How loud can a exhaust leak sound?
Discussion in 'Technical Chat' started by Jgoon54, Apr 14, 2019.
  1. Apr 14, 2019 at 6:26 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    knocking as everytime it changes direction.
  2. Apr 14, 2019 at 6:33 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Oh yes. I’ve only ever had one engine with a wrist pin knock. Not a common issue
  3. Apr 14, 2019 at 6:34 PM
    Jgoon54
    Jgoon54 [OP] Member
    Jacob
    04 Tacoma 2.7l prerunner
    Could that kind of noise even come from a pulley/drive belt?
  4. Apr 14, 2019 at 6:36 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    No, sure not on Toyo. esp.
    I'd rule out everything else first.
    Dirt bikes were terrible about that but always sounded much different. More of a SHSHSHSHSHHSHSH as it smacked the head.
  5. Apr 14, 2019 at 6:41 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Could if a bolt were backing out and touching a pulley.
    edit: listening again doesn't rule out anything.
    again though, I don't think that's going to be hard to find. It's too loud and nearby
  6. Apr 14, 2019 at 6:43 PM
    Empty_Lord
    Dan
    Drive accessories can cause many odd noises. When you have the belt off make sure the crank pulley can’t be pulled in and out too.
    cruxofthebisquit likes this.
  7. Apr 14, 2019 at 9:27 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Have you had the camshaft out? There's a scissor gear that might no be preloaded anymore. I did that once and it was a fast tick. Not that loud though.
  8. Apr 14, 2019 at 9:36 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Definitely not an exhaust leak... sounds too loud to be a lifter. Maybe timing chain stretched and is slapping? Pulling the belts will be a good place to start.
  9. Apr 15, 2019 at 9:39 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    We don't have lifters. We do have shim over bucket and it certainly is possible for a shim to get dislodged but this sounds to fast to be a (as in one) valve. Too fast to be 1 of anything. Makes me think it's something ancillary to the engine
  10. Apr 15, 2019 at 9:43 AM
    Empty_Lord
    Dan
    If a shin was making this noise it would be a misfire too
  11. Apr 15, 2019 at 9:50 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Probably true.
    It does sound terrible, don't blame you OP for much concern.
    Really could be anything though and probably will be something strange.
    The only way I see a broken piston is from detonation but it certainly does happen from that. I hope not for you.
  12. Apr 15, 2019 at 11:08 AM
    Jgoon54
    Jgoon54 [OP] Member
    Jacob
    Never had camshaft out.. replaced harmonic balancer acouple months ago I could have done something wrong re-assembling not sure. Going to take off the belts when I get a chance. If the noise is still prompt what should be my next step?
  13. Apr 15, 2019 at 11:10 AM
    Jgoon54
    Jgoon54 [OP] Member
    Jacob
    And even with this noise it idles at a constant RPM doesn’t misfire and drives perfect. Just with that horrible noise..
  14. Apr 15, 2019 at 11:44 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    OK the harmonic balancer or something attached to it is now suspect #1
    empty lord is also right to check crank freeplay.
  15. Apr 15, 2019 at 11:53 AM
    #35
    Jgoon54
    Jgoon54 [OP] Member
    Jacob
    Check if the crank pulley has wiggle room?
  16. Apr 15, 2019 at 12:23 PM
    #36
    Empty_Lord
    Dan
    Yes forward to back, if it does pull the inspection plate for the transmission and pull it back and forth and see if the flywheel moves too. If it does then there’s bad thrust bearings.
    Kinda doubt this is your issue. But it’s something to check
