How many miles is on your 2.7?
Discussion in '4 Cylinder' started by sourdough, Feb 8, 2010.
  1. Dec 11, 2013 at 7:04 AM
    #681
    TOPOMICH04COMA
    TOPOMICH04COMA Member
    Mark
    Tip o the Mitt
    '04' 4X4 RC 2.7
    Mojave Teflons
    135,000 on my 04 RC. Front brake pads and a muffler. I'll guess the muffler is because I'm in the rust belt, maybe. Happy to have the last of the first Gen's . Does anybody think it is worth it to change to synthetics at this point? I've already changed diffs, transfer and tranny to synthetics.
  2. Dec 11, 2013 at 7:12 AM
    #682
    josh843
    josh843 Well-Known Member
    Josh
    moncks corner, sc
    2001 reg cab prerunner
    Looked down at red light yesterday. Had it like 3 months, no problems except the pos clutch Toyota put in it, at least some people think Toyota offered diesels
  3. Dec 11, 2013 at 5:29 PM
    #683
    124x4tacoma
    124x4tacoma Member
    Margate, New Jersey
    12 4x4 access cab
    Tint Adjustable Shocks 1.75 Rear Leaf 1.5
    17,806 miles 2012
  4. Dec 12, 2013 at 6:24 AM
    #684
    Tacoma Crawler
    Tacoma Crawler Member
    Redding, CA
    Lifted with 35s
    Lifted, King coil overs, marlin crawler dual transfer case, 529 gears, detroit locker in the rear, ARB up front, custom rock sliders and rear bumper, ARB front bumper with warn 8000lb winch.
    Running strong.
  5. Dec 12, 2013 at 8:07 AM
    #685
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    TOPOMICH04COMA definitely worth it to switch to synthetics...been using them for decades...and don't believe the old tales about synthetics causing leaks...leaks will only occur if the vehicle was neglected in the first place.
  6. Dec 12, 2013 at 8:18 AM
    #686
    Fletch
    Fletch Well-Known Member
    John 14:6
    Orange County, Ca.
    Tacoma PreRunner
    15k..just a baby!!!
  7. Dec 13, 2013 at 8:23 PM
    #687
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Bingo.
    Early synthetics were much higher detergent content than conventional oils, so older engines that were "sludged up" would be cleaned by the synthetics and the result was (the revelation of existing) leaks.
    When synthetics were introduced, non-detergent oils were commonly available, and like the current resistance to 5w20 and 0w20, many "old timers" stuck with it (but didn't hesitate to try Amsoil because it was 'Murican).
  8. Dec 13, 2013 at 9:26 PM
    #688
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    The issue with switching to synthetic motor oil is doing so on a high mileage vehicle. The head gaskets get lubricated for years with conventional motor oil and when you switch to a synthetic, you will get leaks, unless you change your head gaskets when you make the switch.
    I read this on a website a while back, and while I certainly don't do any justice to explaining WHY this happens, I have to tell you I didn't believe it, but I found out the hard way - It is True.
  9. Dec 14, 2013 at 7:43 AM
    #689
    Hansel
    Glenn
    Arizona
    base
    I buy all my vehicles used, usually with 200k or more. I always switch them to synthetics with NO problems. IF the vehicle has been reasonably maintained, ie fairly regular oil changes...there has been no problem.
    The dino vs synthetic debate continues :)
    Bottom line is...as long as you change your oil you will be ok.
    I just like the benefits of synthetics. I put lots of miles on my vehicles, usually without many problems. I think synthetics help.
  10. Dec 14, 2013 at 10:18 AM
    #690
    vtmactech
    vtmactech Well-Known Member
    KS
    '11 Reg Cab 4cyl 4x4 MGM
    Hmmm, I have 15k also and 2 years older, I must be doing something wrong. Plan on keeping this truck 20+ years, unless a diesel emerges.
  11. Dec 14, 2013 at 3:42 PM
    #691
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    Well I haven't had my truck too long but it just rolled over to 108k today which is nothing for a 2.7. My truck in high school was a work truck and had over 320k miles on it and is still going.
  12. Dec 14, 2013 at 4:06 PM
    #692
    YEABOY
    YEABOY Well-Known Member
    05 w/160k miles no major work done. Just keep up maintenance and she'll run foreverrrrrr
  13. Dec 14, 2013 at 4:53 PM
    #693
    M0untainman22
    M0untainman22 New Member
    Newport News VA
    I have a 2001 xtra cab with 68,750k miles
  14. Dec 14, 2013 at 10:29 PM
    #694
    DerekM
    DerekM New Member
    ARB bumper, 3" leveling, 33x10.5 KM2
    2000 Tacoma 213k on it
    Parts changed:
    Clutch (turns out it wasn't wore out)
    Rack and Pinion (boot ripped and then seal broke)
    Power steering pump (changed with the r & p)
    Rear axle bearings and seals @ the wheels
    About to change out the exhaust manifold to a header. Got the infamous cracked header these motor where known for.
    LCE or Rock Ripper headers?
    Couldn't ask for a better truck, dad had the first four and I have had it since. The truck get off roaded and at times pulls twice its weight down the road.
  15. Dec 14, 2013 at 10:49 PM
    #695
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    im gonna go with the 2001+ header when i go to do mine one of these days
  16. Dec 15, 2013 at 7:35 AM
    #696
    vtmactech
    KS
    I have an LCE sitting in the box waiting for spare time. The equal length runners are supposed to be better for torque.
  17. Dec 15, 2013 at 5:48 PM
    #697
    Rich91710
    Rich
    Los Angeles
    08 Base
    On a 4-banger, Tri-Y is really best.
    And for Toyota 4-bangers, I have a lot of faith in LCE. They've been building great Toyota engines since the 18R.
  18. Dec 24, 2013 at 4:10 PM
    #698
    Taco3RZe
    Taco3RZe Member
    Georgia
    03 PreRunner SR5 4cyl.
    My 2003 Toyota Prerunner has 224K miles on it and shows no signs of stopping. The engine runs very strong, no signs that it is tired. Love the fact that it has a timing chain that I never have to change. Original starter, alternator, water pump.
    Only the power steering (presumably the pump) exhibits a bit of a whine in cold weather until it warms up. The power steering fluid has really never been changed.
  19. Dec 27, 2013 at 5:51 PM
    #699
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    153,000-5 speed Manual-only thing i have done was replaced cracked manifold, and still has the original clutch!
  20. Dec 27, 2013 at 7:09 PM
    #700
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Got my 2011 used July 2012 with 8000 on the odometer. It now has 50000 on it. Still going strong. I had originally hoped to get 200k in ten years out of it. If things keep going the way they are it will be closer to 400k.
