How many light pods with one battery?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJoeBeck, May 16, 2018.
  1. May 16, 2018 at 4:12 AM
    TacoJoeBeck
    TacoJoeBeck [OP] Member
    Joey
    2017 Toyota Tacoma TRD Off Road
    How many light pods can i put on with only using one battery, what do you guys suggest. Thanks!
  2. May 16, 2018 at 7:14 AM
    MontysTruck
    MontysTruck Well-Known Member
    2017 Tacoma TRD Pro
  3. May 16, 2018 at 7:22 AM
    Noob4X4
    Noob4X4 Well-Known Member
    Brandon
    Stock
    .25 might be pushing it
    tcjacado, Coot83, MMoreno16 and 2 others like this.
  4. May 16, 2018 at 7:30 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    My math gets me around 46 as well.
    Sadly that's all stock can achieve.
    MontysTruck[QUOTED] likes this.
  5. May 16, 2018 at 7:32 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Depends if you get a BIG BATTERY!!!!!!!!!!!!!!!!!!!!!!!!!
  6. May 16, 2018 at 8:02 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    The question should be;
    how many batteries can you put on with only using 1 light pod.
  7. May 16, 2018 at 8:08 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Ask this guy;
    Coot83 likes this.
  8. May 16, 2018 at 8:22 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    =JSG=, chris4x4, ChadsPride and 3 others like this.
  9. May 16, 2018 at 10:28 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    This isn't a suggestion type of thing, it's math. Your alternator output and, to a lesser extent, truck wiring capacity determines how much your electrical system can support.
    You could have a pod that runs 5 watts or one that runs 100 watts. Those differences matter far more than simple number of pods. What are you looking to run?
    tcBob, jberry813, ChadsPride and 2 others like this.
  10. May 16, 2018 at 10:36 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    There really isn’t an easy answer to this.
    How many do you want?
    What brand are you looking at?
    How will you wire them?
    How will they be switched?
    How will they be fused?
    Will you use them with the truck running or not?
    And lastly, what is your electrical background?
    Most switches you buy aren’t rated to run the current through them to power a light so you would need to have them connected to relays or another means of activating them (switchpro, s-pod, or relays)
    You’d need to have the power distributed via a fuse block. If you’re looking to add several separate light pods you don’t want to wire them all to the battery.
    Give us more information and we’d be glad to help. There’s a lot of helpful TW members with electrical backgrounds that would be more than willing to help point you in the right direction.
    tcBob, T-Rex266, mjp2 and 2 others like this.
  11. May 16, 2018 at 5:57 PM
    TacoJoeBeck
    Joey
    Im just running two cali ditch lights and I wanna add another two behind the grill thats it though.
  12. May 17, 2018 at 5:13 AM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    You should be fine with the OE battery. You could go with a blue sea 6 fuse block to distribute the electrical for them as well as give you a little room for expansion if you decide to add more accessories.
    Joe23 likes this.
