How many gallons do 3rd gen tanks hold?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thunder Fist, Sep 1, 2017.
  1. Sep 1, 2017 at 4:43 PM
    #41
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    two kinds of countries.
    Those who use the metric system, and those who WALKED on the moon.
  2. Sep 1, 2017 at 4:46 PM
    #42
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    There is real world data and you too can go fill up when your needle is over the E line. My bet is if you do it asap when on E line that you will add 18 gallons, proving there is 3 gallons remaining (+/- 0.5 gallon).
  3. Sep 1, 2017 at 4:47 PM
    #43
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Nope. 18.3 or 18.4 gallons at the light every single time.
  4. Sep 1, 2017 at 5:19 PM
    #44
    David K
    OK, good research.
    Then, what you indicate is, they CHANGED the point the light comes on, giving you one LESS gallon to get to a station.
    Now, these are real gallons pumped in and not your onboard computer telling you, right? So, do you think (until you actually do it), that there are only 2 gallons when your gauge is on the empty line?
  5. Sep 1, 2017 at 5:23 PM
    #45
    weefek
    weefek Well-Known Member
    J
    2017 OR ACLB
    I've filled 80L before , it was about 50km after the truck told me to fill up
    Thunder Fist[OP] likes this.
  6. Sep 1, 2017 at 6:08 PM
    #46
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    There's 100% German in my bloodline, and I am an engineer. I have a fundamental need for precision. So yes ... anything I claim is backed up from a several sources, and always subject to refinement in the future.
    I will try to fill up from the E line at the same pump that I calibrate my scangauge to. It might take a while, but I will report back my findings.
  7. Sep 1, 2017 at 6:14 PM
    #47
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Also, the ECU gets screwy around the E line ... so I cannot trust the scangauge reading (it jumps around erratically). I'll just take pictures of my fill receipt and the pump meter. And .. likely 42 other things ...
  8. Sep 1, 2017 at 6:24 PM
    #48
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    SO after the light turns on and drive till is said ZERO miles left THATS when i fill up, and most the time its around 18 to 18-1/2 I put in the tank..
    so there is still 2 1/2 to 3 LEFT in the tank till empty >21.1 tank< (ok folks EMPTY is always when the truck stops moving and you have to get the can out )
    I have Driven about 50 miles PAST the zero to go and way past the needle and put in 20ish in ... (didn't want to go that far) and thats the lowest iv gone with it.
    as i know there is still almost 3 gal left in the tank at "zero"
    My wifes ford focus gets about 10 to 15 MAX past zero to go .. so 1/2 gal in there i think, as it gets around 32 miles/gal
    i want to drop the tank and BEND the arm so E is E + 1/2 gal, - they are trying to help the stupid people that don't know when to get gas and have the tanks OFF by 3 gal....
    call it a reserve if you want but it is still wrong.. read above what E really is... thats like having you speedometer of by 5 to 8 so you don't speed and save gas .. its still not correct ..and not there job..
    anyone know how hard it is to drop the tank?
    and drop the mike.....
    usmc2msu likes this.
  9. Sep 1, 2017 at 6:28 PM
    #49
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    I'm more concerned with where 18 gallons cost $48
  10. Sep 1, 2017 at 7:22 PM
    #50
    David K
    We are the same, I think... I am half German... and the rest is a bunch of other stuff! Anyway, accuracy and precision play a big role when I write about Baja and history! It kills me to find typos in something I have read a hundred times, as well! Always have others read your work before it is printed... I did but still, stuff gets by. The brain plays games with the eyes!
    Anyway, figuring these fuel gauges out and figuring how to explain A-TRAC and the traction controls here on TW has been a major undertaking by me and I know others enjoy the work!
    7r41lbr34k3r[QUOTED] likes this.
  11. Sep 2, 2017 at 7:11 AM
    #51
    weefek
    J
    2017 OR ACLB
    It's a lot more than that here :mad::(:ballchain:
  12. Sep 2, 2017 at 7:41 PM
    #52
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    thats ~20% left....lots of gas
  13. Sep 2, 2017 at 8:56 PM
    #53
    David K
    Keep in mind, that's a second gen gauge.
  14. Sep 2, 2017 at 9:10 PM
    #54
    cesar_taco
    cesar_taco Well-Known Member
    Cesar
    2017 DCSB Off-Road Taco
    Don't we all have auxillary gas tanks mounted on our truck beds?
  15. Sep 3, 2017 at 9:12 AM
    #55
    r1200gs4ok
    O. K.
    Irvine, Ca
    i just filled up me 3rd Gen with 20.60 gallos of fuel...The light had just come on with 27 miles left to empty....had 403.2 miles on that tank with a/c on and in town driving all this tank....thats 19.5 mpg..in town with a/c....i cannot complain about that
  16. Sep 3, 2017 at 10:58 AM
    #56
    David K
    That's scary that the light didn't come on until you were down to just 1/2 gallon left!!!!
  17. Sep 3, 2017 at 1:44 PM
    #57
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I'm guessing there was topping off involved.
    The trucks can take an additional 2+G from the first click.
  18. Sep 3, 2017 at 1:48 PM
    #58
    David K
    It's not how full, but how close to empty that turns on the light. It doesn't know the miles you drove, only the fuel level. Unless that too was changed?
  19. Sep 3, 2017 at 2:30 PM
    #59
    r1200gs4ok
    O. K.
    Irvine, Ca
    Yes. I fill my truck up all the way each and every time. Reason: I like to have it full to better calculate. I agree that it take additional 2+ gal after first click but first click is not calibrated. I find that by doing this I can get cocsistant numbers and feel confident about driving long trip where gas is sometimes hard to find. Knowing what I have left by look at guages and odometer I can mentally calculate how much I have left and how far I can drive. Maybe I am anal but it comes from flying jets in the Marine Coprs. Not too many mobil gas stations up there so you got to believe the instruments.
  20. Sep 3, 2017 at 2:32 PM
    #60
    TheReal_amocaT
    TheReal_amocaT Well-Known Member
    18 in some states... 16/17 in others (*Cough Alabama). Personally I find 21 to be a better bet as they are less immature and you can take them to the bar for drinks without getting arrested!
    PapaBear[QUOTED] likes this.
