How low can i go without notching
Discussion in 'Street Trucks' started by midori, Sep 25, 2014.
  1. Sep 25, 2014 at 9:35 AM
    midori
    midori [OP] New Member
    Josh
    St. Louis, MO.
    ive searched and cant find a definitive answer as to how low i can go and still retain suspension travel before notching the frame is necessary.
    im not scared to do it, in fact i considered having it done before anything else as done but if i dont have to with a 3/4 drop im not going to. i know the DJM 3/4 kit comes with notch brackets and this is what makes me curious.
    anyone have some honest insight/experience into this?
  2. Sep 25, 2014 at 9:42 AM
    Aw9d
    Aw9d That one guy
    Might want to post more info about the truck you have.
  3. Sep 25, 2014 at 10:21 AM
    midori
    Josh
    St. Louis, MO.
    thanks, and i thought about that a little after posting haa
    I have a 2010 Base 2WD
    looking at the rear suspension it looks like theres a decent amount of room between the rear axle and the factory bump stops
  4. Sep 25, 2014 at 10:26 AM
    Aw9d
    Aw9d That one guy
    You can PM a guy named Phildamnit on here. He's got a lowered 2nd gen and I don't think he notched it. Sits good.
  5. Sep 25, 2014 at 7:32 PM
    bishop68
    bishop68 Member
    b
    waipahu
    5" drop is the lowest you can go on the rear with low pro bump stops....how do I know!?..I got a 5" beefed block on my 2013 base 5 lug taco rides rough but she aight.. Finally made a decision to notch so going lower in a week or so (4" djm block and a leaf pulled)
  6. Sep 26, 2014 at 7:27 AM
    midori
    Josh
    St. Louis, MO.
    AWESOME! I want to do the DJM kit after winter. I think that will be a good place to start then it will be easy to go lower in the future if need be
  7. Sep 26, 2014 at 9:13 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    I had a 3 inch block and was bottoming out everywhere. I'm sure 3in with QA1 shocks should be sufficient as long as you dont plan on putting anything in the bed lol
  8. Sep 26, 2014 at 10:38 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    I have a 3" block and bottom out with nothing in the bed. I'm waiting for my notch from streetacos.com and pulling a leaf for 6" drop. can't go without a notch really.
