How many miles is on your 2.7?
Discussion in '4 Cylinder' started by sourdough, Feb 8, 2010.
  1. Dec 24, 2014 at 11:02 AM
    #821
    IronBagel
    IronBagel Well-Known Member
    Jake
    North Carolina
    2009 DCSB
    Hit 111k on the way to work the other day!
  2. Dec 26, 2014 at 3:14 PM
    #822
    motoman515
    motoman515 Member
    tim
    Menifee, Calif.
    00 PreRunner XCab
    K&N Filter And Tube
    Just hit 445,000.
  3. Dec 26, 2014 at 3:26 PM
    #823
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Anything major like a new motor ?
  4. Dec 26, 2014 at 5:59 PM
    #824
    Fubarjonny
    Fubarjonny Well-Known Member
    Jonathan
    Orange County, CA
    5-LUG?
    I got 83,000 miles on mine
  5. Dec 27, 2014 at 10:51 PM
    #825
    motoman515
    motoman515 Member
    tim
    Menifee, Calif.
    00 PreRunner XCab
    K&N Filter And Tube
    Replaced engine at 340,000 with a used engine out of a salvaged truck. Unknown mileage on that engine. Everything else i.e. Drivetrain is original.:) I've put over 100,000 on it. It is getting tired. Gonna run it till it dies.
  6. Dec 28, 2014 at 6:25 AM
    #826
    george3
    New Jersey
    Thanks for the reply. 340,000 sounds like a good goal for me -
  7. Dec 28, 2014 at 5:40 PM
    #827
    crainholio
    crainholio Well-Known Member
    253K miles here, rebuilt cylinder head at 199K due to valve clearance failure.
  8. Dec 29, 2014 at 6:15 AM
    #828
    george3
    New Jersey
    So do our 2.7's need valve adjustment as maintenance to avoid that ? Thanks for any reply. Curious George
  9. Dec 29, 2014 at 11:29 AM
    #829
    brian8980
    brian8980 Well-Known Member
    Brian
    Charlestown, MD
    98 Tacoma 4x4 2.7L 4C
    none, yet
    as of today 221,500
  10. Dec 29, 2014 at 1:20 PM
    #830
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Rocking 67k or so 2011 4 banger
  11. Dec 30, 2014 at 5:03 AM
    #831
    crainholio
    There's a measurement interval in the owner's manual, which I failed to do in time. Just over $1200 in rebuilt cylinder head and labor.
    It involves pulling the valve cover and measuring clearance at each valve. Adjustment involves removing disc-shaped shims on top of each valve "bucket" to set the clearance to spec.
  12. Dec 30, 2014 at 7:13 AM
    #832
    george3
    New Jersey
    Thanks for the reply. Sounds like more then I'd want to tackle. Hows it been running since ?
  13. Dec 31, 2014 at 8:48 AM
    #833
    crainholio
    Just over 28K miles since the rebuilt head went on and it still runs perfectly. I had it into the dealer and had them pull the valve cover to measure clearances, they're all in range still.
  14. Dec 31, 2014 at 10:08 AM
    #834
    george3
    New Jersey
    Congratulations - hope you get another 200K. Thanks for the reply.
  15. Dec 31, 2014 at 1:38 PM
    #835
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I have 184,xxx miles on my 2.7L 3RZ. A couple of years ago I heard about the valve clearance issue causing burnt valves and all that goes with it. I've since then taken my truck in every 25,000 miles to get my clearances checked. Needless to say at 184,xxx I'm still in tolerance. A couple are getting close but I will check again at 200,000 miles.
    I've seen some of these engines with valve clearance issues at earlier miles and some with more miles. So I would have to say that each engine is different to when it needs adjusted. I don't know if each one comes a little bit different from the factory or what, but it's definitely a case by case issue.
  16. Dec 31, 2014 at 1:39 PM
    #836
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    New valve springs locks/retainers with your $1200 spent?. Should have been. Getting close to a head check here and gonna full rebuild the thing when it needs to be done, along with scouring the intake clean, new injectors, ect. At 214 now,,and all sounds just like it should hot or cold.
    The bucket setups have been around for awhile. The old 18RG with Yamaha head I did up in the 80's when TRD was young, used buckets and shims. So simple it's stupid, but it makes for a long day adjusting valves, checking, readjusting. Of course, when your zinging the thing to 8200,stupidly,ya needs to be one with the valve settings. Only shattered one bucket in several years of beatdown. Don't miss it to much. I miss the shaft mount rockers to the stem in that respect, lol.
  17. Jan 1, 2015 at 5:01 AM
    #837
    crainholio
    The heads were completely assembled on arrival. Don't know if the valve springs, locks, & retainers were new or not.
    $1200 was parts and labor including Toyota head gasket kit, head bolts, Toyota coolant, etc. The head itself was in the $600 range.
    I tried replacing my injectors and don't recommend it. Actual stock injectors are very expensive, and the market is flooded with lookalike chinese knock-offs that are garbage.
    I got new-in-box ones from injectorwarehouse.com, very official looking sealed packages and the injectors looked just like my factory ones. They were junk. Engine ran terribly, hard to start, spark knock on hills, etc. Flow bench found 2 of them were dribbling gas out the nozzle full time and flowed nearly double the rated flow volume. Likely chinese lookalikes. Ended up getting a junkyard stock fuel rail & injectors, having the injectors ultrasonic cleaned and flow benched.
  18. Jan 3, 2015 at 9:52 PM
    #838
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    7700 at 6 months old.
  19. Jan 5, 2015 at 8:20 PM
    #839
    electrictaco
    electrictaco Member
    BC
    2020 Tacoma TRD off road AT
    canopy
    Not much in the way of problems. I was pissed at having to change a wheel bearing at 75 (46,500 miles) What the hell?? That was the left front. The right is hanging in there though. Truck gets sweeter every mile so far!!!
  20. Jan 5, 2015 at 10:20 PM
    #840
    fasttoyo
    fasttoyo Well-Known Member
    8700 @ 6 mons
    love everything about the truck except the clutch.
