How many miles is on your 2.7?
Discussion in '4 Cylinder' started by sourdough, Feb 8, 2010.
  1. Apr 1, 2011 at 8:12 AM
    #321
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    access cab 2009 just broke 26000kms
    later tig1
  2. Apr 2, 2011 at 5:40 PM
    #322
    frog13
    frog13 Well-Known Member
    Yes...2nd generation.Sounds trust worthy to me....more than likely,mine will be an auto trans.My last ruck I had for 18 years...93 F-150, only 135,000 miles.I'm tired of shifting..if you like shifting,go for it!...me,I'm tired.Thanks for the info.
  3. Apr 11, 2011 at 1:48 PM
    #323
    champs s10
    champs s10 Member
    Travis
    western ky
    2011 tacoma single cab base truck
    Rebel flag hanging from the rear view mirror and custom thrown mud on the side of the truck, aftermarket cd player, 10"mtx sub 400 watt amp, installed power inverter in bed 800 watt
    2011 coma single cab 2.7 5 speed only 1045 on it in a week of owning it bought it with only 24 miles on drove the he'll out it so far and 24 mpg at about 80 mph too
  4. Apr 11, 2011 at 2:05 PM
    #324
    johnsmith195011
    johnsmith195011 Member
    Boone NC
    95 lx
    191606
    95.5
    just replaced my o2 sensor
    i change my oil a lot
    nothing else
    (knock wood)
  5. Apr 11, 2011 at 5:55 PM
    #325
    Yota1
    Yota1 Well-Known Member
    why the hell can i not get better than 19.5 mpg???? i run 89 octane all the time. i don't over rev in a gear, worst is 45 mph in 4th for example. 75-80 on highway. should i drop to 87?? i thought i was driving like an a-hole, so i tamed it down a bit, same mileage. Not that it should make a difference, but truck has 11.5k on it now, bought in sept of 09
  6. Apr 11, 2011 at 6:31 PM
    #326
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    87 octane is fine.
    Need to start slowly, and don't drive over 65-70 on the highway.
    Check your tire pressure as well. Higher tire pressure = less rolling resistance.
    Full synthetic fluids throughout also help.
  7. Apr 15, 2011 at 11:37 PM
    #327
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    5280 give er take!!!! 2010 access cab. 7000 THAT WAS QUICK!!.........
  8. May 2, 2012 at 6:39 PM
    #328
    dentaco76247
    dentaco76247 Registered Mud Abuser
    Greg
    Justin, TX
    97 Tacoma xtra cab 4x4
    4Runner bucket seats, Upgraded headlights Blistein 5100s Blacked out Grille
    222915 miles as of today. Still gonig strong. I'm in the need of a new exhaust manifold or header. If anyone has one laying around I'll put it to good use.
  9. May 2, 2012 at 8:50 PM
    #329
    AztecH3r0
    AztecH3r0 Member
    Riverside, CA
    96 Tacoma
    picked up a 96 tacoma with 2.7 with 205k miles (abused...almost brought a tear to my eye) as a project truck for fun. now runs great with 215562m and a brighter future
  10. May 3, 2012 at 2:53 AM
    #330
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Odo reads 55K
    Really is about...56.5K.
    Ran 225/75 for 17K (Mile rato = 1:1.05)
    Run the 30's for about 3K now (Mile ratio = 1:1.1)
  11. May 3, 2012 at 3:18 AM
    #331
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    26,000 -- 2010
  12. May 3, 2012 at 6:54 AM
    #332
    WVToyota3214
    WVToyota3214 Active Member
    Tyler
    West Virginia
    Silver 08 Reg. Can 4x4
    Glass pack, Dick Cepek rims new tires, that's it for now
    08 4x4 just rolled over to 75,000. Replaced power steering pump at about 72,000 and not long after e break was not workin cause springs in back right wheel was broke got it fixed for free other then that she is good to go
  13. May 3, 2012 at 7:26 AM
    #333
    Quick_1911
    Quick_1911 Well-Known Member
    Brad
    Georgia
    08 Prerunner
    73k miles on my 08 Prerunner, no problems whatsoever (knock on wood).
  14. May 3, 2012 at 9:29 AM
    #334
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    189,000 now, and still on the original rear brake pads. Very thin but still usable. It will get new pads soon this summer regardless.
    The front pads went about 175K before replace, so with all this it kinda gives you a idea of brake proportioning front to back.
    Recently replaced the oem springs and shocks with Old man Emu stuff and Billies. the oem replacement Billies that I installed many months ago I think are about had, so we will do some research and bump the shock replacement up.
  15. May 3, 2012 at 9:37 AM
    #335
    ffbartlett
    ffbartlett Well-Known Member
    southern california
    2011 Reg Cab 4x4
    tint, bfg's, 5100's, tunnel cover.
  16. May 3, 2012 at 9:43 AM
    #336
    rydaniels
    rydaniels Well-Known Member
    South Jersey
    4x4 4cyl manual
    bone stock except tool box in bed
    bought new in feb of 2011, to date 21,1XX
  17. May 3, 2012 at 7:41 PM
    #337
    Dabear
    Dabear Member
    Amesbury MA
    2001 Tacoma XCab 4Banger 260k
    I have a 2001 with a frame replacement. I have 294000 on it right now. driver her everyday. I am aiming for 300K. Then I wll thingk about a new one. Owned her since day one and will owner her till the tires fall off.
    :eek:
  18. May 4, 2012 at 12:18 AM
    #338
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I wonder how they determined who got $$ and who got a frame replacement ? I had a 2000 and they gave me one and a half X book which I used to buy a 2008 new.
  19. May 5, 2012 at 2:24 PM
    #339
    Gumby2012
    Gumby2012 Member
    Wichita, Kansas
    2012 Access Cab 4cyl. SR5
    LEER 700 Tonneau
    293
    Only owned it since Wednesday...
    Retired my 1995 F150 at 230133 miles.:)
  20. May 5, 2012 at 2:58 PM
    #340
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    2008 RC Base, about 65k on it.
    I bought it last December, had 52k on it.
    No problems other than the TPMS won't clear.
