How Many Gallons Are In Your Tank?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gjbonner, Aug 21, 2010.
  1. Sep 4, 2010 at 8:14 PM
    #41
    gjbonner
    gjbonner [OP] Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    how did you guess???? no just a couple of enthusiasts:)
  2. Sep 4, 2010 at 8:16 PM
    #42
    Larry
    Larry CARL
    CARL
    :cheers:
  3. Sep 4, 2010 at 11:08 PM
    #43
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Hey Larry... you wanna get 'tanked' with us? LOL
  4. Sep 5, 2010 at 6:01 AM
    #44
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Geesh .... don't encourage Larry ..... :D
  5. Sep 7, 2010 at 10:01 PM
    #45
    David K
    Full to 3/4 ---= 5.4
    3/4 to 1/2--- = 4.0
    1/2 to 1/4--- = 4.4
    1/4 to E-light = 3.0
    Full to 3/4 -------= 4.8 gallons
    3/4 to 1/2------- = 4.6 gallons
    1/2 to 1/4------- = 3.9 gallons
    1/4 to E-Light----= 3.5 gallons
    Yesterday's fill up:
    Full to 3/4 = 4.3 gallons
    3/4 to 1/2 = 4.6 gallons
    I filled before the 1/4 tank line, and got 17.4 mpg, and that's how I calculated the above quantities. It was 75 miles to the 3/4 line and 155 miles or 80 more miles to the 1/2 line.
    I know this isn't a major update, but I thought I would use it as an excuse to bump up this thread.
  6. Sep 8, 2010 at 5:09 AM
    #46
    gjbonner
    Guy
    Northern Idaho
    seems like you put your numbers in the wrong spot. 75/17.4=4.3 & 80/17.4=4.6
    the 4.6 and 4.3 should switch places right?
    also your supposed to have a bigger 1st 1/4 tank according to your past results but yet your 2nd 1/4 tank gave you more miles...These numbers are no way to gauge how many gallons are in a specific 1/4 tank. you will always get bad results. no worries, just saying careful to base conclusions on these numbers.
  7. Sep 8, 2010 at 7:56 AM
    #47
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Good grief. That's all I have to say. Buy gas. Drive. Be happy.
  8. Sep 8, 2010 at 2:49 PM
    #48
    David K
    Yah... I agree.This is more of a 'something else to do while driving your Tacoma' thread...
    Note the mileage traveled at various fuel gauge lines, then fill up at the 1/4 line, E-light 'on' point, or E line... noting the gallons to fill up.
    We are pretty sure that when on the Empty Line, you still have 2.5 gallons in the tank (18.5 to fill up).
    The E light coming on is a bit more irregular, but for me it was close to 4 gallons in the tank (17 to fill up).
    The last quarter tank mark is actually closer to 7-8 gallons in the tank (7.2 to 7.7), or 13.3 to 13.8 gallons to fill up.
    It is a 21 gallon tank, so a 'true' 1/4 of a tank would be 5.25 gallons. What we have discovered, so far, is only the first and last quarter tank is usually close to 5.25. The middle two quarter tanks are less (3.9 to 4.6), leaving room for the 2.5 gallon 'reserve' between the E Line and rock bottom empty.
  9. Sep 8, 2010 at 5:12 PM
    #49
    gjbonner
    Guy
    Northern Idaho
    hahahaha i meant on the tanks...your first 1/4 (F-3/4)you said was 4.6 gallons but that was the tank that had 75 miles on it so it should be 4.3...now do you see:)
  10. Sep 8, 2010 at 5:22 PM
    #50
    David K
    You are correct sir!
    I was thinking I used 80 for the first part... since the needle was over the 3/4 line from 75-80 miles on my odometer and again over the 1/2 line from 155-160 miles.
    I meant to use the lower mileage, when the needle first was cleanly over the line.
    I will edit!!!
    Thank you!
  11. Sep 8, 2010 at 5:24 PM
    #51
    gjbonner
    Guy
    Northern Idaho
    no worries, i thought i was cray for a second. you made me try to double check a calculator! :)
  12. Sep 8, 2010 at 6:22 PM
    #52
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    a 3 page thread on sizing up the gas tank? wow
  13. Sep 8, 2010 at 6:32 PM
    #53
    David K
    So, where's your figures? :confused:
    This is an ongoing highly scientific survey... we need serious responces here!:rolleyes:;):D
  14. Sep 8, 2010 at 6:36 PM
    #54
    gjbonner
    Guy
    Northern Idaho
    i know right? hey i like to know what i got in the tank at any given moment. where im from and where i'll soon be, Gas stations are few and far between. you can bring gas with you but everyone pushes it. I like to know what options i have as far as how many different places i can go to out in the wilderness without returning home.
    Sometimes your sitting out at the camp with a half tank wondering if you have enough to make a trip in to a lake or a lookout tower and still get home:)
  15. Sep 9, 2010 at 8:34 PM
    #55
    David K
    Okay, today I filled up at the 3/4 tank line... well just 5 miles after...
    The odometer was clearly centered over the 3/4 line at 80 miles...
    I got to a station in 5.3 miles, the needle was on the lower side of the 3/4 line then.
    I put 5.46 gallons in, to fill.
    85.3 miles / 5.46 = 15.62 MPG
    At 80 miles, I used 5.1 gallons.
    Here is gj's (big) estimated gallon chart, and mine (with new figures), below...
    3/4 to 1/2--- = 4.0
    1/2 to 1/4--- = 4.4
    My modified and updated findings: ........................... trip odometer reading at 18 mpg
    Full to 3/4 -------= 5.0 gallons .................. 90 miles
    3/4 to 1/2------- = 4.0 gallons (9.0 total) 162 miles
    1/2 to 1/4------- = 4.0 gallons (13.0 total 234 miles
    1/4 to E-Light----= 4.0 gallons (17.0 total) 306 miles
    E-Light to E-Line-= 1.5 gallons (18.5 total) 333 miles
    E-Line to EMPTY--= 2.5 gallons (21.0 total) 378 miles
  16. Sep 9, 2010 at 8:56 PM
    #56
    gjbonner
    Guy
    Northern Idaho
    yeah i think we are getting a respectable and acceptable margin of error there.
    Im now topping off and seeing how many gallons ican possibly fit in the top 1/4 while still continuing to gather data from the lower tanks.
  17. Sep 15, 2010 at 11:08 PM
    #57
    David K
    With the gauge needle directly over the 1/2 tank line, the truck took 9.1 gallons to fill up, today.
    So,
    Here is gj's (big) gallon chart, and mine (with new measured figures), below...
    3/4 to 1/2--- = 4.0
    1/2 to 1/4--- = 4.4
    Full to 3/4 -------= 5.1* gallons
    3/4 to 1/2------- = 4.0* gallons (9.1 total)
    1/2 to 1/4------- = 4.2* gallons (13.3 total)
    1/4 to E-Light----= 3.5* gallons (16.8 total)
    E-Light to E Line-= 1.7 gallons (18.5 total)
    E Line to Empty--= 2.5 gallons (21.0 total)
    * measured fuel amounts, not estimated
  18. Sep 20, 2010 at 11:59 AM
    #58
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Geat info... this should be a sticky
  19. Sep 20, 2010 at 2:28 PM
    #59
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  20. Sep 20, 2010 at 2:35 PM
    #60
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
