How many miles is on your 2.7?
Discussion in '4 Cylinder' started by sourdough, Feb 8, 2010.
  1. May 19, 2013 at 11:01 AM
    #661
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    130k on my '91 Escort, 240k on my '94 Toyota P/U, 140k on my '03 Tundra, 45k on my '06 Duramax, 90k on my '08 Taco (that's not counting company cars and the 4 cars I drove from '78 to '90).
    Plus all of the cars my wife has driven....
    Never had an oiling related issue with any of them. It's not worth it for a daily driver.
  2. May 19, 2013 at 12:16 PM
    #662
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks - Just saved me $200 plus time installing. Sound like you have a fleet. I thought Chris 4X4 was the go to guy but U R a wealth of info. Thanks again.
  3. Sep 11, 2013 at 5:34 PM
    #663
    canucktacoma
    canucktacoma Active Member
    mike
    gta area, ontario canada
    sr5
    got 154 km on my 2008 acc cab,4cyl,,runs fine so far,,was wondering about water pump i saw on post,,when did it go..i'm using syn oil./just did coolent as well as all other fluids.
  4. Sep 12, 2013 at 10:52 AM
    #664
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Take the valve cover of off a 85 22R and hit the key with a live coil. You be cleaning up the mess running down both fenders for awhile. looks like a mixmaster set on ultra high. Kinda amazing really until the cleanup reality sets in.:eek: It was idiling and it was a gusher. young, dumb,,and curious.
    Just turned 199 on the "99"
  5. Sep 12, 2013 at 1:48 PM
    #665
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    167 on my 3RZ, "50k" on my ranger. True mileage unknown.
  6. Sep 12, 2013 at 10:56 PM
    #666
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya, chain-driven OHC is a bit different because the chain is splash-oiled.
    But the cam journals are dry on initial startup.
    Start the 22R with the oil cap off and you'll have the same effect as with the rocker cover off.
    And ya... I did it too.
    Adjusted the valves on bro-in-law's Mazda GLC. Didn't even think about the chain and cranked it over to see if the valves "sounded ok" after setting everything to proper clearances.
    Freaking mess.
  7. Sep 13, 2013 at 7:26 AM
    #667
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    A Fairlane or Galaxy or something. A 1968 I think.
    It was used and he bought it for my sister. I remember going to pick it up with him. There was some slight lifter noise but other than that it started and ran well.
    My sister then drove it uneventfully for several years until one day it overheated or something and then would not turn over or start. It happened somewhat far away so my father told the garage there to fix it.
    They called a day or two later to say that the engine was seized as the oil pump had no drive shaft. None; it wasn't there.
    Thinking: how the hell can that be? my father and I drove down there to see what was what. And not only was there no oil pump drive shaft (actually just a long flat piece of metal) but there hadn't been for a long time. But they had drained maybe two gallons of oil out of the car. <g> I eventually did find the twisted-off oil pump drive - by poking around in the hardened sludge in the bottom of the drain pan. <g> And the valve covers were Filled with hard baked looking sludge which had obviously not seen oil for a long time. The inside of the sludge was the exact same shape as the rocker arms - like a mold of them. <g>
    The oil pressure light bulb was not installed. <g> Apparently what had happened was that the oil pump failed so the previous owner had pretty much Filled the engine with oil, disabled the oil pressure light, and then sold the car to my father. My sister had checked the oil (had it checked at the gas station) and had always been told that she didn't need oil. <g> But eventually the oil level got to below the crankshaft and the engine seized.
    My point is that the engine apparently survived adequately well for years with zero oil pressure - only submersion and splash-lubrication. So the idea that anything bad happens to an engine in the few seconds it takes to get full oil flow just seems pretty remote to me. <g>
    PHM
  8. Sep 13, 2013 at 7:27 AM
    #668
    Poodle Head Mikey
    Oh; and I have 118K on my 2007 Tacoma w/2.7 running Mobil 1
    PHM
  9. Sep 13, 2013 at 7:10 PM
    #669
    Rich91710
    Rich
    Los Angeles
    08 Base
    Pretty hard to believe that story. The crank bearings could potentially be lubricated by splash and survive, but the camshaft would gall the bearings and seize very quickly, resulting in either a broken timing chain, or a broken camshaft.
    Sorry. I do not believe you.
  10. Sep 14, 2013 at 9:16 AM
    #670
    40950
    CR, WA
    stock
    Tons of pressure on a V8 lifter pushrod configuration. Somewhere south of 100 tons or 200,000 lbs per lifter face to camshaft lobe lift during operation. Once the oil wedge that is supporting the camshaft is gone,,it's a quick death. They wouldn't last long at all without lube. I know, you can youtube me all day long of pin it to win it motor blowups, but most of the time they are a failed motor anyways.
  11. Sep 14, 2013 at 9:32 AM
    #671
    Poodle Head Mikey
    It did, and still does, seem impossible to me too - which is why I remembered it all this time. <g> My father would be the best reference but he is dead. I'm about 99% sure that my brother wasn't living anywhere close at the time, and I doubt that my sister could even remember the car, let alone the details of it's final end. <g>
    Nonetheless; I called my brother just now (left a voicemail to call me) and I guess I give the incredible long shot of calling sister a call next.
    I'll see what kind of confirmation I can come up with but I'm pretty sure I remember it pretty well. I can remember the baked-on and clearly non-oiled sludge in the valve covers like I just saw them yesterday. I worked on my own vehicles all the time back then; rebuild engines and so forth, so I knew what I was looking at. Which is what made me go fishing around in the oil pan sludge for any 'spare' parts. <g>
    PHM
  12. Sep 14, 2013 at 10:15 AM
    #672
    40950
    CR, WA
    stock
    ,,And since the timing chain tensioner is oil pressure dependent, you want to keep good oil in the 20-22r's. Spendy tensioner when I bought mine nib. Had a pile o bucks in that 22R. TRD internal's, custom rods, Comp cams, matched head and intake flow work, custom header, custom 540 cfm carb. Pulled 275Hp out of the thing at a zillion rpms on the dyno back in 87. oil pressure was 75psi at full sing. A new Centerforce about every week, it just wouldn't hold it. Young, dumb and curious. Sold it and got my $5000 back out of it.
  13. Sep 14, 2013 at 4:03 PM
    #673
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup... The one thing that could bring the "bulletproof" 22r series to it's knees is lack of regular oil changes.
    Tensioner gums up, the guides wear, the chain stretches, and the cam goes out of time, causing loss of power, and eventually chain failure.
  14. Sep 14, 2013 at 11:12 PM
    #674
    RynoRodrigosaurus
    RynoRodrigosaurus New Member
    SF North Bay
    98 extended cab 5 speed "White Death"
    My 98 stickshift is at 325,000! Runs AMAZINGLY well :) Pretty sure the head gaskey just went out (spewing oil all over the header) Still running strong though this will require attention. On that note, the clutch has never been replaced. Still feels great, and smooth shifting of course!
  15. Dec 10, 2013 at 9:25 PM
    #675
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    Just rolled 36,000 on my 2011 today. Was using Amsoil but switched to Mobil 1.
  16. Dec 10, 2013 at 9:28 PM
    #676
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    2007 - 136,000
  17. Dec 10, 2013 at 9:45 PM
    #677
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    180k on my 1996 now
  18. Dec 11, 2013 at 5:57 AM
    #678
    Poodle Head Mikey
    124K on my 2007. Mobil 1. Last oil change was at 115,000 - so I guess I'll have to change the oil before I run back to NJ.
  19. Dec 11, 2013 at 6:52 AM
    #679
    40950
    CR, WA
    stock
    200,800 on my 99,,and still on the original real brake shoes with I would guess 70% left.
  20. Dec 11, 2013 at 6:57 AM
    #680
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    270,000 +, have 4.56 gearing so my mileage is off 1/10th every mile. Oil pan is leaking a little but that is a project for summer, not below freezing weather.
