How many miles from stock fuel injectors
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1943MB, Nov 2, 2021.
  1. May 13, 2024 at 6:40 PM
    ireymon
    ireymon Unknown Member
    Kenneth
    Winston-Salem, NC
    99 X-Cab 5 lug 5 speed
    Hyundai wheels, dings & dents...
    did you notice any difference in performance after doing this? I'm not far off from that mileage and have wondered what the inside of my intake looks like.
    And what did you use to clean all that crud from inside the runners!?
  2. May 13, 2024 at 6:49 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Well, I was 9 bolts away and 2 gaskets
    I decided to clean everything while I was in there
    She runs awesome now, but bc cleaned intake/plenum/TB/iAC/new RM injectors/cups all at once….can’t say cleaning gained HP or anything but definitely 10 times better afterwards
    buy stock in brake cleaner!
    Between this job^^^ and the T cover gaskets I replaced……I was $100 in on brake cleaner easy
    ireymon likes this.
  3. May 13, 2024 at 6:50 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    You can save yourself some of the brake clean if you just buy a bucket of xylene and leave the aluminum parts in it overnight.
    ireymon and ControlCar[QUOTED] like this.
  4. May 13, 2024 at 6:54 PM
    ControlCar
    Steven
    Sugar Land TX
  5. May 18, 2024 at 7:17 AM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
    those pieces have NOT been removed off my rig in nearly a quarter million miles since the first VCG weep was nipped
    does blow-by oil from the driver side VC vent hose cause that buildup? or the PCV hose from the passenger VC vent
  6. May 18, 2024 at 7:39 PM
    ControlCar
    Steven
    Sugar Land TX
    Black97
    To answer your Q
    I don’t know
    when I was gifted the Taco, was running perfectly except for “hot no start” condition
    But was leaking/seeping like a stuck pig
    from every where. No drips on driveway though!!!!
    AC compressor bracket had 3-4mm of that dirt/oil coating
    as I got deeper into the rebuild, I was like “I’m in there, might as well do it correct “ mode
    as far as blow by
    I installed a cheap oil separator I had in garage 2 months ago. Just for shits and giggles, I unscrewed the small dip stick, it started whistling! No doubt I have blowby
    THatt and Black97v6MT like this.
