HOW MANY MILES FOR FULL TANK STOCK TACOMA?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JLUIS, Feb 2, 2013.
  1. Feb 10, 2013 at 9:40 PM
    #61
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    2009
    Light on around 320-340.
    V6 Auto
    Use to be light on ~350+ until bigger tires.
  2. Feb 10, 2013 at 10:15 PM
    #62
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    375-400 year round here in FL.
    400 was easier to attain with stock tires on current taco and less weight of DCSB on my 2011...
  3. Feb 10, 2013 at 10:20 PM
    #63
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Pretty much same here.....only did it a couple times, I worry about the fuel pump.
    Tire size for me is minimal tho....265/75/r16 and load range C, so I don't "think" I added too much.
  4. Feb 11, 2013 at 4:24 PM
    #64
    dboz
    dboz Well-Known Member
    Access Literider Tonneau, GO RHINO Dominator II side steps
    WTF?!!! I know my truck is brand new, but I am down to a quarter tank and not even at 200 miles yet. 50/50 mix and driving it mildly until break in. I need to go check my tire inflation or something! I was not expecting a Prius by any means but I was hoping for more than 13-14!!!!!!!
  5. Feb 11, 2013 at 4:26 PM
    #65
    dboz
    How the heck? You are almost 50% more than me with the exact same truck???
  6. Feb 12, 2013 at 12:38 PM
    #66
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Guys, guys... first off... the tank holds 21.1 gallons. Second, you should never run it dry. Third, the gauge needle pointing to 1/4 full line doesn't mean you have 1/4 of 21 (or 5.25 gallons) still in the tank... you do have 8 gallons at that point (+/- .5).
    When the low fuel light comes on, you have 4 gallons (fill up with 17 gallons).
    When the needle is right on the E line, you have 3 gallons (fill up with 18 gallons).
    I don't very often, but have put over 19 gallons in the tank (needle is below E), so if you ran out and pushed it to a pump and could not add more than 18.5 gallons, there are other issues, or you didn't top off (some states don't allow topping off). I don't mean fill it till it runs on the ground, either!
  7. Feb 12, 2013 at 12:44 PM
    #67
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The only way you can accurately figure mileage is miles driven divided by fuel used , not OMG I'm at xxx miles at around a 1/4 ish tank or so
  8. Feb 12, 2013 at 12:50 PM
    #68
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    you're talking to about 5-7 guys here. the rest are trying to figure out what a little bit past 1/4 tank on the gauge means in actual gallons..
    this thread is goofy. math is powerful ju-ju.
  9. Feb 12, 2013 at 3:58 PM
    #69
    dboz
    Thanks for that wisdom. After 30 years of driving I never knew how to figure MPG.:rolleyes:
  10. Feb 12, 2013 at 4:05 PM
    #70
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    thats nucking futttts!! is this a 4 cylinder???
    Granted clevelands roads are flat and straight most of the time, but still...
    i owe you a reach around!
  11. Feb 12, 2013 at 4:26 PM
    #71
    2012 Tacoma
    2012 Tacoma Well-Known Member
    Todd
    Illinois/Arizona
    2012 SR5
    Undercover Classic, TRD Skidplate, Wet Okoles
    2012 V6
    3300 Miles
    Auto
    261 miles last fill-up
    17.655 Gallons
    14.78 MPG
    3 mile commute one way
    40 mph top speed
  12. Feb 12, 2013 at 4:26 PM
    #72
    zackn291
    zackn291 Well-Known Member
    Zack
    Princeton, Ontario
    '05 Taco TRD
    Bilstein 5100 set at 2.5", 2" AAL, Fog light mod.
    how does that guy manage 26mpg?
  13. Feb 12, 2013 at 4:34 PM
    #73
    dboz
    Has to have extreme tire PSI.
  14. Feb 12, 2013 at 5:16 PM
    #74
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I stopped the video a couple seconds in. No 'R' to the left of 1st gear. Definitely a 5 speed 4 cylinder.
    I've averaged 24 mpg at that speed for an extended period but I had one mother of a tailwind. More typical is around 21 on summer gas.
    More than one person around here has pushed 25 mpg on the automatic in the 60-65 mph range but they're usually PreRunners
  15. Feb 12, 2013 at 5:25 PM
    #75
    OZ-T
    Peter North
    British Columbia
    dboz ?
    are you me ?
  16. Feb 12, 2013 at 5:29 PM
    #76
    Bridgeman
    Bridgeman TRD burglar
    Tyler
    Opelika, Al
    2006 TRD Sport 4x4 Speedway Blue
    2006 v6 sport dbl cb sb. 392 miles on 20.38 gal. was def puckered the last 30 miles
  17. Feb 12, 2013 at 5:30 PM
    #77
    rhowell
    rhowell Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Around 240. Just changed the plugs so I am hoping for a change.
  18. Feb 12, 2013 at 5:42 PM
    #78
    OZ-T
    Peter North
    British Columbia
    I get 420kms when the light comes on and usually put 64-65 litres back in
  19. Feb 12, 2013 at 5:44 PM
    #79
    Mark350
    Mark350 Well-Known Member
    I get roughly 350km's when it dips just below a quarter tank, which is when i usually fill up. I don't do a whole lot of highway driving so my mileage blows.
  20. Feb 13, 2013 at 12:33 PM
    #80
    David K
    For the lower 48: 260 miles and 17 gallons... 15.3 mpg
    Basically close to what I get if I don't have any highway miles (ie. city or stop and go driving)
    The E light coming on at 17 gallons used, also is spot on with my findings.
    Thanks Oz!
