How many miles do you get with a full tank???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08Tacoma, Jul 2, 2008.
  1. Oct 30, 2008 at 5:26 AM
    #201
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    if i driver like a grandpa i get 350 to 375 a tank
  2. Oct 30, 2008 at 6:19 AM
    #202
    taconinja
    taconinja Well-Known Member
    Pittsburgh
    08 Base 4X4
    I'm averaging 380 miles a tank. I fill up at the first, best priced station I come across once the light comes on. This usually takes 17-18 gallons, meaning I must have 3-4 gallons reserve. I am averaging 21.6 mpg combined, but one tank yielded 24.3 mpg after 387 miles of mostly highway. I just changed to AMS 5W20 XL synthetic and am already noticing better mileage. 90 miles driven and yet to pass the first quarter mark. I just passed 5000 miles on the odometer. I plan on removing the secondary after a couple tanks and then getting the AFE drop-in a couple tanks after that. I hope to see mid to high 20s on my highway trips.
  3. Oct 30, 2008 at 7:25 AM
    #203
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    I don't know how some of you are calculating you mileage? When you say you are going 360-380 miles on a tank with a few gallons left in the tank
    you are getting 17-19 mpg.
  4. Oct 30, 2008 at 7:34 AM
    #204
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I normally use about 18 gallons to get to about 380 miles. That's 21 mpg.
  5. Oct 30, 2008 at 7:36 AM
    #205
    gfisher99
    gfisher99 Active Member
    Austin, TX
    11 MGM TRD Sport DC
    Just got my X-Runner last week, came with a full tank. Got 310 miles until the gas light came on. Filled up to first pump cut-off, and it was 17.4 Gallons. Around 17mpg. I live in an Austin, TX suburb (Lakeway) and my drive to work is about 18 miles one-way on two 60mph roads. Since its an X-Runner, its obviously the V6...
    Greg
  6. Oct 30, 2008 at 7:40 AM
    #206
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    There's really only one sure way to accurately calculate your gas economy.
    1. Top off the tank until you can't get anymore into it.
    2. Drive a LONG trip, or until the gas light comes on.
    3. Top off the tank again until you can't get anymore into it. Take miles on the odometer and divide by gallons filled on the pump.
  7. Oct 30, 2008 at 7:45 AM
    #207
    taconinja
    Pittsburgh
    08 Base 4X4
    Yeah, this is how I do it. Or monitor flow rate in gpm at the injector to know true fuel usage and have a tachometer that knows your exact tire circumference, which would be a dr value since you are constantly decreasing your tread, you would need a laser position transducer to do this. Yeah that gets complicated...
  8. Oct 30, 2008 at 8:48 AM
    #208
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Filled up last night... 19.2 gallons to go 353 miles, or 18.4 mpg. I'm by no means driving with a heavy foot, and this is about normal for me so far with my '09. Kinda makes me wish that I had bought an automatic. I did just do my first oil change last weekend, and switched to Mobile One, so I'm hoping that will help a little.
    I've been using my friend's Scanguage for the last month, and figured out that if I take the highway home from work instead of the Interstate, I can get about 25mpg on the trip home (slightly downhill). Only problem being that I'm getting about 16mpg on the way to work (uphill), and have to use the Interstate because I'm not leaving the house early enough.
  9. Oct 30, 2008 at 8:55 AM
    #209
    Radelix
    Radelix Runs with Scissors
    Los Angeles
    17 trdor dcsb 6mt
    400 driving like I have no where to be, coasting to lights with it in gear to get the fuel cutoff, coasting down hills, being super anal about tire pressure, keeping truck clean to reduce drag, and reducing unnecessary weight <------------that one includes me losing weight since I became a fatty and no longer wish to be one. down to 182 from 195
  10. Oct 30, 2008 at 9:10 AM
    #210
    TSUNAMI*22
    Stockton, CA
    You guys with V6's and 4x4's are gonna struggle with gas economy no matter what. It's just the way it is.
    The biggest help you guys can do for yourself is drive 55 - 60 for the reduction in wind drag and keep excess weight out of the vehicle.
    Shifting @ 2,000 rpm's helps too.
  11. Oct 30, 2008 at 9:42 AM
    #211
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    My gas light just came w/ 350 miles on the tank, I drove mix of city/ highway and country roads. I put the truck in Neutral to coast to stop sign and red lights and drive 55-60, yes I know grandpa. At red lights I shut the truck off to help more and also I roll through stop signs so I don't have to start from a dead stop. I love cruising behind a fast big rig or bus. I also let truck shift before 2k rpm normally at 15-18k rpm.
  12. Oct 30, 2008 at 8:51 PM
    #212
    Smurfio18
    Smurfio18 Well-Known Member
    Northridge
    06 Tacoma TRD PreRunner
    I keep it Stock but Clean!
    About 350 before the fuel light comes on.
  13. Oct 30, 2008 at 11:46 PM
    #213
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    The most I have gotten, was recently. I have had my truck for about 4 months now, and I finally pushed it pretty far, past the "E" with the light on, got 289.8 miles. one a single tank.
    Specs: 08 Auto, DB Cab, LongBed, 275/70/17's, 3" lift.
  14. Oct 31, 2008 at 4:08 AM
    #214
    hardhat
    hardhat Member
    Well U drive mostly to work and back rarely going over 50, Its all stop and go traffic and my truck wams up on the way, its only 6 miles to work. I only get 230 miles for the 18 gallons I used. Thats only about 12-13 mpg!
    I have 33 KM2's, URD intake, calibrator. I drive pretty aggresivley also.
  15. Nov 6, 2008 at 4:17 PM
    #215
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    I go about 340 -360 with 2-3 gallons left in the 21 gal tank that i can't seem to empty. doesn't matter how long i drive with the fuel light on most i have ever pump in was 19 1/2 gallons. Best mileage was 438mi and still only put 19 1/2 in. I had a o6 acces cab trd and best mileage i had with that was about 19mpg but still could only fit 19 gal or so in it.
  16. Nov 6, 2008 at 4:24 PM
    #216
    Synapse
    Synapse Well-Known Member
    Birmingham
    2008 Tacoma
    Same here. My 4cyl get 450ish before the light comes on, but you would think we had a 17ish gallon tank.
    On the other hand, I ran one time 80+miles with the light on (Debit card wouldnt work!%&) one night coming home, and the sucker didnt run out of gas.
    You can get to the bottom of the "E" and still be ok (for a short time :D).
  17. Nov 6, 2008 at 4:36 PM
    #217
    Smurfio18
    Northridge
    Just checked it today. I get 290 miles with 5 gallons left in the tank. Not to bad considering I use a heavy foot occasionally.
  18. Nov 6, 2008 at 5:35 PM
    #218
    H4LFPNT
    H4LFPNT New Member
    San Diego, North County
    08 PreRunner TRD OffRoad 6 Speed Manual
    K & N Intake, MagnaFlow Exhaust Cat-Back
    I get anywhere from 14-16 mpg :( but I drive a lot and drive free way and city . . . . and kinda fast :/
  19. Nov 7, 2008 at 11:15 AM
    #219
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    About 650km to a tank.
  20. Nov 8, 2008 at 12:07 AM
    #220
    Rich Swanner
    Rich Swanner Well-Known Member
    N.California
    2007 Black PreRunner DC V6 SR5 LB
    Leer 100R Shell NXT Tech Wax
    Last trip to Monterey/Carmel Ca. 21gals 468.3= 22.3 MPG ...Rich _MG_8384_edited-2Large-1_f9ce115711d659a5b005d24186e157a8098d880e.jpg
