HOW MANY MILES FOR FULL TANK STOCK TACOMA?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JLUIS, Feb 2, 2013.
  1. Feb 8, 2013 at 5:05 AM
    #41
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    This. I suppose the math is easier this way. But the rest makes little practical sense.
  2. Feb 8, 2013 at 5:35 AM
    #42
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    320 miles or so on 17-19 gallons thats all in town driving.
  3. Feb 8, 2013 at 6:47 AM
    #43
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    2010 dclb Auto stock was getting 375
    Same truck lifted with 305/70/16 got me 325
    Same truck with 285/75/16 on 10 ply got me 225!!
  4. Feb 8, 2013 at 6:49 AM
    #44
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  5. Feb 8, 2013 at 6:58 AM
    #45
    Runn0r
    Runn0r Well-Known Member
    NC
    07 Prerunn0r
    I have a google engine that gets 9000 mpg. its pretty sweet
  6. Feb 8, 2013 at 3:01 PM
    #46
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    From pump's final click to dead rolling brick
    was eighteen point five gallons measured;
    I never did believe that a jerry can
    would be an item I so dearly treasured.
    The light popped on a measly 4.7 miles earlier. I haven't run it to the light since.
    I was lucky, the can was empty, but the truck stopped right in front of the gas station I was heading to :mad:
    Yes, I did remember to compensate for the can. It took 2.2 gallons. Truck took another 16.3 to fill.
  7. Feb 8, 2013 at 8:14 PM
    #47
    MrTacoma
    MrTacoma Well-Known Member
    Tacoma Base v6
    None
    I ussally fill it up at around 240 miles.the gas gauge is just past a 1/4 mark..I've been averaging 15.7 ish for MPG and been topping it off with about 15 gallons each fill up..Ive been trying to get more miles out of the tank..im at 101k ..i put tonneau..aired tires to 35 psi..and just cleaned throttle body and mass air flow sensor.. however since i cleaned the tb and maf it been vibrating when acclerating while theres more pick up seems to be using more fuel...i feel like im the only one that didnt get gain out of cleaning those..they were pretty dirty..im worried i put it together wrong or something is lose idk
  8. Feb 8, 2013 at 8:31 PM
    #48
    iroh
    michigander
    tonneau
    You didn't touch the wires up in the tube with anything right?
    I bet it's just running on learned data that compensated for that dirty MAF. Sounds like it's time to record your tripmeters/radio presets and unplug the battery for 15 minutes to reset the ECU.
  9. Feb 8, 2013 at 8:39 PM
    #49
    MrTacoma
    Tacoma Base v6
    None
    I spray a little in the black thing the TB was connected to with throttle body spray ..but i assumed it evaporated or dried by now...I wasnt sure if didnt tight something down tight enough. I was thinking the screw that holds down the black tubing to the throttle bottle was lose but i figured my check engine light would of lit up...I did the whole cleaning with the negative battery disconnected should i take both terminals off see what it does?
  10. Feb 8, 2013 at 10:40 PM
    #50
    iroh
    michigander
    tonneau
    Just the ground terminal is sufficient. Don't take the positive off with the ground still connected; it's no fun to weld the wrench to the truck moments before the battery overheats and blows up.
    Since you already disconnected the battery, you get to have fun with its re-learning procedure. It kind of sucks. I know you don't drive one, but with the manual tranny, those first 100 miles or so, every time the clutch goes down it revs to 2000 rpm before it figures out its own stupidity.
    Doesn't sound like you cleaned the MAF from that description. It's the sensor that has the big plug on the top front of the airbox, between the TB and the filter. For some reason the cosmetic cover has a square hole so you can see it. Two phillips screws and it comes out, straight up. The MAF has an IAT sensor on the side (that loves to collect dirt for some reason, spray it off too) and the actual MAF wires are up inside its square venturi tube; those are what cause headaches and sometimes need spraying with MAF cleaner. Those two ridiculously tiny coil wires are what I was referring to - don't touch them with anything.
    edit: here's a youtube video showing the sensor. He never actually cleans the MAF wires, just the air temp sensor on the outside. The important ones are inside the part.
    http://www.youtube.com/watch?v=qiEdey2IHcc
  11. Feb 9, 2013 at 4:09 AM
    #51
    toyota25270
    toyota25270 Member
    USA
    TRD SPORT
    (2inch lift)Toytech ARE Hardcover,456 GEARS.Bully bar
    Just ran my 1st tank out of mine.2007 V-6 Auto TRD,265-65-17 on it.Ran it until light came on.Temp was from 10* to 32* high.Break down on mileage 105 highway,30+ in 4x4 because or storm,rest of mileage 50-55 on rural road.Plus I got on it 2 time up a steep 1/4 mile hill to see what it would do 82mph.Total mileage!(18.4MPG).This truck has 456 gears and im going to put on 265-70-r17 Firestones on it,will lessen the RPM"S and when it warms up I hope to get 20.
  12. Feb 9, 2013 at 4:41 AM
    #52
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Almost always right at 300 miles to light on. If someone thinks they can get the 21 or what ever gallons that the factory says the tank holds, kind of forgetting that the fuel pump is in there taking up space. Haven't ran my truck empty, but like 40 miles with light on and butt puckered, there was not much if any fuel left in the tank. Think I had 340 miles on the clock. Put in 18.7 gallons. There's no way the tank can actually be filled with 21 gallons of gas.
  13. Feb 9, 2013 at 4:45 AM
    #53
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    I'm getting around 300-330 depending on highway vs city driving and time of year. Around 17 gals to fill up. With the fuel additives in winter mileage goes way down. Summer gas is better for mpg's. The EPA pulling their heads out of their asses and admitting ethanol has failed miserably would make it a hell of a lot better. Ethanol kills gas mileage. This is counter productive to helping the environment and using less gas. What a bunch of idiots. Many car companies are now telling consumers using E-15 voids your warranty. What does that tell you about ethanol? Funny the EPA can't figure this out but measly car companies can. There are so many negative facts about ethanol I can't even list them all here.
  14. Feb 9, 2013 at 5:05 AM
    #54
    dpi
    dpi Well-Known Member
    Dan
    Tulsa, OK
    AFE Stage 2 SI CAI Banks 3" Mandrel bend Cat Back dpi Rock Sliders
    Last tank went 373 miles. Added 18.7 gallons at fill-up and averaged 19.9 mpg.
    2012 DCSB TRD
    6 Speed Manual
    13k miles
  15. Feb 9, 2013 at 9:46 PM
    #55
    MrTacoma
    Tacoma Base v6
    None
    I've seen video before, I pulled that sensor out and soaked it with CRN cleaner and let it dry which it did quickly I might pull it out and try again do I really need to disconnect the negative again? Or is it just matter letting the computer relearn ?
  16. Feb 10, 2013 at 5:59 AM
    #56
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Warm weather 400+ winter, snow tires, and cold 350.
  17. Feb 10, 2013 at 6:25 AM
    #57
    iroh
    michigander
    tonneau
    K, you already cleaned it, time to give it a few weeks to settle down. It usually takes my truck about a thousand miles after a battery disconnect to come back up to typical mileage. Since I changed my battery out a week ago I'm going through similar fun as you. I wish Toyota had more precise baseline maps :mad:
  18. Feb 10, 2013 at 8:21 PM
    #58
    zackn291
    zackn291 Well-Known Member
    Zack
    Princeton, Ontario
    '05 Taco TRD
    Bilstein 5100 set at 2.5", 2" AAL, Fog light mod.
    I track all my mileage until the light comes on. My "city" has a population of 14,000 people. I bitch when it takes me longer the 5 minutes to get across town.
  19. Feb 10, 2013 at 8:30 PM
    #59
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I have a 40 mile daily commute, which for most people born and raised in Hawaii is kinda far. Luckily for me I go to work at 4:30am and finish before peak traffic. Probably why I normally average 20+ mpg.
  20. Feb 10, 2013 at 9:39 PM
    #60
    MrTacoma
    Tacoma Base v6
    None
    After about 100 miles after the cleaning it seems to have stopped acting funky..thanks for all the advice from everyone here though this was the first time i did it ..I just wasnt sure if i did something wrong wanted see from ppl who've done it before reason why it was doing what it was doing..
