How many LED pods can one 20A switch handle?
Discussion in 'Lighting' started by little squirt, Oct 14, 2016.
  1. Oct 14, 2016 at 11:33 AM
    little squirt
    little squirt [OP] 808 ALLDAY!!
    808 ALLDAY!!
    Been trying to google the calculations and I'm a rookie when it comes to volts/amps/watts
    Can 1 of my OTRATTW light switch's marked 20A on the side handle 4 18w led pod lights?
  2. Oct 14, 2016 at 11:43 AM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    A really basic way of calculating this would be "I (Amps)= P (watts) / V (Volts)"
    So of you are running a 12 volt circuit and 4*18w pods=72 watts, then the circuit will draw 6 amps.
  3. Oct 14, 2016 at 11:57 AM
    little squirt
    808 ALLDAY!!
    AHHHH HA! see that's the easy kind of educational teaching I need. Thank you sir! Will be keeping that math calculation in my iPhone notes.
    downhillbik3r[QUOTED] likes this.
  4. Oct 14, 2016 at 2:55 PM
    Sparky2012
    Sparky2012 Well-Known Member
    Oregon
    Tacoma Double Cab 4x4
    Leer 100 RCC canopy, Relentless aluminum front bumper, car seats of my twin minions.
    Just google ohm's law and you should find the chart that has all the calculations. A good general rule is to only load your circuit to 80%.
  5. Oct 15, 2016 at 7:35 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    Also make sure the wiring you use is thick enough support the current (amps) needed to power the lights. To be on the safe side allow 20-25% margin so in this case the wire running from the switch should be able to handle 7.5 amps (6 amps x 1.25 for safety margin). Once the wires branch to off each individual light then that wiring should be able to handle roughly 2 amps for the 18 watt lights you're installing.
  6. Oct 18, 2016 at 1:17 PM
    fergsonfire
    fergsonfire Electrical Guru
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    Agreed! I would not run any lights through the switch. Hook it up to a relay and use the switch as the signal for the relay. If you have lots of lighting look at a bussmann rtmr, there are pre-made ones as an ongoing group buy right now and they are pretty fantastic pieces. Also make sure you have the appropriately sized wire to handle the current you want to put through it. If you want to run 20 amps you should be using 12 awg (american wire gauge) wire at a minimum. There are a number of charts online that show what the appropriate current rating for a wire is. The Coast Guard actually has one of the best out there (and that's coming from a Navy guy). If you have more questions please ask them. Remember there are no stupid questions, only stupid people :rofl:
  7. Oct 18, 2016 at 1:23 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
  8. Oct 20, 2016 at 1:29 PM
    TACO MASTER
    TACO MASTER Well-Known Member
    Maroon 1996 Tacoma SR5 V6 4X4
    OME front and rear suspension, ABR deluxe bull bar, Black FJ 17 inch SEMA wheel with treadwright 265/70/R17 E, Bushwacker fender flares, Stock rear bumper, Eagle 4 wheel camper.
    Hey guys kind of along this thread line...... :threadjacked:
    1) What is a good system for setting up lights and switches in a gen 1 taco?? ie spod...lite-way....xprite
    2) I also have 3 lights on a roof bar what is the best way to run the wires with out drilling any holes??
    Suggestions....ideas...posts to look at for ideas.:fingerscrossed:
