how many lights off one wire harness?
Discussion in 'Lighting' started by kinkrider101, Jan 26, 2011.
  1. Jan 26, 2011 at 7:33 AM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    So I have my reverse lights all wired in the back off my truck, could I add 2 more lights to the same harness, so it would be 4 lights and one switch?
  2. Jan 26, 2011 at 5:15 PM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    One switch should be fine, but my instructions for my VisionX lights say no more than 2 lights per relay. So I would run 2 relays for 4 lights, and have both relays controlled by one switch. Probably means not using your same harness for a majority of the install....
  3. Jan 26, 2011 at 6:35 PM
    kinkrider101
    santa barbara
    wheels and tires
    I have no experience with relays, I have 4 offroad lights and none have relays
  4. Jan 26, 2011 at 9:53 PM
    scollins
    Scott
    Renton WA
    Ah, I see. Well, as long as you wire the lights properly (parallel), and the gauge of the wire and the switch is sufficient to handle the current, I don't think it should be a problem.
    What wattage are your lights? If I assume 35w each, you are running just shy of 3 amps at each light. With 4 lights in the circuit, you are looking at 12 amps through the wires and switch. Probably should be 10 gauge at a minimum, but as the length of the run increases, so should the gauge. If there lights at at the back, I'd probably want 8 gauge wires at least....
    But I didn't stay at a Holiday Inn last night, so value my advice at what you paid for it..... ;)
