How many cranks to start?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JRinIowa, Dec 31, 2019.
  1. Dec 31, 2019 at 10:34 PM
    JRinIowa
    JRinIowa [OP] Active Member
    I typically hear four or five cylinders go past TDC before my 2013 fires up. But, it starts every time and runs smooth.
    My old Chevy Colorado 5 cyl would catch on the 1st cylinder that drew breath (not that I would ever want to go back).
  2. Dec 31, 2019 at 10:49 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Usually 3-4 but if it's really cold or if I stall it and start it again it's a bit more reluctant to turn over.
    How old is your battery?
  3. Dec 31, 2019 at 11:32 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    I probably hear 3-5 cranks before a start if it sat all night
  4. Jan 1, 2020 at 5:46 AM
    JRinIowa
    The battery is about 4 years old. It doesn't have any trouble cranking, it just cranks more than some other vehicles I've had before firing up.
  5. Jan 1, 2020 at 5:48 AM
    JRinIowa
    Seems like my experience might be typical, then. I probably won't worry unless something changes.
  6. Jan 1, 2020 at 6:06 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    3-4 cranks, every time.
  7. Jan 1, 2020 at 7:42 AM
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    I one time heard that Tacoma’s take longer to start so the oil pump can push oil through the engine before it actually starts. It’s almost like it’s programmed to miss a few cylinders before firing
  8. Jan 1, 2020 at 7:48 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Mine has never not started but there are times when it feels like it cranks a little longer than it should.
    I will say that I swapped out my OEM battery a few weeks ago for a Sam's club Duracell that supposedly has 800 cca and it spins the motor over significantly faster than the original battery. Kinda freaked me out the first time I turned the key.
  9. Jan 1, 2020 at 9:14 AM
    JRinIowa
    There were a couple VWs I wired to read the oil pressure switch just for that reason.
  10. Jan 1, 2020 at 4:30 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Mine cranks just one more than I am "programmed" for, so I often have to take two tries to get started. Owned it for two years now, and I almost always have to take two tries... Oh well. Love that truck.
  11. Jan 1, 2020 at 6:03 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    About the same here, 3 to 5 if my memory serves me correctly. I had a '77 Camaro back in the day that you only had to 'bump' the starter on, and it would fire right up. It had a 305 V8. What a POS that car was. Starting fast was about the only thing it did right.
  12. Jan 1, 2020 at 6:56 PM
    junkyardyote
    junkyardyote Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    Fires on the fourth every time
  13. Jan 1, 2020 at 7:06 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Same, 4-5.
  14. Jan 2, 2020 at 12:00 AM
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x4
    Mine feels more like 6+ compression cycles, even on fresh plugs and a new battery, with immaculate compression measured on all cylinders.
    I like this a lot more than my other cars that fire up immediately but then rattle like crazy until the oil makes its way to the lifters.
    I'd call this a feature, not a bug. But yeah, sometimes I forget to hold the key forward long enough.
  15. Jan 2, 2020 at 12:21 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Immaculate compression... LOL, I am going to steal that.
  16. Jan 2, 2020 at 12:57 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    It depends on if it's the first start of the day or not, if it's hot or cold etc etc. Sometimes its 3-4 other times its 4-5
  17. Jan 2, 2020 at 1:51 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I had a '79 Trans Am (with a 301:anonymous:) that would fire on the first cylinder every time. Taco usually takes 3-5. Once last winter it took two tries to get started -15F
  18. Jan 2, 2020 at 2:20 AM
    mk5
    SoCal
    '05 access cab 4x4
    OK maybe "immaculate" was an overstatement; I'm not sure if God actually helped, but it felt like it. All cylinders tested between 180-188 psi following a valve job and new head gaskets.
    Gearheadesw likes this.
  19. Jan 2, 2020 at 2:23 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Glad Im not the only one. Was thinking about this yesterday.
    New battery, new alt brushes 140000 miles.
  20. Jan 2, 2020 at 3:15 AM
    Taco-mama
    Taco-mama Well-Known Member
    2015 DCSB Prerunner
    You guys must be referring to the V6. My I4 starts immediately every time! :bananadance:
