How many miles between oil changes??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjreynolds, Mar 23, 2010.
  1. Mar 23, 2010 at 7:51 PM
    rjreynolds
    rjreynolds [OP] Active Member
    2wd 2.7l
    I drive an 08 taco 2wd 4 cyl. I live in North FL, and drive approx 3k miles a month. I use it 6 days a week for work. I use Mobil One 5w-20 synthetic. I have been using a fram oil filter. Will switch to K & N next change. A friend says I should be able to go 15k-20k miles. I have been changing it every 5-6k miles. How many miles can I drive approx between oil changes?.
  2. Mar 23, 2010 at 8:03 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    5,000 miles is the recommendation in the owners manual.
    I use Mobile 1 and I change mine every 5,000 miles.
    Some folks will have their oil tested to see if the oil is still good enough to run for longer than 5,000 miles (I'm sure those folks will chime in).
    Personally, at 5,000 miles...the oil that comes out of my truck is really dark/dirty. I'm more than happy to spend the $$ and change it every 5,000 miles.
  3. Mar 23, 2010 at 8:41 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    I change mine every 3 months or 3,000k...whichever comes first. I'd say I could wait longer, but thats just how I've always done it and always will.
  4. Mar 23, 2010 at 9:24 PM
    nick11
    nick11 Member
    07 Prerunner
    3" lift, full stereo system with 2 amps and sub behind the rear seat.
    I use mobil one oil and thier filter. This setup is supposed to go 12,00o miles, but I change mine every 6,000.
  5. Mar 23, 2010 at 9:26 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i wouldnt be able to keep my oil in for 6k miles, i feel bad for the truck when i leave it a little over 5k
  6. Mar 23, 2010 at 9:29 PM
    dee_bo
    dee_bo Well-Known Member
    DFW
    2007 TRD Sport Tacoma
    None yet
    I bought my truck used...how do I know if it has synthetic or regular oil. After purchased I changed it with regular 5w-30 Valvoline
  7. Mar 23, 2010 at 9:30 PM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    10k I use mobil 1 oil and filter.
  8. Mar 23, 2010 at 9:32 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    I use Mobil 1 5W-30 my oil change light went off so its time for new oil...
  9. Mar 23, 2010 at 9:32 PM
    Wolfman
    Wolfman Well-Known Member
    Paradise, TX
    2010 PreRunner SR5
    My manual says 5k miles. I'll be going with that interval. I'll miss GM's oil life monitor that told you when it was time.
  10. Mar 23, 2010 at 9:34 PM
    08pretaco
    Oliver
    az
    do you care what it has? it shouldnt matter if your running reg or synth when its time just put in whatever you want to :thumbsup:
  11. Mar 23, 2010 at 9:35 PM
    08pretaco
    Oliver
    az
    ours tell us when its time too, its called the maintenance required light :)
  12. Mar 23, 2010 at 9:38 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I use Pennzoil Platinum full-synthetic 5W-30 and change mine every 5K with the Toyota OEM filters.;) So far so good!!:D
  13. Mar 23, 2010 at 9:39 PM
    tekshark
    tekshark Member
    James
    Northern Nevada
    2009 super white xcab trd off road
    i will not admit the interval cause i would get slack from everyone but quaker syn, and napa gold filters, changin the filter every 5k...
  14. Mar 23, 2010 at 9:54 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I use dino and change it out every 4 months (approximately 1,500 miles.) That's not much mileage, but I figure 3 times a year since dino is less expensive and the oil/filter is so easy to change.
  15. Mar 23, 2010 at 10:06 PM
    DheadTaco
    DheadTaco Pill it till you kill it!
    Gulf Coast, Mississippi
    07 Tacoma PreRunner SR5 Impulse Red Pearl
    -Color Matched Grill & Toyota emblem -Headlights from WOTM -Tinted Fogs with Lamin-x (Tint) -Tinted taillights with Lamin-x (Tint) -6K HIDs in headlights and fogs -20% tint all around -Plasti-dipped badges -Plasti-dipped back bumper -Mud flap mod -'10 running-boards -LEDs all around -AFE drop-in
    I usually change it with Mobil1 Oil and Oil Filter. Runs like a champ.
  16. Mar 23, 2010 at 11:48 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    question so how does the light know when your oil is bad. I imagine its pre-programmed to go off the trucks mileage. which is factory set. saying that I found with the expertise of my company's oil analyst that most everyone changes their oil to often. The car makers do that to make money for the oil dudes in return for some under the table cash of some sort in some way or fashion. He took a sample of my normal valvoline oil after 5k and said according to his numbers the oil and its level of contaminants could easily go for another 5 to 7k. But will I do that, probably not because I have been conditioned to believe otherwise. Just a weird late night rant I suppose.
  17. Mar 23, 2010 at 11:52 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Regular oil every 5k here.
  18. Mar 23, 2010 at 11:56 PM
    SoCaliSnowboarder77
    SoCaliSnowboarder77 Well-Known Member
    Joe
    Valencia, Ca
    09 GSXR 600 & Snowboarders Hauler
    4x4 OFF-ROAD... that is all I need...
    Whenever the oil turns dark brown. It's due now and will get done this weekend. 7000 miles since last minor service.
  19. Mar 23, 2010 at 11:58 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    We can probably go 15k each oil change and I doubt something will happen. But ehh. Makes me feel good I'm taking care of my baby. :D
  20. Mar 24, 2010 at 12:03 AM
    SoCaliSnowboarder77
    Joe
    Valencia, Ca
    That's 100% correct. Most engines now can even use oil that 10000 miles old and is black and viscous, but you'll see a dip in mpg and performance. My Coma's oil is dark brown now and it's gettin 2 mpg less than usual and struggles more than usual. I change it once it turns darker brown but not black mainly b/c the engine works harder.
