How many accessories can i attach to battery?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xwillx93, Nov 24, 2011.
  1. Nov 24, 2011 at 6:34 AM
    xwillx93
    xwillx93 [OP] Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    Right now, i have reverse aux lights, another relay/switch for future hellas, and a 1000 watt pioneer amp BRIDGED to another 250 watt amp. How much can we hook up to our stock batteries before buying another one should be a consideration? I'm looking into putting a Cobra CB radio in... its a 2009 2.7l 4 banger, not sure if any of our batteries are different :p
  2. Nov 24, 2011 at 9:56 AM
    joes06tacoma
    Joe
    Central Coast, CA
    The issue isn't the battery, it's the alternators capacity to recharge the battery. One extra set of lights and a CB isn't going to be a problem. The stereo might be when it's combined with the lights. CB really does not draw anything significant.
    You could take the truck to a shop and ask them to measure the maximum output of the alternator and the max that everything on the truck pulls when it's all turned on. Or you could be less scientific and go ask this question in the audio forum. The biggest question I have is the amplifiers. Someone has done it before, just need them to see your question.
  3. Nov 24, 2011 at 10:14 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Im not sure but the factory alternator is only around 60A. You may want to consider upgrading that
