How many miles before you had to replace rear brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marcus Israd, Nov 28, 2018.
  1. Nov 28, 2018 at 11:49 AM
    Marcus Israd
    Marcus Israd [OP] Well-Known Member
    Concord, CA
    09 TRD Sport SR5 4x4
    2009 Tacoma 4.0L Double Cab 4x4 Pyrite Mica Front: Yukon 4.88's ARB Locker Bilstein 5100's/Eibach Springs Camburg Uni-Ball UCA's Solo Motorsports Steering Rack Marlin Crawler LCA & Frame Braces Wheel bearings/Hubs by "05taco4x4" Crown Extended SS Brake Lines Stoptech Cryo Slotted Rotors/TRD Pads Wheeler's Super Bump Stops Rear: Yukon 4.88's ARB Locker Bilstein 5125's/All-Pro Expo Leaf Springs Ruff Stuff U-bolt Flip Crown Extended SS Brake Lines Timbren Bump Stops Intake/Exhaust: TRD CAI w/ AFE Dry-Flow Filter & TRD Exhaust (cut at axle) Lighting: Ultimate Headlight Upgrade by "crashnburn80" Fog light anytime mod Baja Designs S8 20" Light Bar Baja Designs Squadron Pro Fogs Armor: Pelfrybilt Steel Front Bumper BAMF Steel Skid Plates BAMF Weld-on Rock Sliders BAMF Front Bumper Supports Wheel/Tires: Pro Comp 17"x9" Wheels (x5) BFG KM3's - 35/12.5/17 Recovery: Warn M8000s Winch w/ Synthetic line Misc.: SoftTopper Ultra-Gauge Hurst T-handle Shift Knob Energy Suspension Urethane Radiator Support Bushings Pro Eagle Jack Midland CB Pine Tree Air Freshener Fluids: Amsoil
    Just curious when your rear drums wore out and what all did you replace when you did them?
    Alexely999 likes this.
  2. Nov 28, 2018 at 11:55 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I’m at about 90,000 miles. Rears still going strong. Fronts replaced 2 or 3 times.
    inwood customs likes this.
  3. Nov 28, 2018 at 11:59 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    112,000 miles, rear drums are starting to run low, but still within serviceable limits. I’ve replaced the fronts twice.
    Alexely999 and inwood customs like this.
  4. Nov 28, 2018 at 12:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    If the rears are kept clean and adjusted they should last at least 2x the front. Which for me normally means 100k or better.
    When they need replacement, I do all the internals, including the cylinders. The drums are totally dependent on their wear/grooving/lipping. Most times yes, but not always.
    Skyway, Norton and PackCon like this.
  5. Nov 28, 2018 at 12:45 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I’m at 101k and mine still look good
  6. Nov 28, 2018 at 1:13 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I did mine at 90K, they were still in decent shape,but had them done at the same time my fronts were being done the 2nd time. I'm at 192,000 and probably close again.
  7. Nov 28, 2018 at 1:32 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    I agree, cylinders are cheap and avoid the eventual failures.
