How many miles are on ur Tacoma, & what all have u had to replace?
Discussion in '1st Gen. Tacomas (1995-2004)' started by devilsalmostfree, Jul 2, 2009.
  1. Jul 31, 2012 at 11:31 AM
    #241
    AZG1ANT
    AZG1ANT Member
    Arizona
    2004 Tacoma Double Cab TRD SR5 3.4l Auto V6
    Nothing yet...that's why I'm here.
    I'm amazed by how reliable the Tacoma is. I just bought a 2004 TRD/SR5 DC 2wd and love it! It has 99,650 on it and the damn thing runs like it just pulled off the dealership lot. It's my first Toyota by the way and I hope it lasts me at least 300k. One thing I've noticed in most threads I've encountered like this one was that nobody seems to mention replacing the timing belt (suggest at 90k). Mine has yet to be done and I'm wondering if I should have it done now or see how far I can go before it needs replacement. Can I cause harm to the truck if I wait it out? I know what a bad timing belt feels like so if I do feel it I will take it in immediately.
  2. Jul 31, 2012 at 11:37 AM
    #242
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    05 83k miles. I havent repolaced anything yet. I bought it at 76k and it runs like its new. I do have warranty on it till 150k or 6 yrs.
  3. Jul 31, 2012 at 11:39 AM
    #243
    Death_Stalker
    Talha
    Cypress, TX
    2018 4Runner LE
    you dont want to risk it. Its better to replace it before it breaks. If it breaks it can cause damage to other parts. Its best to replace it because it can cost a lot more after it breaks.
  4. Jul 31, 2012 at 4:03 PM
    #244
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    As far as I know, the timing belt won't give warning, it will just snap one day and you're stuck. I don't know much about the 6 cylinder engine but some types of engines will be destroyed by valve to cylinder contact if the timing belt breaks.
  5. Aug 1, 2012 at 9:02 AM
    #245
    michael knieff
    michael knieff Member
    Michael
    NorCal
    White TRD Off Road
    TRD Sport Door Handles and Grille, Leer Shell, 2016 TRD Sport Wheels, P265/70R17
    I hope this helps to clear up the timing belt discussion. The timing belt will break if not replaced. You can't tell that its about to break without doing a visual inspection. The belt will usually shows signs of cracking but not always. Sometimes it just breaks. Its preferred to replace it with an OEM belt because it has marks for both cams and the crank. As for damage to the engine, timing belt breakage will not damage it as it is a non-interference engine. That means the valves will not come in contact with the pistons. If it is a 4 cylinder then it has a timing chain not a belt. Again I hope this helps.
  6. Aug 1, 2012 at 9:26 AM
    #246
    IrmoRabbidMoose
    IrmoRabbidMoose Well-Known Member
    Jay
    Irmo, SC
    2003 SR5 Debadged 4x4
    tool box, tint. (Soon to come... HID's, Mud Terrains.)
    I did mine myself and it's very time consuming. However, not too difficult. I replaced my belt, water pump, camshaft seals, and crank seal and flushed and put new coolant in it. I did mine around 96k. There's plenty of DIY threads if you're interested, but to settle it, the 5VZ-FE (3.4L) is a non-interference motor which means if the belt were to pop, then the truck would just shut down and wouldn't start back up until you've replaced it. Hope this helps. :D
  7. Aug 2, 2012 at 7:20 PM
    #247
    71burton
    71burton Member
    McMinnville, TN
    1999 tacoma 96 hybrid
    I just clocked over 200k. Has several new parts since I bought it as a wreck. My uncle has a 96 taco and it has 533,000 miles on it.
  8. Aug 17, 2012 at 3:33 PM
    #248
    aldoraine
    aldoraine Well-Known Member
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    210k. Only part that has failed and had to be replaced was the starter, twice. Other than routine maint, (plugs, wires, oil, ect) nothing else has failed. Being a California truck helps a little I'm sure!
  9. Aug 17, 2012 at 4:56 PM
    #249
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    My '07 has 43K and the only thing I've replaced is the battery...along with wiper blades, tires and all the fluids and filters during routing maintenance.
    My '12 has 3,850 miles and haven't replaced anything, yet, and hopefully won't have to for a long, long time.
  10. Aug 17, 2012 at 5:05 PM
    #250
    No Rangers Here
    No Rangers Here Well-Known Member
    jordan
    apple valley
    02 prerunner trd off road
    k&n filter, window tint (limo) sway bar removed metal prerunner bumper
    130k and still running strong only thing i have replace is my brakes
  11. Aug 17, 2012 at 9:33 PM
    #251
    1998triton
    1998triton Well-Known Member
    Matthew
    TN
    98 SR5 TRD
    My 1998 has 237xxx. Just routine maintenance. Sway bar bushing is it
  12. Aug 18, 2012 at 3:31 PM
    #252
    06texasedition
    06texasedition Well-Known Member
    Picayune ms
    06 Tacoma Texas edition(RIP) 14 tundra limited 4x4
    3" rough country lift. Blue interior lights courtesy of jumper led. Led tail lights avid front and rear bumper guard with 4 Hellas on front. Borla dual exhaust blue led reverse lights color matched satoshi grille
    195k replaced original clutch tire rods ilder n Pittman arms fuel pump wire inside fuel tank
  13. Aug 18, 2012 at 6:59 PM
    #253
    jamestkirk
    jamestkirk Well-Known Member
    Moab Utah
    1999 Pre Runner 2017 TRD OR
    '99 pre runner 205,000mi 3.4l V6
    sparkplugs
    k&n air filter
    routine oil changes
    that's it, but not for long. about to do some maintenance and suspension work.
    kirk out
  14. Aug 21, 2012 at 6:24 PM
    #254
    Toyota-Dually
    Toyota-Dually Member
    David
    Holden Massachusetts
    TRD 4x4
    206534 on my 03' DoubleTaco TRD. Only thing other than brakes and exhaust is that I busted off something on my flywheel (from hauling too much).
    This is a typical load - scrap steel going to the recyler:
  15. Dec 8, 2012 at 3:08 PM
    #255
    kevinjen
    kevinjen Member
    Kevin
    west virginia
    03 tacoma TRD SR5
    gray wire mod Rhino lined front bumper
    101,000 miles on my Taco an so far just the 02 sensor,tires,wiper blades an the headlight bulbs
  16. Dec 8, 2012 at 3:16 PM
    #256
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    2002 2.7 with 204000miles so far and going strong
    both o2 sensors
    frame recall
    front and rear brakes
    both side cv joints
    cat back exhaust
    whole rear drive shaft (got a tom woods one piece)
    then normal wear and tear stuff like tires, plugs, air filter, and stuff like that
  17. Dec 8, 2012 at 4:51 PM
    #257
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Now have 178k & replaced 1 toasted auto trans....
  18. Dec 9, 2012 at 10:07 AM
    #258
    Buy1Get1Freee
    Buy1Get1Freee HERP DERP
    PEI
    2001 Tacoma TRD
    Grey Wire Mod, Bilstein 5100s, Eibach Coils! 255/85/16 KM2. DDM HID 35W 6000K, Homemade Rear Bumper, Trail Gear Rock Sliders
    352K and still runs perfect.
    Water pump,timing chain, 2 o2 senors, diff seals, and the regular wear and tear stuff.
  19. Dec 9, 2012 at 10:11 AM
    #259
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Ho le piss......^^ i am at 291k nothing major
  20. Dec 9, 2012 at 10:14 AM
    #260
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    47,000 miles... no out-of-pocket repairs. Dealer replaced blower motor under warranty for ticking noise... that's all.
