJoe and xtremewlr like this.
  6. Mar 6, 2020 at 10:50 AM
    Black DOG Lila
    Virginia
    Yes. The studs thread into flange. I used Vice grip locking pliers after one stud broke leaving 3/16" sticking out so I replaced both studs with new 8mm x 1.25
    QMEDJoe[QUOTED] likes this.
  7. Mar 6, 2020 at 11:23 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Kinda like our trucks...
    :D
    QMEDJoe and six5crèéd[QUOTED] like this.
  8. Mar 6, 2020 at 11:24 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    That's right :thumbsup:
    jbrandt[QUOTED] likes this.
  9. Mar 6, 2020 at 12:47 PM
    dominator001
    dominator001 Active Member
    Dominic
    Beaumont, CA
    White 2002 Tacoma Prerunner Regular Cab
    I have no comment in response to your cat question, but you seemed to be considering replacing both sensors. While I’m sure some disagree, if you have the money I have always replaced both the down and upstream sensor at the same time. (Unless you previously changed them at different times). Just extra peace of mind imho, especially if you’ve thrown some codes before. Quicker, cheaper, simpler than replacing the cats
    1997tacomav6 likes this.
  10. Mar 6, 2020 at 12:57 PM
    1997tacomav6
    Denver
    I’ve actually had to replace both the up and down stream sensors twice but not the cat.
    These sensors get caked with carbon, this helps them fail
  11. Mar 6, 2020 at 1:04 PM
    dominator001
    Dominic
    Beaumont, CA
    I’ve never had a problem with my cats either, although I have 220k on my truck. Replaced my sensors about 20k ago. Think if I was you OP I’d throw new sensors on both locations and call it a day
