How many miles are on ur Tacoma, & what all have u had to replace?
Discussion in '1st Gen. Tacomas (1995-2004)' started by devilsalmostfree, Jul 2, 2009.
  1. Dec 11, 2011 at 6:24 PM
    #161
    Jacques
    Jacques Member
    Bham, AL.
    stock
    03 4x4 extra cab - 54,900 miles - battery. Bout to get new tires though.
  2. Dec 11, 2011 at 6:32 PM
    #162
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    107k, replaced spark plugs and timing belt (regular maintenance) and break rotors (didnt raise the break proportioning valve when it was lifted and warped my rotors).
  3. Dec 11, 2011 at 7:34 PM
    #163
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    115k on the odo.
    And I've broken 3ish parts.
    BUT!!! Here's how it went down:
    Had a 1999 with 90K on it, it got totaled.
    Bought a rolling 1995 chassis and cab with 40K on it.
    Put the two together in 2009.
    Titled as a 1995. Engine and Drivetrain from 1999.
    Since I've started driving it I've put 25K on it.
    All of this has happened:
    I've changed the fuel pump, which was already on the 1995, and sitting in the yard for got knows how long. So... I blame that on not being used for years.
    I also replaced the steering rack, which was also part of the 1995. And I'm pretty sure I'm the one that broke it. :D
    In the process of replacing the rack, I broke the clockspring in the steering column... So yeh...
    1. Fuel pump
    2. Rack
    2.5 Clockspring because I'm a dumbass.
    I'd say all things considered... I'm doin allright. :)
  4. Dec 11, 2011 at 7:43 PM
    #164
    LarrysWorld
    LarrysWorld 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    my 98 taco has 395,100 miles and ive changed,
    radiator
    head gaskets
    tires
    flywheel
    water pump, i believe thats it.
    still running strong.
    need tips on how to make it stronger and better looking hahah
  5. Dec 17, 2011 at 12:09 PM
    #165
    TastyHuman
    TastyHuman Oh. Bummer.
    The front shocks on my 07 Tacoma with 85k miles last 10-11 months and then blow out. That was true for the originals and also for four sets of KYBs. The KYBs were replaced under warranty but changing them got old so last time I sprung for Bilsteins. Hopefully they last longer. I drive 10 miles on a rough gravel road each day so am hard on shocks but this was nuts, we haven't had this problem with other trucks. Maybe the strut design causes overheating of the cartridge.
  6. Dec 17, 2011 at 12:38 PM
    #166
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    76K and change. I can't believe that the factory Bilsteins are blown to bits with such low miles. I already order a set of 5100/5125 and as soon I get to FL I'll replace them.
    The dealer I bought my Taco from, replaced the coolant, power steering fluid, brake fluid. I'll probably be doing the rear diff, transfer case and tranny for peace of mind.
  7. Dec 19, 2011 at 8:48 AM
    #167
    Tacoma420
    Tacoma420 Well-Known Member
    Forrest
    Placerville CA
    17 4x4 Tacoma Off Road
    Well i guess ill hop on in this.
    I own a 99 prerunner.
    Owned it since its had 70k on it, and now its soon to hit its 200k mark :eek:
    So far, i have replaced quite a bit, but its been a great runner.
    First thing that went out was the starter, soon as i got it, like 2 weeks later the starter took a shit, along with a noise in the rear end. Turned out it was the differential and toyota covered it to get fixed.
    The normal brake jobs, 1 time of getting new rotor's, the normal sparks, tires, wipes, belts, oil, ect. Things we all get for normal service.
    4 windsheilds, 3 breaking from tailgating on the freeway, 1 from having the truck vandalized while @ a concert. Along with the driver side window that had to get changed.
    Center dash got replaced with all factory Toyota oem plastic shit. Since the people trying to steal the shit totally failed and couldn't even get the stero out, just broke some plastic.
    Around 150k i got the first timing belt change on the truck, and the belt looked as new as the one in the package.. not even sure why i was changing once i seen it.
    Then around 165,000 miles, the truck completely lost power. Going up hills or any grade at all it would chug along, then miss before it would downshift.
    Got very worried about the tranny, but i tried to find the issue. Went into a few different shops, got plugs, they checked compression, it was all good and they ran tests on it. Couldnt find anything.
    So i said hell with it, if they cant see whats wrong, ill just deal with the miss until something breaks.
    Around 190,000 miles, 25k later after the missing, still having the problem..
    Bring the truck into toyota to get a fan clip that holds the plastic together, and when the mechanic came out to just throw it on quick, he looked at the the spark plug wires, and told me "Great toyota eh?". When i asked what he meant, he pointed out that the spark plug wires had "1998" written on them, showing they were made in 98, and put in the truck the first yr it was out, 1999.
    Well, That means those wires lasted 190,000 miles, and many many yr's. Soon as i heard that, walked back in toyota, bought wires, had em changed, and its felt like a whole new truck with a ton of power, and never misses or chugs at all.
    Then i got the shocks/struts changed. Made it ride alot better.
    Also at the same time, i got the steering rack done, because it was leaking some fluids, and was very loose and made the tires have bad wear on them.
    Turned out nice after putting all the suspension work into it, then getting new tires. felt like a whole new truck with 190k on it.
    Well, After all that, i had no more complaints, everything worked as it should.
    Went and got the U-joints changed to try to stop a noise i hear, but that didnt work.
    And then ofc the theifs come back along, and decide to hit up my town for all our toyota trucks cata converts. which all of us toy owners of the taco's know that its a big thing to steal those converters for the cash they make in platinum.
    Well, go to start up truck, loud as hell, look down, and see 4 foot of exhaust pipe cut out, o2 sensor and all. So i make the report with local PD for the report for insurance, and insurance paid for new exaust from the head, to the
    tail pipe, gave us a whole new toyota muffler and all, done by the toyota dealer.
    $2600 it costed for the insurance company, thank god for 250 deductible.
    But yeah, here are the moron's that stole my cata converter. http://blogs.sacbee.com/crime/archives/2011/04/catalytic-conve-1.html
    After all that, just the normal old maintenance, changing fluids, ect.
    No problems since, knock on wood, and hope the best for my taco. hitting the big 200k here in a few.
    All in all, its been a great truck, and does its job. Always been a toyota owner, always will be one.
    Their parts may cost more, but overall, its worth it for the great vehicle.
  8. Dec 19, 2011 at 9:03 AM
    #168
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    93.5K (2006)
    Owned since new. Regular maint. items only, with one exception. I replaced the serp. belt just because it made me feel better... Oh, and 2 sets of brakes.
  9. Dec 19, 2011 at 1:00 PM
    #169
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    im at 193k and ive gotta change the valvecover gaskets i plan on doing that as well as new plug wires that are stock with 193k:D and change trans fluid then the diff fluid.
  10. Dec 19, 2011 at 1:01 PM
    #170
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    80,000 miles plus..only thing I've replaced is oil!!!!
  11. Dec 19, 2011 at 1:03 PM
    #171
    Madjik_Man
    Colorado Front Range
    1998 Xcab TRD 145,000
    Timing Belt (at 125,000... I know, I know)
    Water pump (same ^)
    Tires (once)
    Throttle Position Sensor (at 105,000)
    Shocks (at 125,000)
    Brake Pads (at 85,000)
    Oil (every 5,000)
    Windshield (twice - gravel on mountain passes chew the glass up)
  12. Dec 21, 2011 at 3:49 AM
    #172
    SideStepTaco
    SideStepTaco Member
    California
    03 PreRunner SR5
    2003 33.5k.
    New driver side door lock. Some bastard used a screwdriver and hammer and broke into the truck...to have a smoke.
    Eventually a new A/C compressor. Was overseas when a bigger truck hit my truck and bent the front bumper and killed the a/c.
    Eventually a new antenna. Someone stole it.
    Full size spare replacement. Out of state and someone stole it.
    Tire repair/replacement. Had a flat tonight. Luckily work had an air pump. Not sure what it'll be like in the morning.
    Oh, and the third cup holder with the clamps is semi broken.
  13. Dec 21, 2011 at 5:15 AM
    #173
    Tacomanater
    Tacomanater Well-Known Member
    Washington County, NY (VT Border)
    '02 SR5, 4WD, V6, 5Spd
    JBA headers & exhaust, new cats, K&N CAI, new shocks, 2.5" lift, Prodigy P2, Timbren, snobord552 light bar (v.2), KC off-roads and Hella fog lights, Teflon A/R ATX 16" Ledge, Nitto Terra Grappler, (265/75R16's), ultragauge, curt roof rack on thule set-up.
    '02- V6, Xtra, 4WD w/174K, replaced the usual consumables, (battery, brakes, tires, spark plugs, filters, etc.), second time for water pump and timing belt, also had to replace 02 sensor, cats, then added headers, K&N CAI, exhaust system (mine had a pinhole due to rust/rot), shocks (F&R), a lot of this was done when I had the TSB frame recall work performed, windshield (once recently, plus new one now has a small "star" in it), cup holders are broken....but I would have to say this baby seems bulletproof!
  14. Jan 7, 2012 at 11:52 PM
    #174
    Olysouthpaw24
    Olysouthpaw24 New Member
    1999 4x4 i4 5 speed
    320,000 miles
    2 exhaust manifolds ($200/each)
    Standard filter and fluid replacement intervals
    Original clutch. Original breaks. Burns zero oil.
  15. Jan 8, 2012 at 4:58 AM
    #175
    abn2060
    abn2060 Infidel
    N Florida
    2014 Tacoma OR 4x4
    Stock
    111K and had to replace the battery 3 times. Other than that I just keep up with regular maintenance.
  16. Jan 8, 2012 at 6:19 AM
    #176
    Shikkapow
    Shikkapow Active Member
    Sunny Florida
    01 sr5 4x4
    '01 4x4 5 speed 150k. one battery, front brakes and rotors, (rear brakes look new:confused:), o2 sensor, front and rear shocks,and the shifter bushing
    the little pop out windows in the back (xtracab) are both broken and don't lock closed very well, and the seatbelts dont retract worth a damn.
    other than that, solid.
  17. Jan 8, 2012 at 11:10 AM
    #177
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    i got my truck with 155K miles last year..... it has 190k on it now "/ and i really haven't done nothing to serous yet. of course when i got it it had so many problems that i had to fix like, the knock sensor, spark plugs, rear shocks, tires, ball joints & tie rod ends along with the rack & pinion bellows, u-joint, one of the rear axle shafts was bend so i had to replace the shaft, alternator twice now but because i have a sound system and i rock everytime i drive. and thats it, sounds like alot but because the last owner didnt take care of the beauty so now that i have it shes running like a champ and no problems.
  18. Jan 8, 2012 at 11:12 AM
    #178
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Must be all highway miles to have the original front pads...
  19. Jan 18, 2012 at 10:55 AM
    #179
    hdben
    hdben New Member
    96 Taco, 238,00 miles. Replaced cracked exhaust manifold @ 215K changed the cat too, broke a ball joint @ 225K so I replaced uppers and lowers along with tie rod ends. Decided to replace wheel bearing this week @ 238K. 2 sets of brakes. Clutch replaced at 195K (that's the last time I try to drag a 28' palm tree). Valve cover is weeping now. Burns no oil...
  20. Jan 18, 2012 at 10:56 AM
    #180
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Rack and pinion is done at 176,000 :(
    Probably from running 12.5'' wide tires its whole life.
