how many miles for code to reappear?
Discussion in 'Technical Chat' started by OffroadToy, Apr 6, 2013.
  1. Apr 6, 2013 at 9:12 AM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I searched for this but came up empty handed. I had a few lights on the dash yesterday... check engine/slip indicator were solid and VSC was flashing. After getting the codes i figured it was the gas cap and had the codes cleared after re-tightening the cap. Anyway, my question is if it wasn't the cap and actually another problem how long would it take for the lights to re-appear on the dash? I heard after 32 miles of driving if they don't come back on your good to go... is this true?
  2. Apr 6, 2013 at 9:21 AM
    Tacoma Mike
    Southern Maine
    All depends on the code and the trip monitor logic . Sometimes 30 seconds, sometimes a day. Mileage in some cases has no bearing.
  3. Apr 6, 2013 at 1:34 PM
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Certain criteria has to be met. Coolant temp, rpm......every DTC has its own parameters before PCM trigger codes
  4. Apr 6, 2013 at 6:32 PM
    OffroadToy
    Thankyou :)
