How many change oil viscosity during summer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AznGunner, Jun 1, 2011.
  1. Jun 1, 2011 at 8:51 AM
    AznGunner
    AznGunner [OP] Active Member
    Kingwood, TX
    09 PreRunner SR5 / TX Ed.
    Normally I run mobile 1 5w-30. Now that it's summer, should I go with 10w-40?
  2. Jun 1, 2011 at 8:53 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
  3. Jun 1, 2011 at 9:59 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Short answer: no.
    Long answer: Modern vehicles have efficient cooling systems and if yours is in good shape, in TX you won't need to change motor oil viscosity with the seasons. Some people who live in areas with extreme cold winters will go with thinner stuff in the winter but most climates don't need this. Stick with 5w30 and you'll be fine.
  4. Jun 1, 2011 at 11:20 AM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    No.....
    I run 0w~30 year round even in my heat! I have read that 0 (or 5) even helps when it's 75° out side at start up.
    And then I do not have to worry about changing oil when it might get cold :D
    Yuma Taco,
  5. Jun 1, 2011 at 12:28 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    0w-30 year round
