how many miles are on your guys v6's
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacosuprem, Aug 27, 2010.
  1. May 22, 2012 at 5:47 AM
    #241
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    It's you rear main. Mine started to leak at about 100K. I replaced it at 290K.
  2. May 23, 2012 at 6:39 AM
    #242
    IrmoRabbidMoose
    IrmoRabbidMoose Well-Known Member
    Jay
    Irmo, SC
    2003 SR5 Debadged 4x4
    tool box, tint. (Soon to come... HID's, Mud Terrains.)
    Absolutely don't mess with it. Even though it's a Toyota, GM says that if your tranny has over 100k the fluid has developed a certain wear pattern and once you flush that oil and put the new stuff in it'll throw off that wear pattern. I'd probably leave it unless you plan on rebuilding the transmission. I've known way too many horror stories about people changing their transmission fluid after 100k and then having to look for another one.
  3. May 24, 2012 at 6:19 PM
    #243
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    163400and climibing. but the v6 and auto trans never disappoints
  4. May 24, 2012 at 6:20 PM
    #244
    Asta
    Asta Hold My Beer and Watch This
    Daniel
    Kings Bay, Ga
    2014 DCSB Tacoma TRD OFF-ROAD
    how in the world do you only have 30,500 did you miss a 0 or something?
  5. May 24, 2012 at 7:11 PM
    #245
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    You sure you have correct info? Sounds like bullshit to me. Fluids developing a "wear pattern" Maybe you're mixing up things like tapered roller bearings with trans fluid? Fluids break down and lose their film strength over time. The additives also break down over time and slowly stop doing there job.
    I'd change it without a doubt. If the trans is on it's last legs and the friction materials are worn though, then yes, putting new properly functioning slippery atf in may make steel on steel slip against one another because there's no more friction material left and the old fluid worked so poorly that it allowed the steel on steel to not slip, but that's a different animal.
  6. May 24, 2012 at 7:58 PM
    #246
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I wasn't sure about the wear pattern statement either. What I have heard, though, is that new fluid can have somewhat of a 'detergent' effect and possibly dislodge some gunk that could give you trouble. This gunk is typically left undisturbed by the old fluid which has lost it's cleaning properties.
    I have no source on that info though.
  7. May 24, 2012 at 8:06 PM
    #247
    Honda650
    Honda650 Member
    Fort Worth, Texas
    08 DC TRD 4x4 SB
    DE-BADGED, Billies @.85, TSB Leafs, TRD Seat Covers, TRD Cat Back Exhaust, Seat Belt chime mod, pop lock. BFG AT 265/75/16 Load Range E, Front Mud Flap Off! Alpine INE-S920HD, AFE Pro Dry S Filter,Access LE Tonneau Cover
  8. May 24, 2012 at 8:14 PM
    #248
    Gooch
    Orange County CA
    Here's a source...maybe not a good one...but they are describing in more techical terms what I was referring to:
    When the fluid is burnt up and dirty, by replacing the fluid with fresh fluid full of detergent and cleaners, the debris becomes dislodged and naturally finds its way to the control mechanism called the valve body. The other thing that happens is the new fluid with detergent can loosen the glue that holds the clutch plates and band material that holds them to their backing plates. The goal here is to flush the transmission BEFORE the fluid gets damaged. If you have the insight to keep the fluid changed then the fluid will never change color or become burnt, which is why a strict maintenance schedule needs to be implemented and followed.
    http://www.advancedtransmissionsonline.com/dos and donts.htm
  9. May 24, 2012 at 11:23 PM
    #249
    shampoop
    southwest WA
    Confirms what I said. Do it before it gets bad. Once it's badly burnt the damage has been done and you're already screwed.
  10. May 24, 2012 at 11:27 PM
    #250
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    roughly 6700km :p
  11. May 25, 2012 at 4:33 AM
    #251
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    6700km = 4,163??? New???
  12. May 25, 2012 at 9:25 AM
    #252
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    71K Miles
  13. May 25, 2012 at 9:46 PM
    #253
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    150k on the 3.4l. It runs really clean.
  14. May 26, 2012 at 7:43 AM
    #254
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    156,000 Runs great. Bought it with 149 k. Last tank of fuel was 21.57 mpg
  15. May 26, 2012 at 7:55 AM
    #255
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    49,629 still fresh low mileage for a 2007
  16. May 27, 2012 at 12:14 AM
    #256
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    haha yea, oops 2nd gen :p
  17. May 27, 2012 at 12:28 AM
    #257
    TacomaGuy22
    TacomaGuy22 That deserves to be put in the cool story jar..
  18. May 27, 2012 at 12:31 AM
    #258
    apierce7565
    apierce7565 I eat terrorism and crap freedom!
    Anthony
    Fort Bragg, NC
    2004 Toyota Tacoma SR5 4x4 standard
    ARB Safari snorkel, snug top, snug rug, yakima rack bars, ARB front bumper, plasti-dip camper shell windows, sway bar removal, turn signal reposition, led dome lights, recon smoke roof cab lights, 8000k xenon HIDs, 5100 Billy coilovers and rear shocks, tundra leafs, 3 inch lift rear shackles, 315/75-16 Bfg km2, 16"/8" Eagle Alloy 100 series black wheels, grey wire mod, deckplate mod, diff breather mod, Rola roof rack with tire carrier, trimmed front and rear fenders
  19. May 27, 2012 at 12:43 AM
    #259
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    109000
  20. May 27, 2012 at 12:47 AM
    #260
    JGCarballo13
    JGCarballo13 Member
    James
    91765 DB
    07 TRD 4x4 Tacoma long bed
    Total Chaos upper control arms Donahoe 2.5 coil overs LED map light and dome light SpiderTrax 1.25" Wheel Spacers in Front 4WD Differential Drop Jardine muffler K&N intake HID headlights Damello sliders custom KC light rack
    i have 80,650 still going strong my truck goes everywhere
