How many bags of mulch will fit in a 2012 tacoma 6ft bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nachotaco, Jul 2, 2017.
  1. May 29, 2019 at 12:02 PM
    #41
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    The problem with exceeding GVWR is that everything starts to get stressed and worn at accelerated rates. Your brakes, suspension, steering were all designed for a certain range of operation and loading down the bed really strains that.
    You might not care in which case stop reading, but if the goal is to keep your Taco until the wheels fall off then it's better to haul less, or buy a small trailer you can tow which affords you the ability to carry MUCH more weight.
    I think the Taco being a mid sized truck that is about the same size as some older full size trucks (97-03 F150) gives the impression of equal capability, but that just isn't the case.
    Troyken likes this.
  2. May 29, 2019 at 12:27 PM
    #42
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I've done it. It sucked. Up and down up and down shoveling mulch in an out of a wheel barrow.
    I do bags now, much easier on the back.
    ejl923 likes this.
  3. May 29, 2019 at 12:49 PM
    #43
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    i cant like this post enough, word for word. Two years in a row i did bulk, and it was so much more work. If you wait for the deals which i usually do like 4 or 5 for $10, sometimes bags are even cheaper than bulk. I drag the bags over and dump'em. If i ever have giant beds and i have a tractor with delivery, i'll switch.
    TacomaMike37[QUOTED] likes this.
  4. May 29, 2019 at 12:52 PM
    #44
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Our trucks are in the total payload range of 1200 to 1300 lbs. maximum. Can they carry more, maybe. Is it safe, doubtful. Should you do it, your call. Would I carry the max payload regularly, no way. It really doesn't matter what springs, shocks, bags or other equipment is added, that payload rating doesn't change. Something else will wear and fail in time. The axles, bearings, brakes, clutch, frame and other components are designed for that rating and not too much more. With all the requirements for fuel economy, emissions and price point, why and where would Toyota give us anything more than what was required to meet the specs?
    Don't get me wrong, within it's limits the Tacoma is a good, reliable and useful truck, however, if you push those limits regularly you should consider a bigger truck or a trailer.
    By the way, about one yard of dry mulch will fit in my truck and comes right up to the bed rails. I can roll the tonneau cover over it and latch it.
    2015WhiteOR likes this.
  5. May 29, 2019 at 1:05 PM
    #45
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    One guy in the what have you hauled in your taco thread had like 15 kegs in the back, pretty sure they were empty though.
    PackCon[QUOTED] likes this.
  6. May 29, 2019 at 1:06 PM
    #46
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    How ever many you want.
  7. May 29, 2019 at 1:11 PM
    #47
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    So...the only question I have...Is a pound of feathers lighter than a pound of lead? :muscleflexing: :)
  8. May 29, 2019 at 1:11 PM
    #48
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    The correct answer is your truck will hold 1-5 fewer bags than you actually need.
  9. May 29, 2019 at 1:39 PM
    #49
    TacomaMike37
    13' DCLB MGM
    Ha, brother from another mother!
    Im all for the 5 for 10 deals. Haul the bag where you want it, straight razor it open and dump. Rinse and repeat!
  10. May 29, 2019 at 2:09 PM
    #50
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    not enough to do my yard... i need 12 yards.....that wouldn't fit in a taco, but it might in a burrito.....
  11. May 29, 2019 at 2:09 PM
    #51
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    Hells yeah 5 for 10 :thumbsup:
  12. May 30, 2019 at 5:39 AM
    #52
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Yeah i meant bulk mulch. I can get access to a trailer but it's a pain to go get. But it is an option
    I dont mind the work. I'm 31, i'm still young and i consider it a good workout. But everyone is different and I can see where bags would definitely be easier and cleaner to deal with.
    I can get black mulch for 26 a yard. that would be like 12 bags of mulch.
