How many miles is on your 2.7?
Discussion in '4 Cylinder' started by sourdough, Feb 8, 2010.
  1. May 13, 2013 at 11:56 AM
    #621
    81shark
    81shark Well-Known Member
    that's me. my thinking is, the hoses won't last a second 100K which is how long our coolant is suppose to last.
    figure it makes sense to change the hoses while the coolant is already out, vs blowing a hose and having to replace the hose and lost coolant.
  2. May 13, 2013 at 1:35 PM
    #622
    dunnman19
    dunnman19 Member
    Oregon
    97 Tacoma 4x4
    My 97 has 270k
  3. May 13, 2013 at 2:50 PM
    #623
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Sounds good - thanks. So far I dumped and replaced 1 gal at 30,000 and 1 gal at 60,000. I never completely flushed it. Maybe I should consider the hoses at 90,000. Wonder what the average life of a hose is ? Thanks for your answer.
  4. May 13, 2013 at 3:34 PM
    #624
    Fish Killer
    Fish Killer Active Member
    kai
    ventura
    base 2003, base 2012
    2003 Tacoma Injen Cold Air Intake. Bosch x4 Spark Plugs. Manual 5 speed 2012. Tacoma Stock, Manual 5 speed. Soon not to be. (Planned Headers, CAI, Muff)
    I have approximately 2300 miles on my 2012 Tacoma 2.7L
    Just got the AFE Cold Air Intake,
    Doug Thorley Exhaust Headers (Short)
    Aero 2525 muffler.
    Kai
  5. May 13, 2013 at 5:07 PM
    #625
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    My 2000 PreRunner 2.7 has 134k miles and is all original.The only problem I have is a bad 1st gear upshift/downshift solenoid.I have to manually put it in 1st and manually upshift to 2nd.After that the other gears shift normal.I can get all 3 solenoids for around $125 and it is an easy fix.I just hate pulling the pan off and am quite accustomed to shifting it.I still get between 18.5 and 19.5 mpg in town so not really a problem.I am curious at what miles these engines suffer the timing chain/chain guide issues.That is my only concern about this engine.I do have the cold start typical piston slap that goes away in 2-3 minutes.
  6. May 13, 2013 at 7:49 PM
    #626
    13Greysled
    13Greysled Well-Known Member
    WA
    13' Taco
    Tint
    A whole 700 miles in 2months.... yeah i dont drive a lot :)
  7. May 13, 2013 at 7:55 PM
    #627
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    70000 miles roughly so far 111500km
  8. May 13, 2013 at 7:56 PM
    #628
    BCTOYOTATACOMA03
    BCTOYOTATACOMA03 Active Member
    Samuel
    Mission, B.C.
    2003 SR5 4x4 Access Cab
    just hit a 170k miles on my 2003
  9. May 13, 2013 at 8:09 PM
    #629
    81shark
    i did a quick search after posting that. i saw people claiming to get anywhere from 130,000 to 250,000 on different makes and models (honda, ford, chevy, etc)
    good conversation. just looking at the maintenance schedule, and the coolant and spark plugs are at 90K miles, not 100k.
  10. May 13, 2013 at 9:06 PM
    #630
    BBZ813
    BBZ813 New Member
    Josh
    Tampa
    03 Tacoma 5 speed 4X4
    My '03 has 240,000 on it, so far only the front driver wheel bearing has been replaced. Sounds like the clutch is finally going out though
  11. May 13, 2013 at 11:26 PM
    #631
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    256,818!!!
  12. May 14, 2013 at 2:48 AM
    #632
    george3
    New Jersey
    Then a gal every 30 should B fine.
  13. May 14, 2013 at 7:33 PM
    #633
    09sr5
    09sr5 gonna be a long ride
    East Tennessee
    2009 sr5 2.7 4x4 AC
    265/75 AT3's on stock wheels. 5100's@1.75". Trail Gear sliders. Toytec AAL
    61k on my 09
  14. May 14, 2013 at 7:34 PM
    #634
    09sr5
    East Tennessee
    2009 sr5 2.7 4x4 AC
    Can you post a video of how it sounds in the sound clips section?
  15. May 15, 2013 at 6:11 PM
    #635
    Tacoma Crawler
    Tacoma Crawler Member
    Redding, CA
    Lifted with 35s
    Lifted, King coil overs, marlin crawler dual transfer case, 529 gears, detroit locker in the rear, ARB up front, custom rock sliders and rear bumper, ARB front bumper with warn 8000lb winch.
    Running strong and doesn't use a drop of oil.
  16. May 16, 2013 at 1:11 AM
    #636
    george3
    New Jersey
    How many water pumps ? Anything else other then normal maintenance - oil changes, battery etc. Thanks.
  17. May 16, 2013 at 11:39 AM
    #637
    Tacoma Crawler
    Redding, CA
    Lifted with 35s
    just 1 water pump.
  18. May 16, 2013 at 11:45 AM
    #638
    Tacoma Crawler
    Redding, CA
    Lifted with 35s
    Is the key. I believe this engine will run for 400,000 miles when taken care of.
  19. May 16, 2013 at 1:43 PM
    #639
    WDE TACO
    WDE TACO Punchingclowns (Xbox Gamertag)
    Scott
    Katy TX
    2013 Taco with hot sauce
    They are changing weekly
    171 miles....
  20. May 16, 2013 at 2:31 PM
    #640
    george3
    New Jersey
    Impressive. My water pump on my 2000 went at 91,000 and then the frame went LOL.
