how many miles does your 4 banger get on one full tank??
Discussion in '4 Cylinder' started by 04prerunner, Feb 8, 2010.
  1. Feb 16, 2013 at 3:02 PM
    #181
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You are not going to have the Ultragauge properly calibrated after only 3 fill ups.
  2. Mar 13, 2013 at 8:41 PM
    #182
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    410 miles on one tank.
  3. Mar 14, 2013 at 7:56 PM
    #183
    ChrisGralnic
    ChrisGralnic Well-Known Member
    Southern cali
    06 Prunner with AAL and Trd suspension W/lift
    Previous owner used to haul heavy loads, so he put an AAL on it and TRD front suspension with a lift and custom rear suspension for added weight capacity. I recently installed a tow package (Curt with lifetime warranty) So i will definitely see what this thing can handle as far as weight goes.
    I got as much as 487 on my 2006 prerunner with a manual transmission. Using whatever kind of gas the dealership used. Never use valero for your truck. My truck went through it twice as fast as any other gasoline for some reason.
  4. Mar 10, 2014 at 11:12 PM
    #184
    badfish87
    badfish87 New Member
    Royal Palm Beach, FL
    2006 Tacoma, base model
    Undercover hard tonneau cover, secondary filter removal, full synthetic
    I NEVER get less than 400 miles out of a tank. Though I push it a little. The low fuel light comes on when you have 4 or 5 gallons left (2nd gens.) Anyway, I have pushed it to nearly 500 miles before. And i put 20.5 gallons in it at fill up, so I was Real close to running out. My truck is a bone stock '06, 2.7 liter, manual, base model, single cab. And I run full synthetic everywhere, which makes a small difference. But the biggest thing is driving habits. I can tell when I've been driving fast by my mileage. Usually I try to keep it under 2500 rpm, and It throw 'er in neutral and coast up to lights, stop signs, etc whenever possible.
  5. Mar 11, 2014 at 7:37 PM
    #185
    Rich91710
    Rich
    Los Angeles
    08 Base
    Bingo.
    While my average is mid-24, even at that, 24.5 at 20 gallons is 490 miles.
  6. Mar 12, 2014 at 7:44 PM
    #186
    FTD
    FTD Well-Known Member
    I run a very consistent 22.5 mpg. I don't know what that works out to per tank, but I'm pretty happy with it.
  7. Mar 17, 2014 at 3:15 PM
    #187
    Taco Todd
    Taco Todd Well-Known Member
    Todd
    Cleveland
    2021 SR 4cyl
    I was doing about 80mph on the highway to Detroit and it was super windy out. got around 17-18mpg. typically I drive about 60-65mph and do a lot better. but that 4cyl was running close to 3000rpm and that hurt a lot. I try to keep it under 2500
  8. Mar 17, 2014 at 8:25 PM
    #188
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    All city driving, WOT high into the rpms most of the time.. 16mpg +/-a few :(
  9. Mar 17, 2014 at 8:35 PM
    #189
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    I averaged 21.6mpg last weekend roundtrip from Minneapolis to Chicago. I has cruise control set at 72mph. I'm going to run it again the weekend with seafoam in the tank to clean things up. We'll see what that does.
  10. Apr 17, 2014 at 5:34 PM
    #190
    Stevenlpkr
    Stevenlpkr Member
    Erie, PA
    2014 RC 2WD base
    2014 regular cab 2wd auto 4 cylinder. Only my second fill up, and I got 425 miles before the light came on. Happy with the mileage so far.
  11. Apr 21, 2014 at 11:13 AM
    #191
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    2007 Base /w 2.7 engine and auto. I am pushing around a full bed cap, which is 4-5" higher than the cab, and also a full ladder roof rack which extends forward over the cab. I generally have a fair amount of weight in the truck - most of 1000 lbs. I would guess. Mobil 1 oil, 235R75-15 Michelin tires. Get about 18-19 mpg on average. 3-4 less if I am hurrying on the interstates. <g>
  12. Apr 21, 2014 at 2:55 PM
    #192
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    2014 4x4 4 tanks of gas so far. It gets btween 21.0 and 21.7
  13. Apr 22, 2014 at 5:20 AM
    #193
    Poodle Head Mikey
    I used to have a 2013 Corolla which got about 29-30 mpg. I traded it in on a 2014 Corolla Eco with that no-gears transmission.
    Well; the 2014 is much faster, much quicker, AND gets close to 40 mpg.
    How the hell did Toyota manage That trick? <g>
  14. Feb 6, 2015 at 5:28 AM
    #194
    siderman
    siderman Well-Known Member
    been few yrs and 10k since my last post and my local/city type 4cyl4x mpg has improved from a disapointing initial 17,18 to about 20,21 so not too shabby.
  15. Feb 6, 2015 at 5:31 AM
    #195
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Can't beat the flats of Erie for mpg
  16. Feb 6, 2015 at 7:30 AM
    #196
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    If you look here
    https://www.fuelly.com/driver/xaks
    (caution, my ugly mug is there too)
    You'll see around 110,000 miles tracked on 3 2.7L 5 speed reg cab Tacos since 2008.
    I think about filling around 375 normally. I've gone 460-475ish a couple times and still had a few gallons left, but I don't like running it so low, since the fuel is also the coolant/lube for the fuel pump.
  17. Feb 6, 2015 at 7:33 AM
    #197
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    at the moment, 240.
    my valve cover gasket is going and i have a leak somewhere in my EVAP system
  18. Feb 6, 2015 at 7:44 AM
    #198
    AllTerrainMonster
    AllTerrainMonster Well-Known Member
    South Korea
    2006 2.7L Base 2WD
    mostly city driving, gauge says about 20.5 mpg's... summer get's about 24-28 depending on the weight of my foot...
  19. Feb 9, 2015 at 8:56 AM
    #199
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    for the last 3 months I have gotten 19.71 mpg, but its going downward due to the crap winter gas. Lately I have been filling up around the 325 miles.
    In Aug-Nov, I was averaging 22.43 mpg (bought new in Aug).
  20. Feb 9, 2015 at 2:57 PM
    #200
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    My last ten tanks have averaged 21.4 MPG. Not bad considering 85% of my driving is 3 mile trips back and forth to work.
