How long will a well maintained 5VZ-FE Tacoma last?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoastieTX, Jul 1, 2021.
  1. Jul 1, 2021 at 8:52 PM
    CoastieTX
    CoastieTX [OP] Well-Known Member
    PNW
    Original owner 1998 Tacoma TRD; 3.4 V6 with 5 MT
    As my profile indicates, I’m the original owner of a 1998 V6 Tacoma with manual transmission. The truck has always had it oil changed at 5000 mile intervals with fully synthetic Mobil one, and coolant replaced every 60K with genuine Toyota fluid. The truck still runs absolutely fine and burns no oil that I can detect.
    Realistically, how many miles can I expect to go before something catastrophic happens, like a blown head gasket? Assuming everything is being maintained properly, how do these engines start breaking down?
    It hasn’t escaped my notice that the resale value on these trucks is pretty crazy right now. Before deciding to sell it, it’d be nice to know how far along into its useful life it is. I am still on the original clutch, wheel bearings, catalytic converter, etc.
    MalinoisDad likes this.
  2. Jul 1, 2021 at 9:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ve seen some with 300k on them.
    Not at all uncommon to see 250k.
    The 3.4 is a great engine. The manual transmission is just as good.
    I live in Tennessee. So the rust doesn’t usually get to them first.
    If it’s a northern truck, it’s usually rust that kills them first.
    I have family members in Va. and W.V. they can’t find a good Tacoma that isn’t rusted out.
    With you doing maintenance like you say, I’d think you’ll be closer to 300k before you need to start looking at major repairs.
    JudoJohn and CoastieTX[OP] like this.
  3. Jul 1, 2021 at 9:26 PM
    LiftedOn35s
    LiftedOn35s Graduated!
    Noah
    Northeast FL
    Shadow Grey Met. 2004 Tacoma V6 5MT TRD OR
    1" level, 16" American Racing wheels, 32" M/Ts
    I've seen plenty 3.4 trucks with 350k+, albeit like tnshooter said that's probably with some decent repairs, around 300 is when you need those kinds of things. In a "drive it till it dies" scenario, a well maintained truck will probably run 400 or even 500k with no fatal issues. There's even a handful on here with that many miles, last I checked!
  4. Jul 2, 2021 at 5:36 AM
    tpole
    tpole Active Member
    Check the various odometer posts on here, e.g., the 500k posts.
    I've 682k on the clock now, original 2002 5vz and tranny. Doesn't burn oil, a/c still blows cold, I drove to work this am at 85mph.
  5. Jul 2, 2021 at 6:26 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    My 5-lug v6 has gone through multiple owners and various forms of abuse and still runs great with close to 1/2 a million miles.
  6. Jul 2, 2021 at 6:29 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Check those valve clearances at 200K miles. Heads are a big taker from the population.
  7. Jul 2, 2021 at 6:58 AM
    summithightacoma22
    summithightacoma22 Well-Known Member
    michael
    denver
    2013 grey tacoma trd sport
    front +2 allpro long travel with kings. Marlin crawler lca reinforcements, alpine design cab mount. All pro spindle and upper control arm reinforcements. Willwood 6 piston front calipers and 2 piece rotors. rear 7 pack expedition soa, 12 2.5s, archive garage shock relocation kit. Archive garage shackle flip kit. wheels 285/75/17 geolander g0003 on 17x9 with a zero offset. engine bay. antigravity atx hd-20 lithium battery arb high capacity air compressor. 3* exhaust cam timing. intake spacer custom stuff custom made sliders, custom bed rack system, custom drawer and bed system, modified mounts for arawak awning. Fiberglass/lexan cap door. Boxed out frame in spots I could reach. soon to be a chopped bed at the rear axle interior -lathewerks co polymer stainless shift knob, modified from a wrx to fit. -pioneer mid and treble speaker replacement. -future mods -4.56 gears arb front and rear lockers -traction bar for the rear. -full carbon front clip. -supercharger eventually.
    based off my buddies 4 banger in his 01, as long as you do routine love , those engines are good until auxiliary hoses/headers start peeling away/rusting and need to get replaced. I have seen a 4 banger with 500k on it, and ever header had rust holes, things ran a little putty, but for the 9k original truck, a couple of oil changes/spark plug changes and some tires, my buddy has put 200,000 miles on a vehicle he got with 300 on it.
  8. Jul 2, 2021 at 8:28 AM
    Glamisman
    Glamisman Well-Known Member
    385,000 on my 2.4 before I had the motor rebuilt. My 3.4's are ~ 175k ish
  9. Jul 2, 2021 at 9:08 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Our 3.4, and please correct me if I'm wrong, is a very well-balanced, internally over-built (maybe to accept an optional supercharger?) 206 cubic inch die-hard. One of Toyota's finest engines that doesn't beat itself up with normal running. IOW you really cannot kill these things unless you really try.
    se7enine likes this.
  10. Jul 2, 2021 at 10:01 AM
    beignet
    beignet Well-Known Member
    Ben
    1996 3.4L 4x4 Tacoma
    I’m still getting good oil analysis results from Blackstone at 225k. Plan to have my valve clearances checked this summer to keep it that way.
    Lots of other stuff on my truck has been replaced, but the motor still seems to be in good shape. I actually just drove it from NY to MT in a few days without any hiccups.
  11. Jul 2, 2021 at 10:21 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It's why the N/A 1JZ/2JZ's are so good. Overbuilt.
    Ridgerunner[QUOTED] likes this.
  12. Jul 2, 2021 at 3:30 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    It depends on the value of the truck.
    Everything is replaceable or repairable. If the vehicles hold the value that is currently still going up, it makes sense to rebuild the engine and repair various other parts and keeping it running smooth.
    If you keep it from rusting, replace the little things as they break, don't crash it, do oil changes, maintenance, belts, etc you can look at 600k miles but some will be well under and some will be well over. Then you get it rebuilt and keep going.
  13. Jul 2, 2021 at 3:39 PM
    1997tacomav6
    Denver
    Forever it you NEVER let it over heat,
    Once overheated a leaking head gasket will come your way sooner or later
  14. Jul 2, 2021 at 3:40 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    My ‘97 4Runner with the same engine has gone 370,000 so far. I sold it to my friends son and it’s still running trouble free. Had a front seal leak. I also did the timing belt every 90k miles. Nothing internal has broke and it doesn’t burn oil. I changed the oil every 4,000 miles religiously.
    Ridgerunner likes this.
  15. Jul 2, 2021 at 3:42 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    5vz-fe is an amazing engine. I had a 1996 blow a headgasket at 185k miles. Also a 1999 that made it to 320k miles, then headgasket failed. Replaced both with low mileage used engines. Change the timing belt/water pump every 75-100k miles.
