How many miles is on your 2.7?
Discussion in '4 Cylinder' started by sourdough, Feb 8, 2010.
  1. Aug 21, 2014 at 1:03 PM
    #781
    dukhunter20
    dukhunter20 New Member
    NE, Oklahoma
    01 4x4 SR5
    2001 Single Cab SR5 4X4 94,000 Miles
  2. Aug 23, 2014 at 4:33 PM
    #782
    MikeTaco
    MikeTaco Let's do this!!
    Miami, FL
    07 Regular Cab
    A Few...
    Hit 100K today!
  3. Aug 23, 2014 at 4:38 PM
    #783
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    185k on my 2006! No major mechanical issues either!
  4. Aug 28, 2014 at 11:05 AM
    #784
    thekraken
    thekraken Member
    Alex
    Washington
    '98 4wd 2.7L SR5 Xtra cab 3" lift
    3" Suspension lift, 33" Falken tires, black 2011 Taco rims, Double-din Pioneer stereo, black grill, plastic bedliner, Skyjacker rear shocks, Flowmaster 50 series Delta flow muffler w/single output.
    Didn't read through too many pages but so far haven't seen any with more than mine. A '98 4x4 with 322,xxx. Only thing Ive had a problem with is a worn out O2 sensor but that took 5 mins to replace. Other than that, has always been perfect.
  5. Aug 28, 2014 at 1:22 PM
    #785
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I'm impressed ! Maybe I should get rid of my 08 and look for a 98 :rolleyes:
    You haven't had to do wheel bearings, clutch, replace the frame ? I had to do wheel bearing with 65,000 on it and I don't go wheeling in the streams and mud holes some do. I'm sure you've done brakes, belts, plugs, MAF, filters as general maintenance. Thanks for any reply and congratulations.:D
  6. Aug 28, 2014 at 4:07 PM
    #786
    thekraken
    thekraken Member
    Alex
    Washington
    Hah yeah I've only put about 10k on it myself so Im not sure on exactly all of the maintenance, but I did replace the front brakes, plugs, air filter, oils/fluids etc, just general stuff. Unfortunately an auto so no clutch :/ (got it before I could drive *cough* legally *cough* so my parents didnt want to overwhelm me. Really wish I got a manual since I've driven a few). Apparently the frame is stock which surprises me because of the condition and lack of rust and my tie rod ends are getting a little loose so it wanders a bit at high speed.
    Little low on power in my opinion but its a high mileage 4-cyl hauling 50 lb tires around so Im not necessarily complaining.
  7. Aug 28, 2014 at 6:16 PM
    #787
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    i havent im sitting at 188k miles. my frame is spotless. i do need a clutch it chatters from a stop slightly. but frame and wheel bearings are original. truck came from my buddy(who got it from his grandparents that bought it new) i need to do the ac belt who knows how old that is.
  8. Aug 31, 2014 at 10:18 PM
    #788
    Gerry.GEG
    Gerry.GEG New Member
    PNW
    09 Taco 4x4
    He looked up the 2.7 and officially with proper maintenance it could last 450,000 miles.
    Being a Toyota, doesn't surprise me at all.
    My '09 only has 32.5k
    I have a very short commute.
  9. Sep 16, 2014 at 4:17 PM
    #789
    jmlinne
    jmlinne Well-Known Member
    Mitch
    Montana
    '97 Tacoma 4x4 w/ 5-speed manual and locking hubs, stock for now
    '97 has 186K and I'm overhauling due to lost compression. So far I'm amazed at the specs. The rod bearings are still within limits ( I will replace w/ new tho). The machine shop says the valves, seats and guides all look fine. I discovered that the tech who installed new exhaust valves 80K ago mistimed the cams and left out the twist in the exhaust cam. Maybe that was the whole problem. Oh well, it's apart now.
  10. Sep 17, 2014 at 6:42 PM
    #790
    Triangleacre1
    Triangleacre1 Well-Known Member
    Dustin
    Delaware
    01 Tacoma SR5
  11. Sep 19, 2014 at 4:51 AM
    #791
    YourActualName
    YourActualName Well-Known Member
    NH
    2015 Black Tacoma Limited DCLB
    Magnuson SC, +
    2.7
  12. Sep 19, 2014 at 9:01 PM
    #792
    Manderthal
    Manderthal Member
    Manderthal
    RI USA
    Impressive
  13. Sep 21, 2014 at 12:28 PM
    #793
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
  14. Sep 21, 2014 at 3:57 PM
    #794
    motoman515
    motoman515 Member
    tim
    Menifee, Calif.
    00 PreRunner XCab
    K&N Filter And Tube
    Just turned 443,000. 2nd engine. Everything else original. Engine would knock a little on startup, especially if it was cold in the morning. Not much cold weather here in So Calif.. Started using Lucas oil treatment, no knock at all. Unfortunately, getting a 450 and 420 code on cel. Of course, it needs to be smogged. So I've got some work to do.
  15. Sep 23, 2014 at 7:22 PM
    #795
    theark
    theark Member
    Noah
    Park City, UT
    '09 4x2 Access Cab
    -K&N Air Filter. -16" Toyota Highlander Alloy Rims -Firestone Riderite Air Springs
    2009 five lug with 108k. Been a rocky start. Radio, main crankshaft seal fail, a/c compressor clutch fail. at least they were covered under warranty. Water Pump replaced at 106k. At least it been averaging 26mpg. Still plan on driving into the ground......
  16. Oct 6, 2014 at 1:16 PM
    #796
    miazda
    miazda New Member
    Zane
    Sandy, OR
    98 SR5 4x4 xtracab
    1998 3rz-fe with 232k. Head gasket blew at 231, decided to ship the head off to be completely rebuilt. Still has consistent and within spec compression and the cylinders still look basically new.
  17. Oct 6, 2014 at 3:20 PM
    #797
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Up to 145,700 today.
    Dealer just took it for the frame treatment. Loaned me a beautiful highlander (so very quiet inside!), although I abhor the radio. It won't play folders off my USB stick! It just mixes everything together.
    Thursday I drop about $400 for bearings, seals, and other random parts when I pick it up so I can try to salvage this transmission. I would really love to have 5th gear again.
  18. Oct 9, 2014 at 3:58 PM
    #798
    Just
    Just Member
    Justin
    Russellville, AR
    08 2.7L SR5 5-Speed
    Magnaflow muffler
    Got mine a few months ago off a dealer, 27k on it and I thought that was good for a 2008. Looked great, felt great, almost to 31 now. Apparently an old man had it since new, barely drove it and garage kept it, then traded for a GMC. Nice little 5-speed 4x4. $17,000.
  19. Oct 9, 2014 at 9:33 PM
    #799
    george3
    New Jersey
    Nice ! A got the same truck but 79,000 on it. Yours is brand new from my point of view - 27k is nothing for the 2.7. Congratulations.
  20. Oct 26, 2014 at 10:25 PM
    #800
    ItsNachoTaco
    ItsNachoTaco New Member
    Kenny
    Phoenix, AZ
    2003 Tacoma TRD 4WD
    '03 Tacoma with 177,000. Still going strong. Only major repair was a water pump replacement a year ago.
