How many miles are on your Tacoma? Do they last?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by swb2121, Apr 13, 2018.
  1. Apr 13, 2018 at 10:50 AM
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    113,382 miles currently on my 2012 4cyl 5 speed just have to keep up with maintenance. Also have a 1999 4runner with 360,000 miles
    SecureIT2021 likes this.
  2. Apr 13, 2018 at 10:58 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Proper maintenance and your future son will inherit the truck.
    ToyoTaco25, Ezriderga and 1Shifter like this.
  3. Apr 13, 2018 at 11:03 AM
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    I bought a 2000 Taco new and put 280,000m and still had original clutch and transmission when I traded! Living on an island at the beach for about 14yrs of its life took its toll!
    My dad had an ‘87 4Runner he bought new and sold it for more than what it was worth at 300k.. I was pissed because he new I wanted it! Last time I saw it on the road was last year..
    ToyoTaco25 and SecureIT2021 like this.
  4. Apr 13, 2018 at 12:11 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Listen to Tacoma Mike, with proper maintenance and common sense your Tacoma will last a long time
  5. Jun 3, 2021 at 4:06 PM
    Scott54
    Scott54 Member
    Scott
    1997 Tacoma
    308,000 and still getting 22 mpg
    ToyoTaco25 and b_r_o like this.
  6. Jun 3, 2021 at 4:17 PM
    kjttaco
    kjttaco Well-Known Member
    Ken
    NJ
    2020 Black Limited
    7,012 miles and no problems yet
  7. Jun 3, 2021 at 4:19 PM
    Truckntran
    Truckntran Well-Known Member
    1996 and 1998 Tacoma 2wd
    High mileage work trucks
    What will kill your Toyota is rust. Everything else will last forever with proper maintenance. Well maybe the seats might be a little tattered looking after a million miles. If you like the truck do what you can to keep the body and frame clean and dry. Including blowing out debris from places most folks don’t bother with. (On my first gen, behind lower fenders and inside the frame)
    wi_taco and PennSilverTaco like this.
  8. Jun 3, 2021 at 5:59 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Exactly 133,440 miles on the clock as of this post; Owner the truck since new with 20 miles on it and have to replace the master cylinder and A/C evaporator, but no engine problems to speak of!
  9. Jun 3, 2021 at 6:31 PM
    Tacoman48
    Tacoman48 Active Member
    Bobby
    MA
    2014 Black Access Cab
    Lift, Wheels, Tires, KC fogs, and others
    2014 with 75k. Keep it rust-free and you are fine. Just see what Top Gear and Whistlin Diesel did to the Hilux, the same engineering went into our trucks.
  10. Jun 3, 2021 at 6:35 PM
    skigan
    skigan Well-Known Member
    Utah
    2009 Timberland Mica SR5
    223,000 miles on my 2005 4cyl 5spd. Usually it's the rust that gets them so do your rust prevention and you'll be fine!
    PennSilverTaco likes this.
  11. Jun 4, 2021 at 11:44 AM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    I see snow on the ground. I read "Colorado". I think "salt". So, your truck probably won't last very long.
    In all seriousness, it's going to rust away before it fails mechanically if you give it anything like routine maintenance. If you go to extreme lengths to clean and rust-proof the frame and body, then you'll greatly extend the life of your truck.
  12. Jun 4, 2021 at 12:27 PM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    Keep her clean and follow the maintenance schedules.
    My truck is at 75k
    My coworkers 2005 is at 325k with only an alternator going bad.
    My brothers 1st gen is at 350k. Only had to replace the steering rack and pinion. He is in colorado too.
  13. Jun 5, 2021 at 4:13 PM
    Soulstice07
    Soulstice07 Well-Known Member
    Granite Falls, WA
    2010 TRD Off Road
    6" Pro Comp lift KMC 17x9 XD137 FMJ Wheels 35" Mastercraft tires Custom Bilstein extended length adjustable coilovers 700lb Eibach springs Bilstein rear shocks DV8 Off Road front bumper Custom skid plates/armor Smittybilt 10klb winch Cali Raised LED sliders Cowl air induction ABS kill switch Rear air ride suspension Trailer plug relocate Clazzio leather seat covers Various lighting mods
    My 2010 Off Road recently hit 100,000, finally just broken in. My brother had a first gen and at one point I found out he had not done an oil change for two years, about 20,000 miles. Truck was running fine. We went out to do an oil change, drained the oil, it came out like black honey. Finished the oil change, didnt run any different. He continued to drive it up to about 375,000 miles and sold it, it was still running strong. Apparently you done even have to maintain them and they will still last. Best trucks on the planet!!
  14. Jun 5, 2021 at 9:00 PM
    Oldsalt73
    Oldsalt73 Member
    William
    2007 taco
    Bed deck, back seat deleted
    2007 4.0 DC 265,000. Replaced the alternator today. She runs great shit mpg but thats to be expected
    ToyoTaco25 likes this.
  15. Jun 5, 2021 at 9:03 PM
    #35
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    130,xxx
  16. Jun 5, 2021 at 9:15 PM
    #36
    A Florida Man
    A Florida Man Well-Known Member
    NW Florida Gulf Coast
    ‘13 Tacoma Limited Double Cab
    I’ve owned my 2013 Tacoma Limited almost 3 months and it turned over 100,000 miles a week or so ago. It’s double cab 4.0 6 cyl 4x4. Street only so far...hell, I don’t know where around my parts to even go off road.
  17. Jun 5, 2021 at 9:19 PM
    #37
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    2008 Tacoma base truck
    I purchased my ‘08 Tacoma from the original owner last year and he always took it to the dealer every time it was ready to be serviced. He gave me all the paperwork showing everything he had done to it since he bought it new. As someone has mentioned, keeping the truck maintained will add life and value to it. BTW, it only has 413,000 miles on it and it rides and drives like a new truck. 36C535D8-85DF-40F0-9715-CDBC0F47E337.jpg
  18. Jun 5, 2021 at 9:59 PM
    #38
    SecureIT2021
    SecureIT2021 Well-Known Member
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    @swb2121 I've got 314,790 miles on my 99 Tacoma 4x4. I bought it in 2004 from a Lt. Commander stationed in S.C. It had 97,000 miles on it. I've had one mechanic to work on my truck and his name is Frank Goodwin - he owns Goodwin Automotive and he only works on Toyotas. He's someone I like, trust and respect. I always get parts from the dealership - no modifications; I take off what's gone bad, put the exact replacement on and keep it moving. Bottom line - Toyotas are built to last - period. Take care of it and it will take care of you.
  19. Jun 5, 2021 at 10:36 PM
    #39
    DIRRTY_BOII
    DIRRTY_BOII Active Member
    Joey
    2006 TACOMA TRD OFFROAD
    2006 Prerunner
    196000 and still kicking ass !
  20. Jun 5, 2021 at 10:41 PM
    #40
    SecureIT2021
    @A Florida Man Would like to get a 4 door someday. Prefer 5 speed manual V6
