How many amps to run in fuse
Discussion in 'Technical Chat' started by BeefedTacos, May 18, 2023.
  1. May 18, 2023 at 3:19 PM
    BeefedTacos
    BeefedTacos [OP] Well-Known Member
    Brian
    North Carolina
    2015 tacoma dcsb SR5 4x4
    None so far
    Can someone tell me what amp to run in my sub fuse panel for this product I’m installing in the bed?
    [2022 Newest] Kohree 12V Power Outlet Socket, 3 In 1 200W Cigarette Lighter Socket with PD Type C 3.0 & QC 3.0 USB Charger Waterproof for Marine, Car, RV, Motorcycle, Boat, Golf, ATV, etc https://www.amazon.com/dp/B09CKQJQDT
  2. May 18, 2023 at 3:44 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    If it is 200W, I would use a 20 amp fuse. (200W divided by 12 v = 16.67 amps)
    And make sure the wire is capable of the current--12 gauge, probably.
  3. May 18, 2023 at 4:10 PM
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    12 amps, ensuring that all the wire feeding it will support that amperage.
    You always want your fuse to be the weak point of the system. Here your system (from the fuse panel back) includes the total max current draw of the devices, the panel itself, and the wiring run.
    You can size your wiring with this chart: https://www.bluesea.com/files/resources/newsletter/images/DC_wire_selection_chartlg.jpg
    Max advertised current draw is 200W + 36W + 18W = 254W = 19.5A
    The panel itself has a 10A rating, and comes with a 15A fuse. I'd be hesitant to up-rate that without seeing the quality of the panel in person; the switch will be the most likely failure point if you run new wires. I also generally only overfuse by 10-25%, not 50%.
    Making the fuse the limiting step, and making some assumptions about your wiring, 10 ga wiring and a 12A fuse. I'd expect to only use this particular panel for 10A/120W.
    That's also likely enough wiring beef to protect you if you choose to throw a larger fuse in and run it at what its likely capable of rather than what it's rated for.
  4. May 18, 2023 at 5:58 PM
    BeefedTacos
    Brian
    North Carolina
    None so far
    I was going with a 10gauge with a 40amp fuse and then at the sub fuse panel a 10 amp for the 12v socket, usb and voltage meter.
    MuddySquirrel likes this.
  5. May 18, 2023 at 9:32 PM
    MuddySquirrel
    Will
    Phoenix
    Sounds like a solid plan. Don't forget that you can halve your wire run by grounding to the body, and enjoy!
  6. May 18, 2023 at 10:10 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    ^ x2 on this advice
    100%
    Fuse should go first, everything else should be rated to handle well over the amperage the electronics are rated for. Also: check your instructions or the product specifications. They should list the amperage the thing is rated to handle.
  7. May 18, 2023 at 10:20 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    That’s not how this works. Fuse/breaker protect the wire, not the other way around. Electrical fires are no joke.
